Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Will not turn on.
Haul the tv from house to house and it worked at 1st house and not at the 2nd house. the power won't even come on now? What todo?
  • Philips Master
  • 3,459 Answers
No power - pop the back and check the fuse. Remember to unplug it from the wall first.
Also, look on the circuit boards for spilled fluid. Since you moved the set a bunch the tubes may have leaked. If they leaked on the circuit board it may be shorted out.
Posted on Jan 31, 2009
Graphics drivers windows xp
1st ur desktop is too old to run windows 7 since ur hardware is not compatible
2nd u must reinstall ur windows xp operating system and then head to the hp website and download the drivers responsible to run ur system normally http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90862&lc=en&cc=us&dlc=en&lang=en&cc=us
Dec 21, 2013 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Wi-fi extender
using a wireless uplink sucks and most equipment won\'t do it and the ones that try suck at it.
that said:
-set the 1st router up normal
-set the second router up EXACTLY the same (SSID/password)
-now change the IP on the second router so that if the 1st is 192.168.1.1 the 2nd is 192.168.1.2
-last turn off dhcp on the second router
-NOW run a ethernet from the 1st to the 2nd and plug it into any port but the internet port. (that port won\'t be used anymore)
-ta-da! 2 networks but as far as your wireless device is concerned they are the same 1.
i have done this many times.... I have 3 routers at my place and can walk the whole length of my condo without losing a single packet!
Nov 06, 2013 | Computers & Internet
1994 Ford Escort, auto trans, 83,000 mi, randomly won't shift from 1st to 2nd, randomly loses power at hwy speeds
It could be an internal problem with a pump, or it could be it needs to be serviced really bad. Most 'oil change' places can also do transmission services... I'd try that first, before paying a big repair bill to a shop. good luck.
Feb 05, 2013 | 1994 Ford Escort
2nd tv will not find signal after electric power cut
usually a surge like that can damage the circuitry
Jul 21, 2012 | Televison & Video
I've tried a puller and even used a torch to heat the silicone. It still won't turn.
Please explain what exactly you r trying to remove, 1st is the pully, 2nd is the harmonic balencer, may need an impact gun on the puller, and heat but dont melt the ballancer rubber. Make sure u r using the right puller not a "it should work" puller BIG BIG difference.
Mar 05, 2012 | Cars & Trucks
Only reverse works. No foward gears.
No forward movement in OD or D, but L2, L1 and R work: Forward sprag is broken. R&R. Try not to run or drive the car or further damage could result.
Do you have manual 1st? If so, can you shift through the gears...i.e. manual 1st to manual 2nd then 'D' then 'OD'??? Only 1st and 2nd gears use the forward sprag unless the LO/Rev clutch is engaged...i.e. 1st and 2nd if in "drive". If you can shift threw the gears manually then, yes, your forward sprag broke.
If no manual 1st then your sprag is not what broke. Sounds like you blew up the rear planet. If you pull the pan and find chunks of iron and steel, then that is probably what happened. If you have reverse then it is not the pump. If the pump was bad you would have no line pressure and it would slip in rev. or no rev. Not the beef sun shell either because you have rev., a broken sun shell would cause no 2nd, 4th and rev. gears. Either way the trans needs to come out and torn down and it will be easily found what went. Good luck and thank you for using Fixya.
Mar 06, 2010 | 1991 GMC C1500
I have a intel 478 board an don`t know how to connect power poer led
The power led wires ( there are two) go onto the two pins on the top row of the front panel coonetcor block on the board, on the 1st and 2nd pins working from left to right.
The full connector block is wired as follows:
top row: left to right >>
1st& 2nd are Power LED, the 3rd & 4th are the power switch, the 5th is empty.
The bottom row: left to right >>
1st & 2nd are hdd light, the 3rd & 4th are the reset switch, the 5th pin has no connector to the pin
Note: the power led and hdd terminals are to produce a light when the pc is on and busy.If the lights do not show, turn off the pc, turn the connectors round 180deg, reconnect and turn back on again. Job done
compdoctor2005@btinternet.com
Dec 10, 2008 | Computers & Internet
Canon pixma ip1000
I try this to my customer canon printer and it is working even i used only the step one method.
Here's the steps for reseting "Waste Ink Full" problem at iP1000
Step 1: Manual for Service mode (1st method)
1. Unplug POWER and USB cables.
2. Open door of the printer, PRESS and HOLD the POWER button.
3. Connect the POWER cable.
4. Close door, then release POWER button.
5. Power ON your printer a usual (It should not blinking anymore)
Step 1: Manual for Service mode (2nd method)
2. PRESS and HOLD the POWER button,
3. Release the the POWER button
4. Power ON your printer a usual (It should not blinking anymore)
Step 2 : Software for Permanant (1st method)
1. Reconnect the USB cable and turn ON your Printer
2. Open "General Tools for iP1000",
http://www.printersiam.com/data/download/iP1000%20Service%20Tool.zip
3. Select (USB PORT)
4. Choose (SET DESTINATION 1)
It should be reseted already, but somehow it start blinking again if you ever unpluging AC POWER cable. So try the 2nd method by using ServiceTool for IP1500
Step 2 : Software for Permanant (2nd method)
2. Open "General Tools for iP1500",
http://www.printersiam.com/data/download/iP1500%20Service%20Tool.zip
4. Choose CLEAR WASTE INK COUNTER - MAIN
5. Choose CLEAR WASTE INK COUNTER - PLATEN
It should be working, coz my printer now now work normally
Apr 23, 2008 | Canon PIXMA Photo Printer
Central vaccum
If the outlets work on the 2nd story ok, and not on the 1st floor, then you may have a wire that has come loose. There maybe a junction that split off between the 1st and 2nd floor. I assume you are talking about the suction and not the brush roll on the power head. If it is the power head not working, then check where the 2 prongs go into the outlets to make sure that the plug receptacle haven't gotten pushed in from the holder.
May 30, 2007 | Windsor SR12 Sensor Bagged Upright Vacuum
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
