Question about Razor Dirt Quad Bike
49cc 2 stroke dirtbike hard to start will not idle
Ok what i have is a dessert racer z just bought it have not got to ride it because it is just to hard to start and will not stay running does not get hot just dies and is hard to start again over and over
Carborator needs cleaning
Posted on Jun 30, 2009
Runs and starts great but won't idle
Hi, Emmett and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve is not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
Motorcycle Message Board Motorcycle USA
2 stroke dirt bike problem Won stay running Please help motorcycles
Honda 650 Won Idle
http://www.sportbikeworld.com/forums/179-atv-dirtbikes/30570-bike-runs-fine-wont-idle.html
Mar 21, 2016 | Motorcycles
49cc 2 stroke dirtbike runs great on flat land but not good on hills
Hi, Gadgetmen53 for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
How to derestrict 50cc scooter moped Make it go Faster
How to make your scooter go faster part 1
Video Number 4 Make My 49cc Scooter Wicked Fast
Dec 28, 2015 | Power Motorcycles
Whats most likely the prob if I filled my dirtbike oil level to full and within 1 hr of riding low on oil with white smoke and oio blowing out of exhaust
it would be helpful if you would give us details like what kind of oil, etc. and tell us if it is a 2 stroke or 4 stroke, off road only or dual purpose
Sep 23, 2014 | 2007 KTM 660 SMC
I have a 49cc two stroke bike, (pit bike) like new. Starts first time, no problems. But after 10min of riding the bike stalls out. If i leave it for 20min then it will start again. Run for 10min then stall...
Ok, a two stroke engine basicly needs 3 things to run: fuel, compression and ignition.
First, check that the fuelline, fuelfilter, or fueltap is not blocked. If the fuelflow is alright, check that the compression is fine. try kicking the kickstarter a few time: the should be a certain resistance.If the compression is wrong try changing the headgasket. If it is alright, check the ignition. This is done by taking the sparkplug out at placing it on the frame, when you kick the kickstarter a spark should jump from the sparkplug to the frame.
But my guess would be that you have a partly blocked fuelsystem.
Mar 15, 2011 | 2005 Qianjiang QJ100-2
Pocket bike starts with starting fluid but then even after its warm it wont start on its own, and when its running the idol is higher with the choke on, the bike almost wants to take off, if I turn the...
Did u put oil on the air filter? if thats ok then it sounds like you have a clogged pilot jet in the carb, pull the float bowl and remove jets then poke thru with fine wires untill clean. also take note of air mixture screw which will be located around the opening of the carb. clockwise will richen it up and start to make the idle drop and counter clockwise will do the opposite.
Aug 20, 2010 | RTO 47cc / 49cc Pocket Dirt Bike Atv...
2 stroke 49cc quad engine dies when i accelerate
well it is 2 stroke so if its rev'in slow thats not dunna help . my sister had one and its the kind of thing that u don't let it idle just keep it going. thats what i found best
Nov 01, 2009 | Razor Dirt Quad Bike
I just bought a 2 stroke 49 cc atv. Everything was working fine untill the engine just cut out. It started once or twice after several pulls of the cord but cut out soon after once again. PLEASE HELP, i...
hi mate are you mixing the bike with 2 stroke if not buy a mixing bottle with a ratio of 32/1 on ebay and buy 2 stroke and mix it up with petrol and oil if not the engine will seize also take the spark plug out and give it a clean with a wire brush and check the gap is ok and then put it in the plug cover and put the plug against the cylinder and turn the engine over and see if there is a descent spark if not replace the plug good luck
Jul 21, 2009 | Fender 2 Stroke Full 49cc ATV # ATG-47B...
49cc 2 stroke runs for 20 sec. then cuts out
20 seconds is all that is required to drain the float bowl. You have a float bowl/needle valve problem.
Apr 24, 2009 | Fender 2 Stroke Full 49cc ATV # ATG-47B...
49cc 2 stroke engine
I have a 49cc cateye mini bike it starts idles fina dn every thing but when you ride it it goes fine i can reach around 55 almost 60 with the stock engine but it seems to quit on my after about 15 mabey a little less sometimes and then will not start for about another half hour
Jun 18, 2008 | 1997 Acura CL
Razor Dirt Quad Bike Logo
1,230 people viewed this question
Top Razor Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
RatanbssBD
Level 1 Expert
Are you a Razor Rock and Ice Climbing Expert? Answer questions, earn points and help others
