Question about Panasonic KX-T7630 Corded Phone
KX-T7600 series outgoing calls
Hi!
When somebody is calling a number outside our building, then he has to hit the No. 9 button first. How can I disable this?
  • Carl Navarro
    Carl Navarro May 11, 2010
    Why? What if they want to call someone INSIDE the building?
1. Press "PROG" (Program)
2. Press "1" and "9" (19)
3. Press "ENTER"
4. Select "Idle Line"
5. Press "ENTER"
6. Press "EXIT"
Posted on Apr 20, 2009
Line not assigned
make sure that your service provider has installed 3 individual lines into the building
check that the 3 incoming lines are not all together in the plug at the wall
you may need a telephone technician to check it out
Feb 17, 2016 | Panasonic Kx-tda100 Kx-tda100 Digital...
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    How to configure panasonic exchange Model KX-TEM 824 to work with telemanager call tracking software using telephone KX-T7730
    It's pretty straightforward. The DB-9 connector on the cabinet is turned on by default for incoming and outgoing calls, so all you have to do is connect your serial port to the Panasonic serial port at 9600,n,8,1 (default). In the Maintenance console, tab 1.7 adjusts the output. How you set up the software is part of the manufacturer's instructions. The Telemanager software on my search engine was designed for the NANP only.
    Carl
    Mar 01, 2011 | Panasonic KX-T7730 Corded Phone
    How do i customize a call button to a number?
    What number? You have 24 buttons. You can store inside numbers under a button by pressing PROGRAM the button and dial 1 + the extension number and ENTER or STORE.
    Outside numbers depend on what you dial to get an outside line (usually 9). In that case, press PROG button 9+your outside number and ENTER or STORE.
    Press EXIT to leave programming.
    Carl
    Sep 30, 2010 | Panasonic KX-T7630 Corded Phone
    KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
    If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
    From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
    1. Press PROGRAM * # followed by the system password ( default is 1234).
    2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
    3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
    4. Press AUTO DIAL / STORE to save your changes.
    5. Press PROGRAM to exit program mode and you are done.
    Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
    Hi, Expert Guy , I have some problem with Panasonic TDA100 about calling Out by co line i have 20 extension and 4 CO line , so when i need to call out , i press number 9 , it will switch to the line free ....
    To call out: Go off hook press an idle CO button-- Dial outside phone number. There is no need to dial "9".
    If you need a copy of the manual you can get one for free at the following link: HTTP://phone.manualsonline.com/manuals/mfg/panasonic/kx-t7630.html....Let me know if this answers your question. Master FixYa...
    saailer@att.net
    Dec 05, 2009 | Panasonic KX-T7630 Corded Phone
    Panasonic kx-t7030 FWD/DND button
    Outgonig calls and the FWD/DND button are not realted. Walk up to the phone and dial 790 on the intercom. That should reset everything.
    Now, try that calling out and see what it's doing. If you can dial "9" from the intercom and get an outside line, start dialing a number and see if it fails. Watch the display at all times. If it is still broken, post back.
    Carl
    Jun 23, 2009 | Panasonic KX-T7030 Corded Phone
    We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
    Panasonic KX t7730 call forwarding function to external party:
    If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
    If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
    lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
    Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
    Tel KX-T7330
    The system that the 7330 is connected to controls how you program it and how it behaves.
    In the U.S. and for only a short time, the 7330 phones were connected to a TA-624. In fact, those phones were called "Euro Style" so you may be in the U.K.
    I don't recall if they have a PROGRAM switch in the back or a PROGRAM button on the face, but they are programmed with PROGRAM press the button you want to program and read the display.
    In Panasonic, all C.O. lines are assigned with 0 plus the CO number 1-6 in a 624's case and STORE. So you can reprogram the buttons in top to bottom or bottom to top order with 01 STORE 02 STORE etc. In passing, all extensions are programmed with 1 plus the 3 digit extension number as in 1101, 1102,1103 etc.
    If the puttons are physically sticky, you can use alcohol and clean them, or just reassign them.
    I hope this helps :-)
    Carl
    Mar 15, 2009 | Lands Phones
    Several line can not make out call
    You may not be progammed for outside call on those lines or they may be Centrex lines which require a "9" to be dialed first.
    Dec 25, 2007 | Panasonic KX-T7630 Corded Phone
    Panasonic KX-T7630 Corded Phone Logo
    119 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
