Question about Sony PlayStation 2 (PS2) Console
Ps2 usb doesnt work
My ps2 USB won't work, please help.
    Scholar:
  • 118 Answers
Well the reason your USB won't work is probably from it being old. For most games that use USB run off of a program called FAT32. You need a new USB Flash, I recommend getting a new SanDisk a wal-mart for about 10-40 bucks. Those have FAT32.
Posted on Jan 30, 2009
Change ps2 usb kable.
How do I connect the mouse?
212
i am assuming you have a usb mouse and a PS2 connection on the computer. If this is the case then you need a female usb to ps2 mouse adapter
So that the mouse cable plugs into the USB female connection and the male ps/2 plug end goes int othe female ps2 port on the computer.
If this is the case you have the wrong converter the chester will convert a ps/2 on the mouse or keyboard to a usb on the back of the computer.. Can you tell us what sort of mouse you are trying to connect does the end of the cable have a usb plug on it a bit like the blue usb plug in your picture.
Google it and see the difference.
Mar 12, 2015 | Chester Creek PS/2-USB Converter PS/2 to...
Hi guys ... I'm having a problem that's got me pulling my bloody hair out, and I've got absolutely no idea how to solve it. I've got a box with a blank drive in it [so no existing OS...
if you were flasing the bios and it was interrupted you might be **** out of luck if the bios was compltedly erased. the only thing you can do is try flashing the bios again , make sure it is compatible
Jul 06, 2011 | Dell Dimension C521 PC Desktop
My tower takes for ever to load and it wont read my mouse or my keyboard so my keyboard doesnt work please give me some help
Loading problems are usually due to a hard drive that is almost full, leaving windows with no "swap file" (or virtual ram). It can also be down to a very badly fragmented hard drive.
The mouse and keyboard problem ( I;m assuming you are using a Ps2 mouse and keyboard) point to a failed connector on the back panel. Try using a USB mouse and keyboard, (if you are using one already and this model supports ps2, try the other way)
If the USB ports on the computer do not work, to use a keyboard or mouse, then the problem is more serious and you may have a damaged motherboard
Jun 19, 2011 | E-Machines T2682 (000002965) PC Desktop
I have a dell inspiron desktop that has no ps2 port, only USB. From my older computer I would like to use my microsoft ergonomic keyboard that has a ps2 plug. I bought a PS2 to USB adapter but when I...
The adapter you purchased is for use with a PS/2 mouse only. The only keyboard adapters will have keyboard and mouse in a "Y" adapter. The single adapters will not work for keyboards because they do not have the conversion electronics to go from PS/2 to USB, mice can work on either one. Do a google search for "usb to PS2 dual port adapter" you can get them for around $2 plus shipping.
I hope this helps, if so please rate our solution.
BuddyMc
Dec 23, 2010 | Computers & Internet
Laser doesnt work
Check the mouse cord and make sure that it is properly connected to the PS2 port of you computer. Turn off your computer, wait for a few seconds and then power it on. If it failed to function properly, contact the store where you bought it about the problem. The device is cover by its' warranty and they may replace it if found defected.
Hope this could help you..:-) Thanks..
Dec 27, 2009 | Genius Mouse, OEM Net Scroll PS2...
Mouse works fine but cant get keyboard to sync
Might be a defective keyboard. Check and make sure its compatible for windows vista but all keyboards should work with any system.. As well maybe the port on the computer is bad..
Jul 26, 2009 | Sakar 62150 Keyboard
Trying to install windows and at the boot screen have my keyboard and mouse plugged in windows doesnt see it.. I tried the USB keyboard and nothing I just recently replaced the MOBO using anti-static wrist...
I have seen this before, and the best answer I can offer you is some Motherboards are better than others when working with usb devices while no OS is in place. I actually tried using usb / to / ps/2 adapters and it still would not recognize the usb keyboard in a couple of instances. I had to get a ps2 keyboard for the installation of windows. After windows was installed I hooked up the usb keyboard and it worked fine. (just speaking from my own personal experience here)
Sorry I do not have a more technical answer for you but I'm almost 99.9 % sure this should work, providing there is no problem with the ps2 keyboard port on the Motherboard. I have never failed to install windows unless there was another hardware based issue of some kind, but never a problem with a known good ps2 keyboard.
Just double check everything is seated properly and try to get into the bios setup, if you cannot use the usb keyboard for this, you can try the usb / ps2 adapter, but if that doesn't work either then use a regular ps2 keyboard. That should work fine, then after setup is complete, windows is installed, then your usb keyboard should work fine.
Mar 03, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
USB to Ps2 keyboard adapter
i think your usb to ps2 connector is faulty.
change it and try again
Apr 01, 2008 | Computers & Internet
Sony PlayStation 2 (PS2) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
