Question about Intel DG31PR Motherboard
DG31PR Problem with extender usb 2.0 in cascade
When i cascade extender usb 2.0 (5mt), the two and next extender is not detected. I have 3 extenders and that work wery well on asus mother board. When i plug the extender on Intel DG31PR, the first work, but not when i chain a two.
All of the tree extender work when i put directly in the mother board, but not in cascade.
  • 1,602 Answers
Go into the control panal and looking in the following folders;
device manager, adding new hardware, network and sharing folder,
problems and report.
look trew the sections that apply
looking for any type of marks that should not be there
red, yellow, orange,
green mark okay
Posted on Feb 05, 2009
Trying to setup my netgear wifi range extender
If you look on the back of the unit, it should have in small print, the access IP address, the admin name and admin password. If you have changed it in the past, then reset it back to the default. Typically netgear use, admin name of admin, and the password is either password or netgear1. Older units may use 1234. The only exceptions are newer extenders that ask you to put in a password when you set it up, in which can you will need to reset it to the defaults and do a new setup.
Jun 16, 2016 | Uniden exi4560 2.4ghz extended range...
Sim 3 into the future installation
What causes Extended Attributes Are Inconsistent Error Message error? The Extended Attributes Are Inconsistent Error Message error may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
There can be many events which may have resulted in the system files errors. An incomplete installation, an incomplete uninstall, improper deletion of applications or hardware. It can also be caused if your computer is recovered from a virus or adware/spyware attack or by an improper shutdown of the computer. All the above actives may result in the deletion or corruption of the entries in the windows system files. This corrupted system file will lead to the missing and wrongly linked information and files needed for the proper working of the application.
How to easily fix Extended Attributes Are Inconsistent Error Message error?
There are two (2) ways to fix Extended Attributes Are Inconsistent Error Message Error:
Advanced Computer User Solution (manual update):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (Extended Attributes Are Inconsistent Error Message ) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Jan 20, 2014 | Computers & Internet
Seagate's DiscWizard, Extended Capacity Manager didn't recognize a hard disc with MBR partition style larger than 2TB when trying to maximize the capacity of the 3TB Seagate ST32000641AS drive...
Seagate Extended Capacity Manager
Seagate Extended Capacity Manager lets your operating system support large size discs with MBR partition style, so then you are able to use the space beyond 2 TB: this free space will be recognized as a separate disc, and will be accessible by your operating systems and applications as if it was a regular physical hard disc.
Seagate Extended Capacity Manager wizard will display all hard discs larger than 2 TB (unallocated or with MBR partition style). You can see, which disc space is recognized and allocated by Windows - this space is called Native Capacity in the wizard.
The space beyond 2 TB is displayed as Extended Capacity Zone. You can enable Extended Capacity Discs, and once it is done, this space will be visible by the operating system and ready for disc management operations.
Click Allocate space to see the possible disc space allocation in the next step.
After clicking Apply changes now button, the Extended Capacity Discs will be emulated on your physical disc. In case your physical disc is larger than 4 TB and the host operating system does not support a GPT partition layout, there will be several Extended Capacity Discs.
Note these Extended Capacity Discs are not bootable, and most properties will be the same as a physical disc's.
After allocating the space, you may temporary switch off Extended Capacity Discs by clicking the corresponding option. This will make Extended Capacity Discs invisible for Windows Disc Management tools, though the disc space will remain allocated.
To disable Extended Capacity Discs, click Remove partitions from Extended Capacity Zone and then click Apply changes now button in the next step: these discs will be removed from your system, and as a result - the disc space beyond 2 TB will become inaccessible
Sep 15, 2011 | Seagate Technology Barracuda Xt...
I recently installed CAT6 cable to run between my computer and main stereo. The run is 50' so I also purchased a USB extender. My issue is that once I hook the network up to my computer, it can no...
Yes- don't use USB as an extender- Network spec for Cat 6 without a repeater ranges from about 165 feet to 75... You should be able to run the cable straight through.
Jun 15, 2011 | IOGear USB Booster Cable G2LUB16 USB...
How to get the warranty status
It depends on how long your warranty is. Most manufacturers give a one year warranty. You may have also purchased 2, or 3 year extended warranty. If you still have your receipt you can tally up how many years have passed since you purchased the motherboard. If not, you can contact your manufacture and supply them with the serial number, or which ever information the ask for, and they should be able to tell you the status.
Mar 28, 2011 | Intel DG31PR Motherboard
Leupold Windriver Cascade 10x42 eyepiece jammed
Sounds like one of the eyepiece screws underneath the eyecup has come loose. The rotating eyecup is threaded underneath so it can rotate into up or down position on the eyepiece. If this is the case your Cascades are under warranty and it sounds like you should send them to Leupold to examine them. They are a very reputable company and I doubt they would put it down to user misuse if that isn't the case. Bear in mind that if you have been using them in the field and have had muck on them a small foreign object may have worked its way into the eyecup thread.
May 16, 2009 | Leupold CASCADES 10X42 CAMO
WD My Passport Essential 250GB USB2.0 is not working in WIn 98SE
Try using a Usb 2 cable "The one that came with the WD My Passport " And put it directly to the PC...
In some cases, Like mine, I used an extended cable + the cable that came with the "WD My Passport" and i got the same problem ..
So i simply removed the extended cable and put the put "WD My Passport " directly to the PC with its own cable and the problem was solved to me ..
Dec 26, 2008 | Western Digital WD Passport 250GB Portable...
Intel DG31PR Motherboard Logo
127 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
