Question about Jenn-Air JER8850 Electric Kitchen Range
Electric Range Door Locked after cleaning
I was cleaning my Jenn-Air JER8850 when at the end of the cycle the display flashed F1 and began to beep. Now the door is locked and will not release. Does anyone know how to get the door to release???
  • 5,911 Answers
"F1" is an error code for any of the following possible problems: Electronic Oven Control (EOC) board. Wiring harness shorted. Defective touchpad on the control board. I speculate that the control board may have failed during the cleaning cycle, causing your problem. Unfortunately, this may be an expensive repair if it is a control board, and it could be maintenance intensive to get to the door latch to release it. You will need to lift the stove top to gain access to the linkage for the oven door relay. There should be a few screws under the top front to remove. Make sure you unplug the unit or turn off the circuit breaker before servicing. I hope this helps you.
Posted on Jul 28, 2007
Jenn-Air Range displaying Error F1-8
Did not find an error code "F1-8"
I did find these. Seems that about everything that can go wrong with a Jenn Air is related to the clock.
https://www.repairclinic.com/RepairHelp/FaultCodes/26/Range-Stove-Oven
Sep 22, 2017 | Jenn-Air JES8850AAS Electric Kitchen Range
I have a double oven electric whirlpool oven and turned self cleaning on and by mistake as it was loking i opened the door and cannot turn on its showing locked the opens and i can not turn on oven
Hi, Door locked flashing after the attempt of the cleaning cycle. After taking the oven appart to get the door open, I began troubleshooting. I discovered that the door lock motor failed in the locked position. I opened up the motor and found the magnet inside was cracked! The coil winding for the motor was also open. Hope that helps! While your waiting on the new part you can trick the oven by using a zip tie on each of the two lock motor micro switches to hold them closed and remove the lock lever. The oven will work just fine.
bye
Jul 05, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
F1 llight on, oven locked, stove beeps every few seconds
My stove did the same thing after I cleaned it. I had to have the sensor replaced. That is what the F1 code is.
John
Oct 01, 2009 | Frigidaire Gallery GLEFM397DS Electric...
F1 error code is displayed on my Jenn Air 8850AAW, attempted to reset circuit breaker and the F1 code came back. Any suggestions?
Hello, I am going to include a link which gives you a full list of error codes, once you have found the error code for you range it should just be a matter of changing the part...If you have any problem understanding what the error code refers to please feel free to comment again and i will go through the problem with you. Hope this helps...good luck!!! http://www.repairclinic.com/0078.asp#Back
Jul 08, 2009 | Jenn-Air JER8850 Electric Kitchen Range
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Jenn-air gas electric grill range
any power to unit at all?? clear, start, clean ,button?? what happens when you push them??? clock on?what happens when you try to set to clean again??? it should activate hte door lock latch at which point cancel and it should reset itself. with any luck! what happened thankgiving how was it fixed
Mar 14, 2008 | Kitchen Ranges
This is not a problem. The cleaning cycle goes on for approximately 4 hours as I recall. it will unlock by itself when done. Read your user guide for troubleshooting tips. if you can't locate your copy, one is available on line at the Jenn-Air site
Nov 24, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Check the trouble shooting section of your owner's manual for your various fault codes. It may point you in the right direction as to your next course of action.
Oct 04, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JER8850 Electric Kitchen Range Logo
186 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
