Question about Pentax Espio 738S 35mm Point and Shoot Camera
E1 error message and the camera won't open
I have tried all sorts of tricks, nothing E1 keeps flashing up and the lens won't go out, the whole camera is stuffed up. What can I do?
    Genius:
  • 1,550 Answers
Try hard reset . Remove the batteries and insert new batteries . Sometimes this may work
Another chance is that lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work
Hope this helps .
If your problem still continues you need to take to service center .
Because the sensor is broken or damaged you need to replace it .
Thanks for using FIxya
SAM ANDERSON
Posted on Jan 30, 2009
Canon prima flashing E
First reaction, when your camera acts strange, is to switch it off. Then when the memory access light stops burning, or flashing, you can remove the battery (Batteries) Give it a few seconds, and then reinsert the battery. Now the camera will start from scratch. So if the problem was caused by a software problem, it should be solved.
Only when after switching on, the error reoccurs, you have a bigger problem, that perhaps only can be solved in a photo store, or at the service centre, closest to you.
Jan 26, 2014 | Cameras
I need an instruction manual for a Canon sure shot a1 panorama date camera
Ordinarily the panorama feature is utilized like this: you choose a panorama subject, and move your camera on a straight horizontal line with keeping your shutter down, and trying to capture the whole scenes into the lens. You can also stitch several common photos into one panorama picture(in vertical, horizontal, tile, 360 degree, 3d) with some programs like ArcSoft Panorama Maker.
Oct 09, 2011 | Canon Sure Shot A1 Panorama Date 35mm...
Hi. A friend gave me a weathermatic dual 35 camera and said that it may need some work. I replaced the aaa batteries and turned it on, the lens moves, the red light comes on but it will not take a photo....
Your camera very likely has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the manufacturer's service department in your country to find out about a free repair [EDIT: this option definitely will not apply to your camera as it's too old and Minolta no longer exist]. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the battery as it can be used in other devices. Please take a moment to rate the free answer I have provided for you.
Jun 15, 2011 | Minolta Vectis Weathermatic Dual 35mm...
Camera is jammed.
this is a lens problem you must find and replace the lens block for you camera.. search on ebay ionternational seller. it s possible that you can find the lens block for you camera,, the cost of the entire lens is 25 ----35... euro...sorry for my bad english i repair cameras but i am italian
Jul 25, 2010 | Olympus Stylus Epic 115 QD 35mm Point and...
Reads "Error"
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Mar 27, 2009 | Olympus Stylus Epic Zoom 80 QD 35mm Point...
Error message L1 and L2
Hello
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
May 31, 2008 | Leica Minilux Zoom Date 35mm Point and...
Busted
Hello
Regards
Andrea
May 19, 2008 | Fuji Zoom Date 60 35mm Point and Shoot...
Nikon one touch zoom 90 camera
I bought this camera at Value Village for $1.99. It came up with an E. I assumed this was an E for empty. I loaded a film and it is fine. frankvos@sasktel.net
Oct 07, 2007 | Nikon One Touch Zoom 90S 35mm Point and...
Cannot take photo
Hmmm, that problems posted on here a couple of times - THE H. Surely there's some info out there if you "google" the error message.
May 21, 2007 | Canon Sure Shot 105 Zoom S 35mm Point and...
Pentax Espio 738S 35mm Point and Shoot Camera Logo
215 people viewed this question
Top Pentax Cameras Experts
halotheracer
halotheracer
Are you a Pentax Camera Expert? Answer questions, earn points and help others
