Question about Ruud UBHC Air Conditioner
Not sure what blower motor to get for my furnace
I have gotten the information for the blower, but i can't find the correct motor anywhere. This is the info I was able to get from the motor
General Electric Motor
#5kcp39kg
R047 S
1050rpm
60 hz
115V
5.8 A
1/2 hp
1/2" shaft
    Scholar:
  • 144 Answers
The real relevant info is 1/2 hp, 1050 rpm, 115 vac, 1/2 inch shaft. Bring that info to any HVAC supply, any appliance parts, Graingers etc. and they should be able to match it up. I just went to the Graingers site and you can order one for $87.50 plus shipping. lease give me a good rating for getting this info for you. Thanks.
Posted on Jan 30, 2009
Compressor runs but why is no air coming through ducts?
The fan motor may have gotten zapped. Something, such as a line surge, may have affected the controller.
Sep 11, 2015 | Bryant Single-Packaged AC & Gas Furnance...
Blower motor will not come on
If the blower motor has correct voltage and not running it can be a capacitor, its about $5 to try it, otherwise a new fan motor is required. 22296134-wil0gxehsfojcry3vcxysbjd-5-0.png
Dec 19, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Carrier 58MVC100 furnace no power. Tree fell on main power line and after power restored noting going on with furnace/air handler. LED is not lit. 3amp fuse appears to be good and there is a sulphur smell...
Possible that when power got restored you furnace might have gotten surged. replace fuse any way to be sure. Check break box for trip circuit. Call a tech from there man.
Aug 08, 2013 | Carrier Infinity 58mvc080 Gas Furnace 80k...
I have a vulcan silhouette manual wall furnace that gets really hot and the grill and vents are starting to warp the thermostat doesnt seem to be working, should i still be using the heater...
YOU MUST HAVE THIS THING CHECKED OUT BY AN EXPERT. IT IS A FIRE HAZARD. Even if the thermostat was a closed circuit, the furnace would be working all of the time but it would not be overheating to the point of warping parts. You are either overfiring or your blower is not running all of the time. If it's a blower problem, clean out the dirt and dust and oil the motor. If the motor is not running, replace the fan control or the motor. If the furnace is overheating, your gas regulator might be bad allowing to much gas pressure to the furnace. Also, make sure that the burner orifice's are the correct size for the heater.
Jul 08, 2010 | Heating & Cooling
Furnace/air cond. blower motor is smoking
I recently installed a horizontal gas furnace. All the electrical and gas supply was done correctly for sure, but upon the trial run, some smoke was coming out the supply lines into the house. I used some flex duct tape to seal all ductwork for air leaks. I also used some inside the first box coming off the heat exchangers to seal the inside of the box for leaks. Could the tape be burning because its to close to the heat exchangers and smoking or is it because its because its brand new and the heat exchanges have to burn a while? Please help
Jun 25, 2009 | Dehumidifiers
Ruud 90 deluxe plus, in the last week blower motor noiser
George, make sure the belt is not loose flapping around making all that noise.
Not hard to change if you can get one from an hvac friend, they won"t sell to homeowners normally.
Jan 18, 2009 | Honeywell Power Humidifier: Furnace...
Furnace Blower Motor Specs
That information is usually on the data plate on the furnace and on the motor itself. All you need to know now is the HP. Other than that a universal consolidator motor is an easy fix too. It can handle 1/6-1/3HP.
Dec 17, 2007 | Heating & Cooling
Coleman furnace problem
Sometimes people replace the blower motors with a higher horse power. Has this motor ever been changed? I believe the original should be a GE motor
Nov 12, 2007 | Heating & Cooling
Ruud UBHC Air Conditioner Logo
1,053 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
