Question about Samsung HCN529W 52" Rear Projection Television
How do I determine my tv's configuration.
I have a 52" Samsung LN52A650A1F that was originally wall mounted. Recently I moved, but instead of wall mounting it I bought a " Bell'o flat panel tv mounting system"my instructions states that In order to convert it,I need to know my TV's configuration but I dont have an owner's manual what can I do?
    Genius:
  • 1,550 Answers
You can get configuration from the link below
http://www.mediacollege.com/equipment/samsung/tv/hc/hcn529w.html
Posted on Jan 30, 2009
My Sony KDL-42EX440 will not turn on
Have you tried to do a "reset" ALL modern electronic items often get "locked up" and unplugging them from the wall will often get them going again. Unplug for at LEAST 30 seconds--then try again. If this does not help--the SMPS board may have failed on you. A good repair shop may be able to repair the board instead of replace it.
May 06, 2014 | Sony Bravia 36 40 42 46 50 52 55 LCD...
Where can I buy a new base for the Samsung 24
The original Samsung stands will be very hard to find, only available from somebody that has wall mounted their monitor and no longer needs the stand. You can get a third party stand such as the one in the link below that will mount your monitor. All modern monitors have mounting holes in the back for VESA mounting, this is a standard configuration.
http://www.amazon.com/Adjustable-Tilting-Mount-Bracket-10~25inch/dp/B003L171KW/ref=sr_1_12?ie=UTF8&qid=1339684562&sr=8-12&keywords=monitor+stand
Jun 13, 2012 | Samsung 24" LCD Monitor 2494SW
Need a stand
I could not locate a stand for purchase on http://www.partstore.com/Model/Samsung/Samsung/PDP4294LV1.aspx
By the way, your tv is a rebranded Samsung model.
Without the stand, you only option would be to wall mount the tv.
You can purchase a wall mount for your tv from your local Wal-Mart or something to that effect for around $30.
Mar 13, 2011 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
I have recently bought a Samsung SM2033HD TV and want to wall mount it. I can remove the base but how do I remove the collar that joins the base to the TV.
Your tv is not fully VESA compliant. You cannot remove the collar. There are mounts available that grip the screen instead of screwing into the back. This type will look better.
Jan 10, 2010 | Samsung LE40R74BDX 40 in. LCD Television
WILL BE BUYING LCD TV IN NEAR FUTURE, BUT NEED TO MOUNT IN ON WALL WITH FIREPLACE, SEVERAL FEET ABOVE EYE LEVEL. CAN DO?
Absolutly, I have wall mounted a few dozen above fireplaces in the past 5 years; I can even send you over some pictures and suggestions come time for the install.
What is the wall material? Brick mantel or drywall with wood studs?
Although a TV looks attractive about a fireplace you have to consider that it is fatiguing to watch from such a high height. The optimal average height for a TV is 45" to centre (depending on furniture). If you exceed that by a few feet watching a lot of TV is awkward.
The advantage is it combines the focal point of the room, and instead of having a picture about a fire place, your TV becomes the work of art and can be used as a digital picture frame.
Jan 01, 2010 | Samsung LN52A850 52 in. LCD HDTV
Tv was previously wall mounted now want to place on a table
try calling 1-800-samsung to find the closet repair center.
Nov 14, 2009 | Samsung LW15M13C 15 in. LCD Television
TV Installation at Home
we really cannot speak for the Geek Squad. You will need to look at the contract you sign with them to determine if they provide the bracket or require you to do it. most of the time you will need to purchase the wall mounting in addition to the tv.
How long it will take will depend on the professional. It should take less than 30 minutes.
CH
Jul 29, 2008 | Televison & Video
Reccomended settings for Samsung 52 inch LCD tv
I have recently posted a question regarding my Samsung 52 inch LCD hi def television. After doing some research online and reading some others experiance I have adjusted my settings in the menue of the tv to provide the best picture.
May 30, 2008 | Televison & Video
Samsung HCN529W 52" Rear Projection Television Logo
101 people viewed this question
Henry  Thomas
Henry Thomas
