Question about OEM Systems ATX P4 350 Watts Power Supply ( Channel Well OEM ) (PS350) Power Supply
I need datasheet for AT2005 IC
I try to repair the power supply atx p4 350 watts all component around Q ksc5027 is good , transistor c945 is good .
i need schematics diagram for power supply p4 350ATX
i need datasheet IC AT2005
i need troubleshooting to help me to repair the power supply
please help me
thank youuuuu
  • 6 Answers
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
Posted on Sep 07, 2009
  • L? Vinh
    L? Vinh Jul 08, 2010
    WT7520 datasheet here:
    http://www.dianyuan.com/bbs/u/28/1112672...
One reference indicated AT2005 is the same as WT7520. I think WT7520 datasheet has some errors, but have found no one to ask about them. I need schematic of Powork PW-600, using WT7520; and a better WT7520 datasheet.
Posted on Mar 08, 2009
I need datasheet for WT7520 IC
Posted on Mar 17, 2011
Power light goes on (green ) for about 3 seconds then shuts off
the tv have a fault in the power supply circuit or horizontal circuit check the regulator transistor or ic in your power supply and other components there.check the horizontal output transistor in the horizontal circuit and other components around replace what ever component you find faulty and components associated with the faulty component.good luck.
Sep 25, 2011 | LG 42LC2D 42 in. LCD HDTV
I need Power Supply unit ATX-300-12Z CDR for my H Pavilion desktop. P/S HP P/N 51882625
You dont have to replace it with the exact one...just shop around and find a 300 watt ATX power supply. You can find a few good deals around the internet. (tigerdirect.com...newegg.com....etc)
Jul 30, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
What is full meaning of the following codes in design and constructing an inverter-NE55,CD4013,JRC455,A733,IRFP150,1N4007,C945.
These numbers are the identification of some electronic devices that probably are being used in the inverter's circuit:
CD4013 - Dual D Flip-Flop integrated circuit
1N4007 - 1 A rectifier diode
IRFP150 - power MOSFET
A733 (2SA722) - PNP silicon transistor (low frequency amplifier)
C945 (2SC945) - NPN silicon transistor (low speed switching)
I could not find the devices marked JRC455 and NE55 - maybe they were not correctly marked, but there are some devices which have similar designations: JRC4559 is a dual operational amplifier integrated circuit and the NE555 is a time/oscillator integrated circuit.
You can download their datasheets from
http://www.alldatasheets.com
Hope this information can be useful!
Mar 09, 2011 | Electronics - Others
ATX-300-12Z was hit with a power surge (thought we had a surge protector). Green light on power supply blinking at 2X/second. No power at USB devices (or anywhere else.) PC was on when surge hit.
There were 2 Switching power supply circuit inside the ATX PSU. There's a Standy PWM circuit whichSupply +5V to the PWM IC of the Main PWM. Stand by pwm still working or insufficient voltage, lower than +5V. This is the reason you still have Green light. Check or replaced small filter capacitor around 100 MFD 16V, open resistor or shorted diode that was nearest of the PWM IC..
Watch out for charge voltage on big capacitors.
Rleo
Dec 30, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Need a fan for the extreme Power Plus 600w
What a wastage of power ?
I suggest not to fan more but to reduce heat generation.
Better check, why excess heat generated? Surely low power devices overdrived. Just modify it. Like low voltage schottky rectifier. insted of using 20A per channel, they use 3A per channel. Your PCB of SMPS has the hole to cater the proper rectifiers. Just Search the datasheet, replace the overheat component with higher capacity and you solve the problem.
Sometime, poor screwing of heatsink to transistor/devices may generate excess heat too.If you can replace the fan, you must do the other work I recomend. GOOD LUCK.
Jan 29, 2010 | Cooler Master Extreme Power 600 Watt...
HI I have a FSP200-61GT SPI switching power supply with a burned out Mosfet on the high voltage side. There is a (I think)a .5 or 1 watt resistor on both sides of the mosfet. But they test good, my problem...
Please give motr of the devices fixed on same heat sink. Search for SMPS IC like FPS or similar, search their application notes and the datasheet of the nMOS. then you can get idea. without those data Solution is impossible.
Jan 27, 2010 | HP and Compaq Pavilion Replacement 200w...
SCHEMATIK DIAGRAM FOR POWER SUPPLI
I would also have liked to have had a schematic diagram for my ECHOSTAR 450w ATX power supply.
Not having one though, I have replaced two capacitors (one with a bulging top) and another with a leaking top, three rectifiers (two shorted and the third had a cracked case), and have ordered transistor Q1 (also shorted). Will also need to repair trace damage on the bottom of the circuit board. Other components check out OK so I hope it will be working again after the transistor arrives Monday. I need the -5v this one supplies to get my old computer running so I can retrieve last year's tax info.
Jan 17, 2010 | Echo Star 450W 450 Watts ATX Power Supply,...
I need 1001dl datasheet , IC inside DELL NPS-330B B PSU
I've never had trouble getting datasheets. I start at my Yahoo search bar and put in all the information I can and their off. Hit me with exact numbers like ( sn74als244b )
Jun 16, 2009 | Dell Power Supply 330 Watts nps-330cb...
I need ic used in power supply p4 ATX 350 . I need datasheet for integrated circuit ( IC ) the no. of ic is AT2005.
man that going to be amouth impossible to find because is more cheap to buy a new power supply for 25 bocks that going to kill your self trying to repair one sorry but good luck
Jan 30, 2009 | Computers & Internet
HOW DO U KNOW THE CAPACITY OF AN COMPUTER SMPS (unbranded)
Maximum output of any smps is not based solely on the type of power switching transistors used. One of the parameters which will be crucial is the Ic (Max collector current rating). But this by itself isn't the lone determining factor either.
Other design factors which will come into play are the switching transformer, its size and windings. A smaller transformer and smaller wire gauge windings will generally mean lower max power output.
Max power output measurements probably require a set of load resistors, volt and amp meters, monitoring the 3.3, 5, 12 volt lines.
I'm not an engineer, but have had numerous computer power supplies apart, repairing some, junking some. Quality of construction or lack thereof is generally obvious. PC Power and Cooling probably builds high quality units. There are plenty of cheap, low cost power supplies which frequently die after a year or two, sometimes taking a motherboard down with it.
Dec 21, 2007 | Compaq Refurbished 280WATT POWER SUPPLY...
OEM Systems ATX P4 350 Watts Power Supply ( Channel Well OEM ) (PS350) Power Supply Logo
5,825 people viewed this question
Top OEM Systems Computers & Internet Experts
micky dee
Terry Hair
Bill Boyd
Are you an OEM Systems Computer and Internet Expert? Answer questions, earn points and help others
