Question about Elna 2007 Mechanical Sewing Machine
Elna TSP button hole sequence
Have owned SU and SD models.Have tried same sequence but no luck
  • 11 Answers
SOURCE: Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Posted on Oct 28, 2008
SOURCE: have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Posted on Apr 09, 2009
Sewtech1
  • 69 Answers
SOURCE: elna su motor won't turn off
it is only your Capasitor that is faulty and can be by passed
Posted on May 01, 2009
Tally Girl
  • 1133 Answers
SOURCE: I have a old Elna
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Posted on Mar 07, 2011
Tally Girl
  • 1133 Answers
SOURCE: how to thread bobbin on Elna SU
if you go to this solution
http://www.fixya.com/support/t1064475-elna_carine_electronic_sewing_machine
you'll see the threading diagram for an Elna SU, threading up is same on all the air electronic Elnas (the SU, TSP, 500, Jubilee and Carinas).
If clicking on the link doesn't work, then just select the text, control C to copy, the paste it into your browser address bar.
Trust this helps.
Posted on Oct 02, 2011
I need an Air foot control # 436310-20 for my Elna Stella TSP air electronic. How and where I can get this part?
I'd suggest www.sewingpartsonline.com if you are in USA.
https://www.sewingpartsonline.com/air-foot-control-elna-436410-20.aspx
Or you could try the Elna Guru, White Sewing Center www.whitesewingcenter.com, he's the specialist supplier for all things Swiss Elna.
The air control foot is the same for all the Elna Air Electronics, whether Stella, SU, TSP, TX etc.
Mar 20, 2017 | Elna Sewing Machines
How do i get manual for Elna TSP 770/12095052
You can see it at http://sewingonline.co.uk/instructions/elnatsp1/
and http://sewingonline.co.uk/instructions/elnatsp2/
You can also buy it at http://www.sewingmanuals.com/Sewing_Machine_Manuals/Elna.htm for $10 a section.
Nov 27, 2014 | Elna Sewing Machines
I have an Elna Elnita air electronic and cannot figure out how to backstitch. I have always owned Elna Su air electronics but this little machine I can't figure out the backstitch
Unless there is a specific button to do reverse stitching, you could try pressing the foot peddle 'backwards' .. in other words, press with your heel rather than your toe. Some foot peddles are configured this way.
Apr 09, 2014 | Elna Sewing Machines
How do i disengage the feeddog on my elna tsp machine
If this is a lotus TSP then you can't disengage the feed dogs, but your machine was sold with a little square metal plate that clips onto needle plate covering the feed dogs. If you dont have it in the accessories then you may be able to buy it from an Elna dealer or Ebay. If you are in USA try Ray White of White Sweing Center, he is renouned for Swiss Elna spares
Mar 17, 2013 | Elna Sewing Machines
Buttonhole function
Bar tack
left side
bar tack
right side
Jul 10, 2012 | Elna Sewing Machines
I have an elna airelectronic tsp machine & cannot thread bobbin. Please help
Firstly, have you got an Elna metal bobbin? it should be solid on the bottom and have 7 holes on top. It is essential that you always use it this way, wind it with the holes on top and load it into the bobbin holder the same way.
Have a look at the image above, you need to load the bobbin in and click the thread into the tension spring so it doesn't lift back out when you pull the thread upwards. There should be an audible click as it goes in.
If you can't get it right or this image is just too small, feel free to email me and I'll send you the image and talk you through it, I have a TSP machine too. cwrogers@tpg.com.au.
Also, check my tip on bobbin winding here http://www.fixya.com/support/r10598580-winding_bobbin_correctly it is important to get a good even tension onto your bobbin as you wind the thread on, you may need to manually add some tension to the thread as it winds off the spool, as I've described in my tip. I sold these machines for Elna and customers would bring them in complaining of problems with their machine. Almost aways, it was the needle in backwards, bobbin upside down, thread/lint buildup in the bobbin race or badly wound bobbin that was the problem.
Hope this helps you Gaylene, but if not, please email, I may be able to send you the relevant manual pages.
Apr 20, 2012 | Elna Sewing Machines
How do you put a bobbin in a elna so i can use it to sew
Drop in a full bobbin with the holes side upwards (I'm assuming this is a Swiss Elna sewing Machine horizontal bobbin design as you haven't given the model number).
Now, hold the thread tail with your right hand and pulll the thread clockwise towards you while holding the bobbin still with a finger from your left hand. Bring the thread tail around towards you until it goes into the little slot, then press downwards onto the thread tail close to the bobbin until you hear it click into the tension spring. Test by lifting the thread tail upwards, it should stay in tension and not come back out of the groove.
Now close the back slide cover over the bobbin leaving the bobbin thread tail visible out to the right.
Now manually turn the flywheel towards you while holding the top thread tail and take the needle down into the bobbin holder area and back to the top, pull the thread tail to bring the bobbin thread up to the top.
There is a threading up diagrams at www.sewusa.com http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_Supermatic_threading_diagram.htm
for the old Supermatic but the bobbin holder design is almost identical for all the subsequent models such as the SU, TSP, Supermatic or Air Electronics like the Stella, Carina or Jubilee, the above is the same for all.
Sep 19, 2011 | Elna Sewing Machines
Need repair manual for elna tsp. or info to repair tension mechanism
I would suggest that you join the Yahoo newsgroup called "Elna Heirlooms" then check out their "Files", one of the members may have this item scanned there for members to refer to. If not, there are some really experienced members too who may be able to help you with information on how to do this repair. But you'll need to specify which TSP, Elna made a TSP in the Star Series, and Stella air electronic and the bill air electronics too. Your side panel will have the model 2 digit number so just include that when you ask for help on Yahoo.
Aug 19, 2011 | Elna 2007 Mechanical Sewing Machine
I have a Elna SU - new in the mid-70's and recently took it to an auth. repair place. The needle position wheel is very stiff - almost impossible to move. It is used mainly in conjunction w/the...
I was going to direct you to the www.arizonaexpressionz.com website which had lots of Elna instruction and service manuals including the SU but today its links seem to be out of action. It may come back to life so worth checking another time.
In the meantime, did your repair shop actually service the machine or just pull the top cover off, put in oil and tell you that's it. There are still Elna trained technicians out there who are familiar with the older Swiss made machines and its probably worth trying to find one if you think the service centre you've visited hasn't actually addressed the issue.
The other option is if you are in the USA, contacting White Sewing Centre and maybe sending it to them to be serviced. LInk is www.whitesewingcenter.com.
Or if you are technically minded yourself, you could join the "Elna Heirloom" group on Yahoo and then ask the other members there for help, there are lots of Elna lovers with models much older than the SU there who lovingly keep their machines running and share their knowledge. Just be clear as to whether yours is a Star Series SU (white with blue top) or Air Electronic SU (if you look on the id plate of the machine there will be a 2 digit code either 62 or 68.
I hope this helps you a little, I'd certainly persist with it if I was you. I just purchased my second SU 2nd hand after buying a new model of another brand 5 years ago and being quite disappointed with its performance, particularly with heavy jobs.
Aug 07, 2011 | Elna Sewing Machines
How to thread bobbin on Elna SU
Please describe the type of bobbin you have. Is it held inside of a removable metal casing? Or is it a dropin type? Is the sewing machine what is known as a "freearm" which you can put a sleeve or trouserleg over or is it a flatbed type? When I know this I can help you further.(I used to sell sewing machines).
Jun 11, 2009 | Elna Sewing Machines
Elna 2007 Mechanical Sewing Machine Logo
240 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
