Question about Samsung S760 Digital Camera
Samsung S760 Digital Camera - Not turning on and lenz stuck out.
I don't know what to do. I was just using my camera as normal then I turned it off and when I tried to turn it back on it would not turn on, and I realised the lenz was stuck out. The small green light would flash everytime I tried to turn it on. It still will not turn on to this day. I had tried taking the batteries out and putting them back in, but the same thing happened, I tried pluging it into the computer, still doesn't work. Please help!?
  • Anonymous Feb 13, 2009
    My Camera will not turn on either the light keeps turning on butthe lenz never goses out and im not sure hat to do
  • fallout_girl Feb 14, 2009
    Sorry I haven't replied I haven't had time and I keep forgetting, so yes, you say my lens is struck, and there is abit of dirt I can see and its abit foggy. I also do not know where I can get canned air, any suggestions? (I live in Australia, not America, just letting you know because of all the different shops.)
    Genius:
  • 1,550 Answers
Yes you are correct lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work
Hope this helps .
If your problem still continues you need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Posted on Jan 30, 2009
I also had this problem after buying cheap (only ones available in Centre Parks) batteries. lense was stuck out and every time i tried to turn on or off the green light flashed. I eventually got some Duracell and presto camera worked fine and the lense retracted.
Posted on Nov 20, 2009
Manual
If you need the manual it's here http://www.samsung.com/au/support/detail/supportPrdDetail.do?menu=SIA00201&prd_ia_cd=&prd_mdl_cd=EC-J39APBA/AU&prd_mdl_name=SAMSUNG%20S760
1st one at top of list is the User Manual normally the greatest in size and pages with instructions, others are Quick Guides.
Cheers.
May 15, 2013 | Samsung S760 Digital Camera
My samsung s760 has ahorizontal lines when you shout in a day time but if you shout it it evening the picture is ok.eventhough i put off the flash in day time it is the same result.what can i do?please...
Mary,First check to ensure that your camera is in automatic mode, and not in one of its manual modes. For example, shooting in a night scene mode in daylight could cause these symptoms. But if you are in auto, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 11, 2011 | Samsung S760 Digital Camera
My camera samsung lenz keep saing CARD LOCKED when I turn it on
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Apr 16, 2010 | Samsung L100 Digital Camera
Samsung S760 not turning on after mishap.
If it's a lens problem, there's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 23, 2010 | Samsung S760 Digital Camera
Lens is stuck and camera will not turn on.
there is a problum in your lenze block (optical assy) this problum is not remove at home so please go to your nearst sony service centre & repair the lenze block because no the child parts are avalable
Feb 12, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Stuck up lense of samsung s760
did you check if your battery is dead. When batteries are dead, your lens sometime get left out.
Aug 22, 2009 | Samsung S760 Digital Camera
Headache
Since you purchased it fairly recently it is probably still under warranty. Contact Samsung. Camera instruction book probably has contact information or try their website.
Jun 11, 2009 | Kodak EasyShare M853 Digital Camera
Won't stay on even with new batteries- it beeps then turns off
my camera is doing the exact same n i'm hunting the net right now for some kind of solution!! :( i think its something to do with the lens, mine was completely stuck, but i gently pushed it n it went back in and moves in and out fine, but the cam still comes on for a couple of seconds makes this wierd beep n goes off again!
May 27, 2009 | Samsung S760 Digital Camera
Error
lenz motor not worck or may jam
Apr 02, 2007 | Kodak EasyShare LS443 Digital Camera
Samsung S760 Digital Camera Logo
668 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
