Question about Goodman GMS90703BXA Heater
The heater will ignite for a second and shut off but it will continue to blow cold air
  • 96 Answers
Check and clean the flame sensor
Posted on Jan 31, 2009
THE IGNITION DON'T FLAME AND THE HEATER BLOW COLD AIR
Can you verify if the igniter is receiving 120 volts?
Dec 09, 2012 | Goodman GMS90703BXA Heater
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
Air conditioner suddenly stops blowing cold and starts blowing heated air. Control panel indicates that it is still on air conditioner. Switching the control from vent to cold does not have any effect. ...
If you are absolutely confident the AC compressor is not kicking out on low pressure then it is the blend door actuator.
The blend door determines how much air blows through the heater core or evaporator.
The actuator can be purchased at dealer and maybe at a local part store.
May 27, 2010 | 2005 Chevrolet Avalanche
Reddy heater blows cold air
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 30, 2008 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Heater blowing out cold air
Yes you could have a bad overload on the heater element which is fairly simple to fix. To test for this pull the heater out and get an ohmeter set it to continuity and check the continuity first through the entire heater element then if there is none pin point the overloads and check to see which one has no continuity.
Nov 05, 2007 | Amana PTH153B35AE Air Conditioner
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
