Question about Symbol LS2208 Handheld
I have this situations: my system don't read any code begining with 0, please need this configuration for symbol LS2208. Thank you.
Your scanner must have been delivered with a "Quick Start Guide".
All you need to do is to scan the following barcodes from thar Guide:
1.Set Defaults
2. Scan Options
5.The barecode for whatever type of connection you use (RS232, Keyboard, etc.)
Posted on Feb 04, 2009
I can't set to read a barcode 128 with symbol ls2208. I have scanned the "enabled barcadeo 128" on the manual but nothing happends... please help
Sometimes it can be something as simple as scanning another code and retrying. Don't forget to scan the save command.
Jul 06, 2011 | Symbol LS2208 Handheld
Hi my name is christian canola and i purchased a symbol ls2208 barcode scanner from geminicomputers and i downloaded the program 123 scan2 for my barcode scanner and i click on my scanner is connected via...
Hi Christian, if your scanner was manufactured before February 2010 it may not be able to communicate directly with 123Scan2 so you wont be able to upgrade firmware with the program, but you will still be able to use it to create configuration sheets. These are the only two uses for 123Scan2.
To create a configuration sheet without "finding" the scanner click Create New Configuration then choose My scanner is NOT connected. Select the LS2208 and click on the blue firmware button to get into the configuration. When you have completed your configuration click the Print bar codes selection at the top of the window and when the file comes up be sure to click on the Bar code formatting menu and change the Bar code type to 1D One setting per barcode if it is not already there. Older scanners will not work with concatenated 1D barcodes where 123Scan2 puts more than one setting into a barcode.
Feb 12, 2011 | Symbol LS2208 Handheld
Can i make my ls2208 read ean 13+5?
Hello, here is the link for the ls2208 product reference guide, in this it will walk you through the symbologies and how to scan them
if you need additional information please let me know
Kim Ganoe 800.933.2839
Mar 22, 2010 | Symbol Hotshot LS2106 Handheld
When we scan it will read factories bar codes but no other bar codes does anyone know how to fix this problem?
What software are you using with the scanners as it can be configured to only read codses beginning in a certain number
Aug 07, 2009 | Symbol LS2208 Handheld
Create a barcode for F1 and F2 using Labelview
If you have created your barcodes as "F1" and "F2" you will have to create two Advanced Data Formatting rules with the LS2208 Product Reference Guide. This link will take you to the manual. Print only the barcodes you need from the list below then scan them in the order they are listed:
Begin New Rule
Specific String at Start
F (from the Alpha-numeric section of manual)
1 (from the Alpha-numeric section of manual)
End of message (from the Alpha-numeric section of manual)
Send F1 Key
Save Rule
Begin New Rule
End of Message
Send F2
Save Rule
That should do it!
May 06, 2009 | Symbol LS2208 Handheld
Reading codebars
A solution to your problem would be to use usb cable to connect the scanner to the POS system. I have had a similar issue in the past where the IBM pos system did not like the cable that the customer had and we've got around this by using usb instead.
I hope this helps you although it may not be the kind of answer that you were looking for,
Mar 24, 2009 | Symbol LS2208 Handheld
Barcode scanner Symbol LS2208
I had the same problem with LS4278, you need to configurate your keyboard and scanner in the same regional and language options
Oct 20, 2008 | Symbol LS2208 Handheld
Symbol LS2208 Handheld Logo
263 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
