Question about Microsoft Windows XP Home Edition
SATA drive not recognized AFTER partial install of Vista
My new system has a SATA drive. After booting to the Vista DVD and installing, the system locks up at the first reboot during the install process as if the SATA drive does not exist. This also happened with XP on the same system, which is why I purchased the full version of Vista. Two hours of discussing the problem with Windows technical support did no good at all. The system works fine with the OS installed on an IDE drive. There is no opportunity during the install to load any drivers; I am never able to get this far. There is no mention of this problem at all in any hardwear or softwear documentation I have.
Thanks for any assistance.
    Sergeant:
    Champion:
  • 318 Answers
You need to download a program from the Hard drive Manufacturer which will re-format the hard drive again.
This seems to be very common with SATA drives.
Posted on Jan 30, 2009
Just installed new HP dvd1270i. PC boots but
Check your power connector to the DVD Rom and also check the cables (Sata or IDE). If this doesn't bring any solution, scan your system using updated anti virus. Good luck.
Apr 07, 2010 | Dell DVD-ROM for Dimension (6t903)...
Vista Home Edition Driver Problems
Hi Ajay.
It would be best if you take a back up of important files from your OS drive and make a clean installation of the OS again. There might be an issue of corrupt OS files.
Hope that solves it.
Dec 17, 2009 | Microsoft Windows Vista Home Premium with...
I have purchased an hp550 computer with the Vista operating system. i wish to downgrade to the win XP operating system. how is this done ?
Greetings.
There is no direct path to downgrade Vista to XP. You can’t simply insert the XP installation CD media into the CD-ROM drive and hope to ‘upgrade’ and replace the Vista with Windows XP usual install routine because Vista won’t allow it to be overwritten. XP will treat Vista as ’superior’ operating system and refuse to install over it. There’re actually few options available instead of completely uninstall Vista as listed below. But if you decide to downgrade from Vista to install XP, there is also a simple guideline that you can observe to ensure that the migration goes smoothly.
Option 1 – Dual Boot:
It’s by far the easier and best method to run XP instead of Vista if you have another partition or hard disk. Simply boot up any XP setup media and install XP into different partition or hard drive than the Vista installation. Once completed, you can choose to boot up either XP or Vista, and has the best of both world.
Option 2 – Virtual Machine:
Install VMware Server or Virtual PC 2007 (both free) or any other virtualization software, and then install Windows XP into the virtual machine
environment. You will get XP which runs inside Vista, with minor compromise on speed, performance and have to go through Vista first on every bootup.
Option 3 – Format the Hard Drive, Wipe Off Vista and Install XP:
For those who totally fed up with Vista and just want XP, or prefer a clean installation of OS has only this option to rely on. To downgrade to XP from Vista, you have to basically delete the whole hard disk that installed with Vista, and start anew with XP. Here’s a simple guide and procedures that you can try to follow to switch to XP. However, each system configuration is different, so you may have to adapt the steps to suit your own need.
1. Download all drivers for your system for Windows XP from the manufacturer’s website(in case if you don't have the CD/DVD installers). Copy the drivers files to a USB flash driver or external hard drive or burn them to CD/DVD.
2. Find a Windows XP installation CD (should be pretty easy to find or else you can search in torrent sites such as Demonoid to download via BT network such as uTorrent and BitComet or search and download via ED2K network client such as eMule. You can also use Volume Licensing (VL) CD, retail (FPP) disc, or system builder hologram CD provided by Microsoft.
3. You will also need a XP product key even if you legally can downgrade from Vista Ultimate or Business edition. The Vista serial number won’t works with XP. (try to search for XP product key on web).
4. Backup to USB flash disk, external portable hard disk or CD/DVD every data files and any other things such as documents, downloads, pictures, movies, programs and etc that you need and want to keep. You can also create a second partition with disk management utilities such as Acronis Director or Partition Magic, and then move the data files to the new partition.
5. Ensure that also you have CD or DVD setup media for the software applications that you want to install and use after wiping off your system from Vista.
6. If your OEM doesn’t provide you with recovery CD/DVD discs and Windows setup media discs (it’s because they’re stored in the hard disk in hidden location), you may want to burn a copy of recovery CD to CD/DVD first before you proceed, just in case the hidden partition is lost and you want to recover your computer to original state. (How-to Guide: IBM/Lenovo ThinkPad recovery CD)
7. If the system has SATA (Serial ATA) hard drive, locate the driver for SATA controller and put it in USB flash drive, diskette or CD first. If you have PATA (normal IDE) hard disk, simply go to BIOS CMOS to disable SATA or Native SATA mode if you don’t want to install XP on SATA hard drive. Else, you can also create an XP install disc with the SATA drivers integrated by using tool such as nLite.
8. In the BIOS, also set the CD or DVD optical drive as the first boot device in the boot sequence.
9. Put in the Windows XP installation CD into CDROM drive and boot up the computer by using the CD. You probably need to press a key when prompted with “Press Any Key to Boot from CD…”.
10. If you’re using SATA hard disk with driver on external media (not integrated into XP setup disk), remember to press F6 when you see the message at the status base: “Press F6 if you need to install a third party SCSI or RAID driver…” during the very initial stage of setup to load the SATA driver so that the SATA hard disk can be recognized.
11. Run through the setup wizard at per normal. However, when prompting for where to install Windows Vista, delete (by pressing D and then confirmation), create and format the Vista disk drive or partition (if you have multiple partition). And then choose to install on that just formatted partition or hard drive.
IMPORTANT: If you choose the wrong hard disk or partition with data to delete, you will lose your essential data.
Note: If the setup does not allow you to delete or format the Vista partition or drive, you will need to find a third party software that can recognize and read NTFS filesystem to clear the drive or partition first.
12. Enter any product key for XP. Vista product key will not work.
13. If you own a legitimate Windows Vista edition that allows for downgrade (See Vista downgrade rights), call Microsoft after performing the clean install of Windows XP Pro to activate the XP installation. Notify Microsoft that you’re downgrading from Vista and require to activate XP Professional or other version allowed newly installed. You won’t get a new Windows XP product key though. You will have to read out the long Installation ID plus your original Vista serial key, and Microsoft will provide an activation ID that will make the XP usable.
14. Install the drivers for your system devices.
15. Reinstall any software programs that you want to use.
16. Move back the data files and documents.
Thanks
Nov 03, 2009 | HP Business Notebook 550
Toshiba Qosmio laptop with Phoenix securecore util,uses SATA drive. Had to replace the Hard drive, HDD1 password issue After installing the new HD and at boot up, blue screen occurs I get errors F78da640,...
You've probably got to have your computer configured to boot from a rescue CD before it can recognize and install the new harddrive. Also make sure that there is an operating system installed on the hard drive . If not it will not do anything until you install one. This will be automatic if you install a new XP or Vista DVD into the computer's DVD drive the reboot.
Sep 07, 2009 | Toshiba Satellite A135-S4527 Notebook
Installed new dvd drive installation disk not recognized
I need alot more info than this to solve. Like model,year,kind of drive(ide or sata),operating system & any other relevant info.
Jul 14, 2009 | HP Computers & Internet
Got a new hdd 250gb sata the pc can't find it
I have the exact same system you have and have the same problem. Dell quit supporting that system as far as updates to drivers and BIOS updates before SATA drives became readily available.
The short answer is there is no way to boot to a SATA drive on that system that I have been able to discover. The BIOS does not recognize it as a bootable device.
What you can do is boot to a regular IDE (PATA) drive, install the driver for the SATA drive and Windows will recognize it. Place your Page file on the new drive and all your applications and data on the new drive.
It is not ideal, but I have managed to move the majority of files to the new drive and it runs quite well. You have to be diligent about installing new software to the new drive instead of the IDE drive.
There is a program you can buy for about $15 that will help you move applications that insist on installing to the boot drive called App Mover. I tried the free trial and it works quite well.
If you ever get a better answer, let me know.
Dec 28, 2008 | Dell XPS™ 600 PC Desktop
Hp 6700 vista
HP 6700 laptops use SATA hard drives. Any 2.5" SATA hard drive should work fine.
Vista works with all models of hard drives. You just need to install it onto the drive by booting your vista CD/DVD and installing the operating system on your computer.
Dec 24, 2008 | HP 6700
Unable to boot Vista install DVD on FreeDOS
Your DVD should be bootable -- that is, restart and it should boot off DVD. If in fact you have an installable copy of Vista, and you have a working DVD drive.
If those two answers are correct, restart your computer and immediately figure out how to get into the BIOS -- Normally delete, F1, F2 or F10. Hit 'em all real quick and keep trying, looking also for something like "To enter into system configuration, hit ..."
There should be an entry for boot preference. Just make sure CD/DVD/removable media/ATAPI drives are listed before your hard drive.
Dec 07, 2008 | Microsoft Windows Vista Ultimate Edition
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
Microsoft Windows XP Home Edition Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
