Question about Apple Cinema Display Flat Panel Monitor 20"
Dim 20" Apple Cinema Display
My 20" Apple Cinema Display just started looking dimmer than  previously.
Is this a backlight problem? What can be done?
Thanks for the help.
  • Anonymous Apr 01, 2009
  • eightdeer Apr 07, 2009
    My problem is similar, but I have a 22" Apple Cinema Display. The older generation one, I think it was the 2nd one, and has the clear plastic with white borders. Anyhow, my monitor seems pretty dim and it takes a while to get brighter, which is still not as bright as my newer monitors. The colors are not as right, vibrant, and bright as I think they should be... I have compared the monitor to another same, but smaller monitor and it definitely darker, but not like dark or impossible to see, it just seems dimmer than the rest. Does this need new bulbs or one of those inverter boards replaced? ANy info would be appreciated.
  • 51 Answers
Double check you power cord and try switching plugs.
sounds like its not getting enough power or a CCFL is going or is out and you need to get it serviced if thats the case.
Do not attempt to repair this your self Monitors usally have there own power supply built ind can store massive amounts of energy and will cause serious injury or death.
Posted on Jan 30, 2009
30" apple cinema display suddenly went blank.
It's probably the backlight. If you look very closely, perhaps using a flashlight, you might be able to see that it is still working but just not being lit up from the back. In that case it may be worth fixing, but if not, then it's probably past its useful life.
One other thing you might try is a different power supply.
Feb 14, 2014 | Apple Cinema HD 30" LCD Monitor
Blinking light on 20 inch apple display
Blinking light on Apple cinema display usually indicates insufficient power from the power supply. Test it with another power supply from ANY cinema display (23" and 27" power supplies are ok to test with).
Feb 03, 2014 | Apple Cinema HD 30" LCD Monitor
I have a M8149 Cinema dispaly 22" and want to connect to late 2009 Mac mini. The monitor came with a strange adaptor set of ADC input to 1x each of usb, 24Pin 92x rows of 8) male ADC, and another plug...
The Apple 22" Cinema display M8149 (ADC) is one that is not compatible.
It might be better to find another brand display to work with your 2009 Mac Mini. The Apple model A1081 is DVI, but for the age (its 8 years old, the lamps are likely dimmer than new...) I would look for a resolution-compatible DVI input display (Dell Ultrasharp, etc..).
Jul 22, 2017 | Apple Computers & Internet
Someone is selling an Apple Cinema Display 20"
It is fixable the question though is it worth fixing? because the problem usualy resides in the cost of repair.
May 11, 2011 | Apple 20 inch LCD Monitor
How can i open my 20'' apple cinema display monitor
Here you can find explanation in pictures how to open:
Feb 09, 2011 | Apple Cinema Display Flat Panel Monitor...
After a couple of electrical power outages my Cinema 20" Apple monitor doesn't work. The power light (lower right) goes through cycles of off, dim, bright, etc. sort of as if it's flashing a Morse...
There are three "morse code" flashes that an Apple Cinema display can produce that are diagnostic:
Three short flashes (morse "s") means incompatible video format. Try resetting the parameter RAM when restarting to go to the default
Short-long-short (morse "r") means "wrong power adapter." I've seen some monitors that will not work with an adapter that others will and that give this signal. In some cases this can be fixed by insulating the power sensing pin on the display power cord.
Finally morse "u" (short-short-long) means a backlight problem.
May 19, 2017 | Apple Cinema 20" LCD Monitor
Backlight is not working
eht coil generator which generates power for backlight tube is damaged change it
Nov 26, 2009 | Apple Cinema Display 23" HD Monitor
Apple cinema display has interference
Check your DVI cable for breaks. If that's not the problem, then you'll need a new IP board. Not sure of the part number for this monitor, it's printed on the circuit board. It starts with 820-XXXX or 620-XXXX in some cases.
Nov 24, 2009 | Apple Cinema 20" LCD Monitor
Apple Cinema display goes BLACK after start-up
My G4 has a ADC & VGA on the same card. The VGA works but the ADC, is doing the same thing as you described. I am searching the web, and can not find an answer to this problem. George 3/21/2010
Aug 03, 2009 | Apple Cinema Display Flat Panel Monitor...
Apple 20" display black screen
I've read that aftermarket DVI cable adapters don't work well with this set-up. You might try the Apple DVI to ADC adapter. It's expensive but I see them on eBay or craigslist from time to time at less than half the normal $99 cost.
Aug 26, 2008 | Apple 20" Flat-Panel TFT LCD Cinema...
Apple Cinema Display Flat Panel Monitor 20" Logo
659 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
