Question about Pioneer DEH-P2500 CD Player
Short on Chasis
My stereo powers on and off frequently. Initially thought some Butt connectors were bad to the power. Replaced all connections going to 16 pin plug. Still shorting. The local shop tells me it is the female receptacle on the stereo chasis that is probably causing the short. Claims they see it all of the time on this model. How difficult is it to re-solder the chasis plug connectors? Any suggestions on how I go about doing it?
  • James Hirst Jul 31, 2007
    I used "almost there", because I hadn't completely solved my issue. The soldering was pretty easy to get too as long as you can prop open the stereo. I soldered all of the points, but to no avail. I am still getting a short somewhere. I am new to this chat room/blog so I am not certain about the meaning of responses. Your information was absolutely correct on how to resolve the problem I presented, but my stereo must be having some other issue. Sorry for the incomplete response before.
  • 883 Answers
Open unit to point of seeing the connector in question. turn pcb over to reveal the pins soldered to board. Simply using a hot solder iron and flux-core solder (and you properly grounded using wrist strap), proceed to re-solder each pin's solder joint. Additionally, to prevent this same broken solder joint problem again, use strong epoxy and apply to gaps between connector and pcb to prevent connector from "rocking" back and forth during cable installation.
Posted on Jul 29, 2007
  • Marty marty Jul 31, 2007
    ok, I submit a solution that I believe covers your problem and all I get is an "almost there"? What else can I say? How about "How difficult is it to re-solder the chassis plug connectors?...answer is: extremely difficult for a beginner and easy for an expert. next: "Any suggestions on how I go about doing it?" answer is..."open unit to point of seeing the connector in question. turn pcb over to reveal the pins soldered to board. Simply using a hot solder iron and flux-core solder (and you properly grounded using wrist strap), proceed to re-solder each pin's solder joint. Additionally, to prevent this same broken solder joint problem again, use strong epoxy and apply to gaps between connector and pcb to prevent connector from "rocking" back and forth during cable installation." There is not much more to cover here...this is an easy question answer session and I think almost there leaves me to believe I must supply more info...but what?
  • Marty marty Aug 09, 2007
    ok,
    when you said "Your information was absolutely correct on how to resolve the problem I presented"...can you then change the rating to SOLVED from "almost there"? I appreciate your honset response.
SOURCE:
Replaced stereo in 2004 Ford F-150: used a ford wiring harness with all wires connected correctly, but no power to stereo??
Check for a inline fuse, if no fuse is found, fit a power wire from the ignition switch to the power connection on the stereo via a inline fuse.
Oct 20, 2017 | Ford Cars & Trucks
Not getting power to fuel pump on a 1996 chevy pick up 4x4
Some fuel pumps come with a new harness and butt connectors to attach them. Peel back the loom close to the pump connection and check the connection if it has them. If it does have butt connectors remove them and solder the wires with heat shrink tubing. Keep in mind your close to the fuel tank.
Apr 18, 2014 | 1996 Chevrolet K1500
Buzzing sound in my car speaker after installing stereo with install kit
That is alternator noise install a 12 volt noise filter inline with the power to the deck.
Jun 28, 2017 | XO Vision XD103 FM and MP3 Stereo Receiver...
I need to know where the ground wire goes in the pinout connector for jensen mp5610
All car stereo's are internaly grounded, so just connect the ground wire to the stereo chasis.
Jul 12, 2011 | Jensen MP5610 CD Player
When I replaved samsung hls6767w lamp with hosing with new lamp with hosing I noticed burning smell.I assumed it is new lamp buring smell. After 15 mnts when smell did not go I removed power and when...
Most of the time the female end of the connector comes right of a part called the ballast. Ballast's are replacable. Is the aluminum melted? I am not sure where to purchase the ballast. The female connectors is ussally atached to frame with screws or sometimes clips
May 27, 2011 | Samsung HL-S6767W DLP TV
Stereo integrated amplifier a30, turns on some times
A few things to check:
- a bad power cord or connector to the unit on the cord (if any), bad power connector on the unit (if any) or bad connector soldering on the circuit board (replace cord or resolder/replace connector if necessary)
- main power switch could have dirty contacts or some damage (needs to be cleaned or replaced)
- an electrolytic filter capacitor (any of them) could be dried out, blown (bulged at the top), badly soldered or otherwise faulty (should be replaced if faulty and resoldered if there is a loose solder joint)
- a connector (any of them) could be loosely plugged, oxydized or have bad solder joints on any pins (connections should be checked, dirty contacts cleaned, loosely soldered pins resoldered)
- any other components could be poorly soldered or damaged (resolder or replace, as necessary - might require technical service to establish which components are bad, if any)
Note that the problem may be any of the above, a combination of any of the above or something entirely different, i'm just pointing to some possible causes/solutions.
Hope you can fix it.
regards
Triarcuate
Sep 21, 2009 | Audio Players & Recorders
I have a DEH-P7900BT. It was working very well for the last one year. But last week onwards I am facing a strange issue. The audio from the system go blank (mute) for few seconds and then come back. This...
I would check both of the power wires for the unit. There is a yellow one and a red one. The yellow one always has power regardless of the position of the ignition switch. The red one only gets power when the ignition switch is in the on position. Also does this only happen when the vehicle is in motion or does it happen just sitting and listening to the stereo? It also could possibly be the ground wire not getting a good connection. Make sure the ground wire is tightly connected to something that is metal. Good luck.
Jul 18, 2009 | Pioneer DEH-P7900BT CD Player
2002 Chrysler Town & Country - Driver Front Dash Speaker Buzzes
The first thing I would do is pull the stereo out of the dash and unplug it . If the buzzing stops the stereo is bad get a new stereo. Its not hard to remove the stereo. Right above the cup holder there is a small cover you need a very small screwdriver to remove it . Under that is a few screws take those out then grab the plastic cover that runs around the stereo and pull towards the back window it simply pops off (No screws) After you remove that cover you will see 4 phillips head screws that hold the stereo in remove them. Last slide out the stereo there will be 1 plug with alot of wires that is the power and speakers . Unplug it . The other round plug is the FM antenna
Mar 26, 2009 | 2002 Chrysler Town & Country
No Sound
check for a short. I experienced the same thing in my '86 F-250. Wires were replaced using a larger gauge, and crimped connectors with heat-shrink. Worked great.
Jan 18, 2009 | Jensen CD3720 CD Player
Pioneer DEH-P2500 CD Player Logo
73 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
