Question about ASUS P4P800-E Deluxe Motherboard
Will not boot with Keyboard and mouse plugged in
When my computer is rebooting I have to unplug the keyboard and mouse. The screen is black then after it sounds there are 3 shorts beeps or one long and 2 short, the hard drive light comes on and it boots to windows. I have no way of getting to my bios and it does not matter if the key board is plugged to the computer or not the internal memory does not display. I have changed my memory around to see if it was a memory problem but it still does the same thing.
    Problem Solver:
  • 10 Answers
Did you try removing each memory module individually... Instead of just moving them around.. because the error you are receiving is a bad memory error code.
Posted on Jan 30, 2009
My mouse doesnt work, when my mouse s plugged the keyboard wont work too
Try to unplugged both (mouse and keyboard) and reboot your computer. Wait at least 10-20 seconds and plugged the two devices. If your devices is a USB type try to interchange the plugged to a different port. Hope this will fix your issue.
Jul 12, 2011 | HP Keyboard/Mouse
My keyboard will not work
Keyboard Is Dirty:
Keyboards should be cleaned with "spray-n-wipe" cleaner and a cloth or tissue on a monthly basis. Ensure that computer is not powered up while cleaning the keyboard. Compressed air can also be used to clean between the keyboard keys. Another tip: clean the keys with a cotton swab dipped in alcohol.
"Keyboard Not Found" Message:
Your keyboard is not plugged into the computer securely. Unplug it and plug it back in and the problem should go away. If this doesn't work, follow procedure: "Computer isn't taking inputs from keyboard" (below).
Key Is Stuck:
1. If a key does not work or is stuck in the down position, you may try to remove it with a CPU "chip puller" tool. These simple "L" shaped tools are great at pulling out keys. Once you've pulled out the stuck key, you can try to stretch the spring to "reanimate" its action.
Computer Isn't Taking Inputs From Keyboard
1. Is keyboard connected to computer? Ensure that the keyboard is plugged into the keyboard jack and not into the mouse jack. If the keyboard was unplugged, plug it back in and reboot the computer.
2. If the keyboard still doesn't work on boot-up, power down the computer and try to borrow a friend's known-good keyboard for troubleshooting. Plug the new keyboard up and boot up the computer. If the new keyboard works, the old keyboard is bad and needs to be replaced.
3. If the known-good keyboard doesn't work, check your BIOS to make sure it sees the keyboard. It should say, "installed." If the BIOS recognizes the keyboard, then you probably have a bad keyboard port.
I Plugged Keyboard Into Mouse Port
1. Many mice and keyboards today use a PS/2 connector
. If you plugged your keyboard into the mouse port (or viceversa), follow steps 2 and 3.
2. Shut down the computer and plug the keyboard into the keyboard port. The keyboard port is usually marked with a "keyboard" symbol. Plug the mouse into the mouse port (usually marked with a mouse symbol).
3. Reboot the computer; the keyboard should work now. If keyboard doesn't work, check your BIOS to make sure the BIOS recognizes the keyboard. You should see the words, "installed" or "enabled" under the keyboard.
4. If the BIOS recognizes the keyboard but it still doesn't work, you may have a bad keyboard port.
I Spilled a drink on my keyboard!
1. If you spill any liquid in the keyboard, turn it upside down ASAP. Drain all the water out of the keyboard, shaking it if necessary. If you've spilled water into the keyboard, just let it dry. You may use a hair dryer to dry out area under the keys (remember, too much heat and you could damage the electrical components).
2. If you've spilled a soda into the keyboard, completely rinse it in warm water. No soap please! You may use a hair dryer at this point or just let it dry for 2 days. Ensure the keyboard is perfectly DRY before you attempt to use it again. Don't plug a wet keyboard into electrical equipment. Think safety.
5. If the keyboard still doesn't work, replace the keyboard.
Nov 13, 2010 | Dell Computers & Internet
The mouse appears to be on but the pointer on the screen does not move. The keyboard is still working. The re-set button does not correct the problem. Re-booting the computer does not work.
The same thing happened to me today. Somehow, something uninstalled my setpoint mouse software?!?!
While I was actually using the mouse?!?!
(it just stopped moving all of a sudden)
Don't ask me how/why this happened but I fixed it by unplugging the MX1000--both power and usb connection, plugging in an old serial mouse, rebooting the computer, opening mouse properties, going to the Mouse settings (in Control Panel), clicking the Setpoint tab, telling it to look for an update to the Setpoint program, letting it download and install the program automatically, then unplugging the old serial mouse, plugging in the MX1000 (usb first, them Power) and Voila'! Working as it should once again, even without a reboot. :o)
I love this mouse--perfect size, fast, programmable, accurate, long battery life, Perfect!
Aug 06, 2010 | Logitech MX1000 Laser Cordless...
Keyboard not working after being unplugged & used on another comp
Close down computer and reboot and pray. I mean to close down not reboot, not hibernate, not sleep.
Why? The electronic chips chatter before the operating system boots up. BIOS asks who is here? Any Keyboard, and other internal bits.
For readers... Cold rebooting fixes a multitude of problems with not working. OK, it does not fix everything, but it is a good first try
Sep 08, 2017 | Dell Computers & Internet
Keyboard not responding
Have you tried a USB keyboard and mouse wired.try also to hook up the normal keyboard and Mouse with out any usb devices hooked on the computer
May 05, 2009 | Logitech 967461-0403-PK Keyboard/Mouse
Mx 3200 keyboard runs but won't type
windows xp info.
go to start,
control panel,
systems,
hardware,
device manger,
click on x at keyboard see your keyboard there right click delete keyboard shut down and reboot leave keyboard plugged in...and it should find and reload the keyboard.
if this does not fix the problem..shutdown the computer unplug the keyboard and mouse...reboot the computer and let load all the way...I know you can't do nothing about signing in or working on it
but let load all the way after finished loading push button to power it off are unplug it...then replug the keyboard and mouse and boot it back up should fix it...
Apr 05, 2009 | Logitech Cordless Desktop MX3200 Laser...
Dell C521 Will boot to User login But cannot use mouse or keyboar
If it is a USB then it should work with any keyboard and mouse. When you say it shuts off after XP loading screen, does the machine power off? have you tried unplugging the mouse and keybaord and let Windows load?
Mar 10, 2009 | Dell Dimension C521 PC Desktop
Lost signal on Microsoft 4000 wireless keyboard & mouse
you have a resset onder the mousse, change the battery , and reinstall the driver
Dec 31, 2008 | Microsoft Natural Ergonomic 4000
Just installed a microsoftwireless keyboard 4000 and installed software and it worked fine. When I rebooted my computer would not start untill I unpluged the new keyboard. Tried several times to the same...
Hello There,
This problem is not common,
Try these:
1) Re-install the software - see what happens.
2) Un-install the software if 1) doesn't work and try using keyboard.
3) Read about common problems in the software and keyboard:
http://support.microsoft.com/kb/258826
4) If all these fail then call Microsoft about this problem and let them diagnose it. They are the makers so they should know what to do.
Dec 27, 2008 | Microsoft Wireless Laser Desktop 4000...
ASUS P4P800-E Deluxe Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
