Question about Microsoft Windows 98 for PC
Detection for unused application
What are the possible codes for detecting unused application using the visual basic?
Hhhhhhhhhhhh
Posted on Jan 30, 2009
Code po456 on my 2006 mustang 6 cyl. is there an easy fix
This elaborates more on the code.
P0456 - Evaporative Emission System Leak Detected (Very Small Leak)
Description:
The powertrain control module (PCM) monitors the complete evaporative emission (EVAP) control system for the presence of a very small fuel vapor leak. The system failure occurs when a fuel vapor leak from an opening as small as 0.508 mm (0.020 inch) is detected by the EVAP running loss monitor test.
Possible Causes:
• Very small holes or cuts in the fuel vapor hoses/tubes
• Loose fuel vapor hose/tube connections to the EVAP system components
• EVAP system component seals leaking. See the Possible Causes for DTC P0442
Diagnostic Aids:
Check for a missing fuel filler cap or the integrity of the cap.
Check for loose or damaged vapor hoses. Visually inspect the EVAP canister inlet port, CV solenoid filter, and canister vent hose assembly for contamination or debris.
Application Key On Engine Off Key On Engine Running Continuous
Nov 21, 2013 | 2006 Ford Mustang V6
Code po456 on a 2006 mustang 6 cylinder. any suggestions?
Description:
Possible Causes:
Diagnostic Aids:
How to do vb.net framework ??
You need Visual Studio from Microsoft. Inside this visual Rapid Application Development (RAD) tools, you can use c++, c#, or basic language. It is lot of learning to become programmer.
You can find SharpDevelop free programing studio if you want to learn more. With this program, you will need .NET packages on your computer. It is like JAVA from Sun (Oracle). It is copy from Microsoft of JAVA ideas. Like free NetBeans IDE for JAVA development.
Inside studio you will have option for create New project. It can be grafical with graphical designer for draw some button, text input frame ... You will have properties for this objects, and possibility to write programming code. It is lot of learning to do real application. When you write some application you can compile it to exe output.
Visual Basic is only simplest part of this technology. C# (C-sharp) need more learning, and C++ is hardest thing.
Aug 26, 2011 | Computers & Internet
My 1997 chevy s10 is messing up I hooked up a obd2/eobd code reader and it gave me back this code......P1380 EBCM DTC detected, dada unusable? I have no clue what that code means but if you can help it...
P1380 - Misfire Detected Rough Road Data Not Available
The comprehensive component monitor (CCM) monitors the VCT circuit to the PCM for high and low voltage. If the voltage falls below a calibrated limit a calibrated amount of time during testing, the test fails.
Possible Causes:
  • Open or short in the VCT circuit.
  • Open VPWR circuit.
  • Damaged PCM
  • Open or short in the VCT solenoid valve.
  • Possible Solutions:
    DTC P1380 is a VCT circuit check. Testing should include wires, solenoid coil, and the PCM.
    Jan 17, 2011 | Chevrolet S 10 Cars & Trucks
    I bought serious magic visual communicator pro 2 on amazon.com but the product key is not working. I called adobe and they said that I should ask for a refund. I am not sure that the seller will give me a...
    Issue Activation fails when you attempt to install and launch a legacy Serious Magic product.
    Reason Adobe has chosen not to renew the hosting account for the Serious Magic web site. The hosting contract expired on Nov. 3, 2008. Activation for Serious Magic products that rely on this server is no longer supported by Adobe. SolutionDo one of the following:
    1. Upgrade to the latest Adobe-branded version of the product.Note: DV Rack is now Adobe OnLocation. The most recent version of Adobe Ultra was Ultra CS3. Ultra was not included in CS4, however, color keying is available in After Effects CS4. A tutorial on basic color keying is available here.
    2. Download and run the Serious Magic legacy product activation tool.Instructions for SMActivate.exe:
    1. Extract the .zip file to a convenient location.
    2. Double-click SMActivate.exe. The application will display a list of Serious Magic products to be activated.
    3. Click OK.
    Your product is now activated and ready to use. If no qualifying products are detected, it will display the message: "No legacy Serious Magic applications detected."
    This change affects the following Serious Magic products:
    • Ultra NTSC VxxV
    • Ultra PAL XxxX
    • Ultra 2 PAL BPWB
    • Ultra 2 NTSC BNWB
    • Visual Communicator 1 Studio SxxS or TxxT
    • Visual Communicator 2.0 CxBC
    • Visual Communicator 2.0 Web CxWC
    • Visual Communicator 2.0 Pro CxPC or CxQC
    • Visual Communicator 2.0 Studio CxSC or CxTC
    • DV Rack DxxD
    DV Rack Express requires a special version of the activation tool, available here. This affects the following Serious Magic product:
    • DV Rack Express FxxF
    For DV Rack Express, do the following:
    3. Select the checkbox for DV Rack Express.
    4. Click Activate. This will create a file, smact21.db, in the C: root.
    5. Move that file to c:\program files\serious magic\dv rack express\bin
    The following Serious Magic products do not use activation, or use alternative activation and are not affected:
    • DV Rack 2.0*
    • Ovation
    • VlogIt!
    * DV Rack 2.0 uses activation through a third party company named Softwrap, which resides on a server that is not affected. http://www.softwrap.com/
    Note: Ultra CS3 is an Adobe product and is not affected.
    Dec 21, 2010 | Serious Magic Visual Communicator 2 Studio...
    PO 341 code on 2002 chevy impala
    This P0341 code basically means that the powertrain control module (PCM) detected a problem with the camshaft signal. The camshaft position sensor (CPS) sends a specific signal to the PCM for Top Dead Center on the compression stroke as well as signals indicating the position of the cam sensor. This is accomplished through a reluctor wheel attached to the camshaft that passes by the cam sensor. Any time that the signal to the PCM is inconsistent with what the signal should be, this code is set.
    NOTE: this code can also be set by extended cranking periods.
    Here is a possible solution to the problem;
    • Check that the wiring isn't routed too close to any secondary ignition components (coil, spark plug wires, etc.)
    • Visually inspect the wiring at the sensor for any burn marks, discoloration indicative of melting or chafing
    • Visually inspect the cam sensor for damage
    • Visually inspect the reluctor wheel through the cam sensor port (if possible) for any missing teeth or any damage
    • If reluctor isn't visible from outside the engine, visual test can only be done by removing cam shaft or intake manifold (depending on engine design)
    • If all checks out okay, then replace the sensor.
    Be cool!!!!
    Aug 02, 2010 | 2002 Chevrolet Impala
    I dont know the disadvantages of visual basic.
    visual basic, is only a basic programming language, most programs will run on Java script, microsoft is visual basic though, but it uses a lot more complex scripts then, if you like the programing language, go for it, but i did not like it.
    Also
    VB is undoubtedly the simplest and easiest platform to build major Windows applications. The problem is that like other Microsoft products they change faster than I change my socks.You will certainly need more than just VB. Get into server and client side scripting and the use of VB Net.
    Jul 06, 2010 | Microsoft Visual Basic V6.0 Fundamentals...
    How to download microsoft visual basic 6.0
    Hi.
    Microsoft Visual basic is not a free download.
    The best complete application to program in Visual basic is Visual Studio. You can download it here: Visual Basic Downloads.
    If you want to download the service pack required to run VB applications see here:Download details: Visual Basic 6.0.
    See also:Microsoft Visual Basic 6.0 downloads.
    Regards.
    May 02, 2010 | Microsoft Visual Basic 6.0 for PC
    Authentication by Face capture by webcam
    For you to be able to do this you would need a separate standalone program. Your web application would try to detect if that program is running or installed on your client's computer if it is then your webapplication would send a request to the local application to run the face capture, if not then your webapplication would require the download of the software.
    With regard to your local standalone software. you could do that in visual basic. make sure that your standalone code would also be a small webserver.
    so what your web application actually does is it sends a request to the localhost or client computer, assuming that the local standalone is present then your webapplication would be able to connect to it through the small webserver. Well, the main point is that the local software would be the control for the webcam and also the means fo communication between it and your web application.
    Apr 16, 2010 | Microsoft Visual Basic Professional...
    I have a runtime error 9 subscript out of range, when i try to open a program
    1. Start the Visual Basic Editor (press ALT+F11).
    2. If Project Explorer is not visible, press CTRL+R to activate Project Explorer.
    3. Click to select the Visual Basic project that contains the module sheet that you want to copy.
    4. On the Tools menu, click References. Click to select the Microsoft Visual Basic for Applications Extensibility 5.3 check box, and then click OK.
    5. Click Module on the Insert menu.
    6. Type the following code into the module sheet: Sub CopyModule() Dim CodeLines As String Dim ModuleToCopy As VBComponent Dim NewModule As VBComponent ' Set a variable to the module to copy. ' Note: This assumes that the name of the module to copy is ' "module2". Replace "Module2" with the name of the module to copy. Set ModuleToCopy = _ Application.VBE.ActiveVBProject.VBComponents("module2") ' Get the Visual Basic code from the module. CodeLines = ModuleToCopy.CodeModule.Lines _ (1, ModuleToCopy.CodeModule.CountOfLines) ' Create a module sheet in another workbook. ' Note: You must refer to the name of the Visual Basic project. By ' default, the name of all new projects is "VBAProject". You may want ' to rename the project to which you are copying the contents of the ' module sheet. Set NewModule = Application.VBE.VBProjects("VBAProject") _ .VBComponents.Add(vbext_ct_StdModule) ' Add the Visual Basic code to the new module. NewModule.CodeModule.AddFromString CodeLines ' Rename the new module to the name of the previous module. NewModule.Name = ModuleToCopy.Name End Sub
    7. Run the CopyModule procedure.
    Regards
    Samson Ved
    Dec 05, 2008 | Computers & Internet
    Microsoft Windows 98 for PC Logo
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
