Question about Coleman Powermate Premium Plus 6250W Portable Generator
I hv a colemanpowermate 5000/6250w generator- won't stay running
I have added stabelizer to the gas. it will start and run 30 to 45 min and then hesitate and then kick back in after several seconds and then repeat this a couple of times and finally after hesitation it will not kick back it and cease to run. I will wait 30 min to restart and after 30 to 45 min the process reoccurs. I have replaced the gas, still happens. the generator is 5 years old but only has about 120 hours on it. Do I have a sparkplug problem and how do i fix?, or do I hv another kind of shut down issue.? How do I resolve? Please advise
  • 257 Answers
Hi, Please understand that this type of troubleshooting is hard without seeing it but doesn't sound like a fuel issue at all. This genset does have other sensors that will shut it down like low oil and high temperature. Most likely oil from your description. You also don't say what load it is carrying, could you be plugged into something that cycles off and on and when it cycles on the genset shuts down from the overload? If you think this might be the case, disconnect everything and power up a few at a time especially things that cycle on and off like refrigerators, heaters, stoves. Good Luck!
Posted on Jan 30, 2009
  • Jim London
    Jim London Feb 04, 2009
    Hi, I hope I solved your problem, Please rate my response, your
    favorable ratings help others that may have the same or similar
    problem. Thank you!
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
Nov 09, 2013 | Poulan WEEDEATER FEATHER LITE 1500 GAS...
Craftsman 5600 watt generator won't stay on and white smoke pours out when started.
try running it with nothing hooked up if it runs fine, then the power draw is to much for it that would cause it to hunt !!!
Jan 30, 2013 | Craftsman 5600 watt Generator
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
My three wheeler doesn't stay running when it starts. What could be the problem besides the fuel line . just added a fuel filter on it but she still won't start or stay running at times. Co
The damage is already done before you put the fuel filter in. (dirt in Carb)
Remove your carb and dissesemble it and clean everything out and then put back on the machine with FRESH gas and you will be fine...run like a top !
Jul 06, 2012 | Cars & Trucks
Unit will start at full choke but will not stay running with choke off,will load up on full choke and stay running around 3/4 choke
HI,
Turn off the gas and take the bowl off the carburetor.Look for water bubbles in the gas that spills away. Water will float like little balls on gas. If so drain gas tank put in new gas with some HEET added. While you have the bowl off spray up and around the bottom of the now exposed carburetor.
Pay attention to spray up the small copper tube in the center of the carb.
Clean out bowl and put it back on. Turn on your gas. Look for leaks around the replaced bowl. Good luck.
Jan 29, 2010 | Coleman Powermate Powermate 5000W...
Generator Starts But wont stay running after a few mins.
check the oil level most products like this have a safety valve.
Jul 15, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
387 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
