Question about Trekstor i.Beat MP3 Player
The ipod doesn't turn on
One day I pressed the button on my ibeat pink (just like always) and it didn't turn on. The computer doesn't recognize it, but I can see on the display of the ipod that it is charging. What should i do?
  • Anonymous May 10, 2009
    when ever I try to charge my Ibeat pink it does not work
I think u have formatted it using any other file system like in Linux or MACOS
just format it using windows FAT file system and it will go
if it is not detected on your PC then it might have got corrupted so in this case just give it back to the shop retailer he will get it replaced for you
regards,
hussaini
Posted on Jan 30, 2009
Screen shows usb and Itunes but computer doesnt recognize ipod.
1. Verify if your pc passes the system requirements.
(a) usb 2.0 port
(b) You are running the latest version of itunes
2. Recharge your iPod Touch
3. Check USB connections. Use a USB port that is built into the computer instead of using an external usb hub.
4. Restart iPod Touch. Do the following steps: To restart iPod touch, first turn iPod touch off by pressing and holding the Sleep/Wake button until a red slider appears. Slide your finger across the slider and iPod touch will turn off after a few moments.
Next, turn iPod touch on by pressing and holding the Sleep/Wake button until the Apple logo appears.
Is iPod touch not responding? To reset iPod touch, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds, until the Apple logo appears.
5. Restart your computer then reconnect your iPod Touch
6. Try reinstalling iTunes. And if this doesn't resolve the issue, you can also try uninstalling iTunes then reinstalling the latest version.
7. Check if there are third-party software that might prevent iTunes from recognizing your iPod touch. Such software may be security software, anti-virus software and webcam drivers. What you can do is adjust the software settings or you may also temporarily disable the software.
If you find this helpful, kindly click the thumbs up button. Thanks! :)
May 23, 2011 | Apple iPod touch
My ipod doesnt want to read in my computer as soon as i dowloaded itunes. I'm running windows operating system but I didn't seem to have problems until now. I can't access the usb driver. My...
Try restarting the iPod and connect it again. If it doesn't recognize it try it on another PC, if it still isn't detected it is the iPod. Buying a Mac wouldn't help nor hurt the situation, it would just be an expenditure.
May 23, 2011 | Computers & Internet
My 2g ipod touch is bricked on the apple screen and i dont know what to do
Your ipod can go into paper weight or brick mode after dropping it or exposing it to moisture ie. water. Look down the headphone jack with a flash light and see if the little rectangular water sensor is white or pink. White means that your good and pink means the water sensor has been triggered and the unit has been exposed to excessive moisture. Here's the kicker- Apple's 1 year warranty does not cover water damage so your fu.kd. But if your still within your year warranty or you got an extended warranty, then just take the thing back to the Apple store and exchange it out if the water sensor is not pink.
Oct 03, 2010 | Apple iPod touch
Ihome--ih8,
I got the iH8 as a present everything works fine except for the ipod alarm. the unit will play my music when i press the play ipod button, and recognizes its plugged in, but when i set the ipod alarm, without taking out the ipod or anything, it doesnt go off with my music, it just buzzes. Idont think it is the ipod because i have updated the software on the ipod and have even tried 3 different ipods with the iH8. i have had the iH8 for about 2 weeks and set it nearly every day, and out of all those times it has gone off with my music only 3 times. How do i get it to work every time!??
Jul 08, 2010 | iHome Ih8 Dual Alarm Clock Radio For Ipod...
Failed to eject before rebooting computer, now USB port says it doesnt recognize the ipod and my ipod is frozen on "Connected-eject before disconnecting"
Actually this issue shouldn't really be that difficult to resolve. :) A simple reset should take care of it being frozen on the connected screen. Below I have posted a step by step on resetting an iPod.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
As soon as you see the apple icon appear disconnect the iPod from your computer. After the iPod completely loads. reconnect it to make sure it is connecting and loading correctly. If this does not resolve your issue for any reason please do let me know. I have a few other options we could attempt. :) and the feed back is always good. It lets me know if I am actually helping people with they're issue's or not.
May 16, 2009 | Apple iPod nano
My Ipod is frozen
Press and hold the home button and the power button for 20 seconds.
Apr 23, 2017 | Apple iPod nano
My computer doesn`t recognize my ipod?
Hi, try these steps
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
Feb 02, 2009 | Apple iPod nano
My ibeat pink ipod doesn't turn on
I'm afraid I won't be able to help you much with this one. There is no recovery software for this player, no firmware updates, and no technical info from the company's website. The Trekstor website, does, however, have an e-mail request form where you can ask for help via e-mail:
http://www.trekstor.us/en/products/detail_mp3.php?pid=69&page=7
-Tha Mp3 Doctor
Jan 30, 2009 | Trekstor i.Beat MP3 Player
My Ipod is frozen
hi there did you try to reset the iPod by holding the MENU and center button?
to do that first lock the itune then press and Hold MENU and Center Button by 7sec. then apple loge appears means the ipod had been reset. ok!
peace!
Dec 15, 2007 | Apple iPod MA446LL/A MP3 Player
Doesn't reocognize songs and Ipod
Try booting it into disk mode. Do this by clicking on the menu and center buttons at the same time. When you see the apple logo, immediatley hold the centerbutton and play button down at the same time for 10 seconds. The ipod should now say disk mode at the bottom and have a check mark on the screen.
Then connect it to your computer, and format it using your computer. To do that click on my computer, then right click on the drive letter assigned to your ipod (should be like drive I: or H: or similar.. Then scroll down to format and click on format. This should reformat the ipod completely.
Once that is done disconnect your ipod from the computer and reset it again using the center and menu buttons. After it reboots, try reconnecting it to you r computer and see if it is fixed.
Aug 21, 2007 | Apple iPod MA446LL/A MP3 Player
Trekstor i.Beat MP3 Player Logo
106 people viewed this question
Top Trekstor Audio Players & Recorders Experts
Humanoid
Are you a Trekstor Audio Player and Recorder Expert? Answer questions, earn points and help others
