Question about Nakamichi SoundSpace 9 CD Shelf System
Error e-20. Doesn´t Work anything related to the Cd Players.
E-20 (error 20) appears on the display every time I try to play a cd. It won´t eject either... Nor does the illumination work... Now that Nakamichi Support is dead I depend on you... Please!!!
  • Anonymous Mar 06, 2008
    New Friend:
I am having the same problem it turns on , but display light does not come on, and cd mode shows error 20 have try to unplug and restart but still nothing, radio plays ? please anyone! help me!
Posted on Jun 10, 2016
    New Friend:
Have you had any success with this question anywhere as I have the same problem
Posted on Mar 08, 2015
The system may need to reset. Unplugged the amp from the power source completely and let it rest for at least 5 minutes.
The illumination can only be controlled from the main remote. Adjust the prongs inside the remote and this should fix the issue.
Posted on Mar 23, 2009
U70 error message on cd player
U70 error message on cd player - Fixya
www.fixya.com/support/t12308553-u70_error_message_cd_player
Apr 5, 2012 - U70 error message on cd player Cd player doesn't work at all. Displays 0 track, 0:00 (min,sec). The play - Technics CD Players question.
Technics error code f 70 CD Players Questions & Answers ...
www.fixya.com > Forum > Tags > error code f 70 > CD Players
Technics cd players error code f 70 related questions and answers. ... won't play cds changer turns on ok, reads error message I have the same problem.
Apr 05, 2012 | Technics Audio Players & Recorders
Cd in02 lincoln ls light comes on ( cd error ) wont work or eject ??
This can be from a couple things that caused this. Most the time and 99% of the time that causes this is the cd driver is dirty, which some times it just spits it out after error message comes on. AND in your case, it is staying in there spinning and reading error, and won't eject. One way that is possible to have this kick out is, to unhook battery, wait 5 minutes, and re- hook battery up, and sometimes it will trigger it to eject. If not, you do not want to start forcing something in there, it could cause more damage. You would then, i suggest , take it to car stereo shop as they have all kinds of methods to check it out and eject cd and figure out the fix method. Which could be as simple as a good cleaning, or cd itself was bad, or mechanism is screwed up.
I hope this helps Mike.
Oct 23, 2011 | 2002 Lincoln LS
I have a RDS stereo and it won't play my cd's. It says player error
RESET YOUR PLAYER AT DEFAULT SETTINGS. SWITCH IT OFF. SWITCH IT ON AND INSERT CD. GIVE THE PLAYER TIME TO READ. DON'T PRESS ANY BUTTONS TILL IT COMPLETE IT'S READING. IT WILL PLAY THE CD.
ALSO CHECK CD'S ARE BRANDED AND NOT COPY FROM COMPUTER. FEW COMPUTER WRITE CD NOT HAVE AUTO PLAY OPTION.
IF PROBLEM NOT SOLVE PLEASE INTIMATE.
Oct 07, 2011 | 2002 Buick Rendezvous
My 2005 Chevy Malibu's 6 CD changer will not play CD's, and will not eject them either. When I press the eject button it appears to try and eject as I hear movement but after a short bit of clicks I get a...
Extreme heat can cause warping and the cd will not evenly eject or exit the slot. the player may have to be removed and the cd physically extracted from the player. Delco players have a lot of plastic cogs, flywheels and gears in them that get old and crack or split. Hence, the player can no longer spit out the CD.
Jul 26, 2017 | 2005 Chevrolet Malibu
Hi what does Error 03 mean?
My endeavor has done this error 3 a couple of times and the cd changer basically shuts off all lights and won't do anything. Someone on another solution page said to slide a credit card back and forth in the cd opening to fix the problem. I've done this both times and it has made the changer play again as if nothing had happened : )
Nov 14, 2009 | 2004 Mitsubishi Endeavor
E20 error code
E20  error is a problem with the focus on the CD reader.
If the error only occurs on one CD then it's most likely a problem with a smudge or scratch on that CD and not the CD player  lens .
Try cleaning the CD thoroughly with iso-propyl alcohol
Nov 06, 2009 | Car Audio & Video
I have a Tascam CD-01u CD player that has a CD that will not eject. It will play the CD, but only clicks a lot and displays "Error 2" wihen I attempt to eject it with the remote and/or the machine's face...
I have a Tascam CD-1u Professional that load's the CD and say nodisc once it is done loading. this unit dosen't seem to be reading the CD what is the problem
Oct 16, 2009 | Tascam CD-01U CD Player
Ford 6006e cd changer with e 3 error keeps happening
The only way to do it is to remove the radio using DIN radio removal tool - then you will have easy acces to remove cd's if you do not have this tools try to use coat hanger (do small catss on the ends)
(you can try to hold eject button and swich off - swich on button - probably it will not work but try few times
Good luck,
Kamil
May 11, 2009 | Car Audio & Video
Kicking out disc "error 3" displayed
is it a burned cd? cause some cd players dont play burned ones. let me know if this helps
May 07, 2009 | Car Audio & Video
Doesn t reading the cd
hey,
also mention how old are ur CDJ and does it play original cds. Did you get any error code.
thx
djajay
Jan 23, 2009 | Pioneer CDJ-1000 CD Player
Nakamichi SoundSpace 9 CD Shelf System Logo
743 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
