Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Samsung HC-P4752W Blurred
I've owned this TV since July 2005, and a few months ago, the TV would go black, and you couldn't change the channel or source, etc. nothing. Just a couple of weeks back, when I turned the TV, it looked blurred (something similar to the problem somebody else described above), or 'ghosting', with yellow onto the left and blue (the most prominent color) to the right. Yes, I also tried autofocus, and it didn't work (the autofocus works halfway and then finishes). There is also a line that runs from the bottom and splits into two above the middle. Would it be too costly to fix? It is a good TV, and I never had any problems, but with $700 LCD TVs on sale, is it really worth fixing it?
Im sorry for this not being a solution, but I have the exact same issue Jose. It just happened 3 days ago. When I run auto focus it says check factory default settings. Will replacing the 2 CI's help cure this problem.
Posted on Oct 08, 2007
6ya staff
SOURCE:
Samsung Rear Projection SP43W6HFX- Smoke + Blurred Vision
Convergence IC's are busted.....google it. You'll find loads of solutions!
Nov 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" projection TV distortion & yellow?
I think you have a fault on the chroma board and on the picture frame board. If you can trace it yourself try these two locations otherwise call out a competant technician. hope this helps.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung rear projection tv
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
TV problem
It sounds like there is a fault on the chroma panel of some kind.
Jul 23, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4752w
Sounds like convergence amp ic's
i dont have any part number for that model.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 14, 2008 | Samsung HC-P4752W 47" Rear Projection...
Problem with hc-p4752w
Jan 10, 2008 | Samsung HC-P4752W 47" Rear Projection...
Sansung HC-P4752w 52 in. Rear Projection
you require a deflection board replacement the board cost around $150/
Aug 02, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W Blurry ONLY on HD Channels
Similar problem, then about 2 weeks later the SD convergence went out. Changes convergence Amps,,, Now I'm trying to learn what 2 red flashes mean now when I try to power it up,,, it flashes twice then shut down into standby mode,,, I got no picture after installing STK392-040 chips, thinking about trying another set as atleast I had blury picture before. No solder shorts of opens that I can find. TV has always been a pain,,, locking up once in a while such that you can't change modes,,,
Jul 22, 2007 | Samsung HC-P4752W 47" Rear Projection...
T.V. blurred then died
You will need to replace or have the main convergence amp board replaced or have the main amp ICs replaced. i you have no electronic experience with printed circuit boards, play it safe and call in a pro to assist you with this repair. Good Luck
Jun 19, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
77 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
