Question about Toshiba D-R2 DVD Recorder
Problem with DVD-RW's
When I insert a brand new DVD-RW, I get an error message that the disk may need to be cleaned or may be damaged. The recorder used to work fine, then would record but not re-record, now it won't even recognize new disks.
I had a very similar problem with my Toshiba D-R2. I found two firmware updates on the Toshiba website. One was called 1314.iso and the other was called 1416.iso. All the instructions are there for how to burn a CD and install it on your DVD recorder. It solved my problems - hope it works for you.
Posted on Dec 12, 2007
When i insert a blank disk i get cannot format disk message
sorry that you getting this message......... but the ch-dvd 300 is not a recording machine........it only plays recorded DVDs
May 08, 2011 | Cyberhome CH-DVD 300 DVD Player
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
Record errors
If your dvd player only supports dvd+r discs then that is the only way it will record. It will only record once onto the dvd-rw and, since it doesn't support the re-writables, it won't be able to use this function. This is the most likely reason for the first error. The second problem is a little confusing. Is it when you are trying to record on dvd-rs or dvd-rws that it says it can't record? I hope this post was helpful (for the first error, anyway). Good luck! I hope everything works out! Sincerely, Der Strom
Apr 06, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Error message e4 54040990
It may mean that the disk is no longer usable due to scratches or other over-use reasons. If a new disk, it may mean you're using the wrong brand. This machine works on recommended brands, and the brand of DVD+RW that has proven to be workable on this device, and that I use with no problems, is VERBATIM. Hope this helps you solve what's wrong.
Mar 22, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Won't format new DVD-RW disks
i did everyting today to fix this. bought new dvds, name brands different, tried finding codes, called the number. trust me. try this. clean it. thats All i did. cleaned it with a dvd cd cleaning disc, the one with two little brushes on it, nothing special, ran it until i heard the beep, popped my dvd in, they all worked. everyone, im still recording. i ran it about four times. now, if you tried to burn a dvd, and got the error, throw that dvd away. because i tried about ten dvds. after i fixed it, THOSE dvds were no longer usable. dont know why. hope this works.
Sep 18, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
DVD will not load/format new disk
I have got exactly the same problem. Thought I had found some discs that worked as the first one formatted, since then all have come up with that crappy error protection message. Samsung really should sort this out.
Mar 25, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
Sylvania dvr90vf dvd recorder
Unfortunately without a firmware upgrade the only disks you can use are DVD-R or DVD-RW. The tricky part is that you can ONLY USE 2X speed. Per my conversation with Sylvania there is a firmware update that will allow you to use up to 8x disks, but they are charging $17.00 for it.
Feb 12, 2008 | Sylvania DVR90VE DVD Recorder/VCR
Toshiba D-R2 DVD Recorder Logo
205 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
