Question about ViewSonic VX922 19" Monitor Flat Panel
No image on monitor
Hi, i have a problem. Just turned my old computer which i left aside for a few months back due to a new computer i just rigged. When i turned it on, everything seems ok, bios beeps fine, first menu on screen ie: Detecting drives, Total ram calculations blablabla.. and then just a few seconds the screen went black and theres this one bright line (similar to looking under a magnifying glass under the sun kinda glow), bout an inch length on the bottom of the screen and it stays that way till i turned the whole pc off. When i did a cold boot, it runs again but this time with just a black screen. Normally on bootup, my monitor led will turn yellow and stays solid. But this time, the led keeps glowing yellow and then it dims and then glows bright again continuously like i suppose if you're watching superman the movie (the 80s version) and when the kryptonite glows bright and dim, sorta glow. No image on monitor though. Any solutions as to why this happens? My computer still runs normal but there just isnt any image on screen. Just that weird monitor led glow.
    Sergeant:
    Champion:
  • 318 Answers
Looks like the Video card, or Video chip has bought the farm
Try hooking up to another monitor to confirm where the problem is.
Posted on Jan 30, 2009
Tmy monitor shows the images only for 20 seconds, then it turns black.
Hi hope your monitor issue has resolved. I would suspect the problem is a hardware issue then a software setting. Since the monitor is over three and half years old, if your monitor is a LCD with CCFL back light and had been used almost every day, there may be 3 possible hardware issues. First is the internal power supply, that can go wrong due to heating problem within the monitor, this problem usually cause the monitor to display poor quality picture and may show interference lines on screen prior failure. Secondly, it may be the inverter that drives the back light, which may fail due to the safety circuit kicks in, because it involves with high voltages. Thirdly it may be the backlight itself, which is like most compact CCFL energy saving lamps that flickers or turn itself off when it reaches the end of its service life. This problem usually caused the monitor to show redness or yellowness images prior failure.
All of these can be resolved by qualified electronic repairers, all the best.
Nov 10, 2011 | Computers & Internet
Shuts off to a dark grey, turn VS power off>baon to display image
You may have failing DC filter caps in the power supply just like Viewsonic monitors you can see in my albums, you is about the same as 2235.
If you are not going to DIY you will be better off putting the money toward new monitor, estimate repair up to $100.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 24, 2010 | ViewSonic VX2035WM LCD Monitor
Monitor flickers about 2 minutes after turn on. the flickering starts from the left and it eventually becomes a black screen. the monitor is 8 months new.
Unless I have the model number wrong (F1903), this monitor was relased in 2004. If it is 8 months old then it should be fixed under warranty. This can be bad problem in the bcaklight inverter circuits or bad lamps due to bad soldering works, bad power supply, please look here to see hwat is involved in repairing the monitors: http://s807.photobucket.com/home/budm/allalbums
Apr 01, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
HPvs17x power flicker on/off no image, 3-10min after image ok!
More likely to have failing power supply problem due to bad caps, look for caps with bulging top first and post back what you see inside, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 02, 2010 | Computers & Internet
Ghost images
Yes the images where left on the screen for a long period of time which burnt the images you see into the screen
Mar 10, 2009 | Samsung 2220WM-HAS Monitor
My Monitor turns off randomly
First check to make sure your drivers are up to date and the card is seated properly. Then If your graphics card is still under warranty take it back and get a new one. For some reason it is cutting out the signal to the monitor.
Dec 11, 2008 | Acer Aspire 9300 Notebook
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
My monitor turns itself off
If it's only a few months old then send it back under warranty.
The fault you have is the inverter circuit.
Hope that helps. =)
Apr 12, 2008 | Acer AL2032WD 20" LCD Monitor
ViewSonic VX922 19" Monitor Flat Panel Logo
215 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
