Question about Vizio P50HDTV10A 50 in. Plasma HDTV
No picture. I get audio, but can't see anything.
My cable company so the problem is with my TV, not the cable?
  • Anonymous Feb 28, 2009
    no picture but i get sound
    New Friend:
  • 56 Answers
Replace the Y Sustainer board will fix the problem. The board cost 135.00, I have the board in stock.
Posted on Feb 16, 2009
My TV brings up message "No Hard Disk Found" and doesn't show pictures
sounds like the hard drive went in the Digital TV box, call your local tv cable company for a replacement.
May 08, 2015 | Audio Players & Recorders
Cable box is plugged into denon's hdm1, but I can't get a picture. Hdm1 out monitor (arc) is plugged to TV hdm1 in (arc).
Power up all components. Select the HDMI 1 input on the Denon amp, and the HDMI 1 input on the TV. Additionally, run the old analog cables between the cable box and the TV. If no picture, select the input on the TV that is associated with the analog input from the cable box. You should have a picture at this point - but it will be a standard definition type. Check the settings on the cable box to change the output from "A / V" to Digital on the HDMI jack - if present. You may have better luck unplugging power / replugging in the cable box first - or calling the cable company if you can't find settings for this. Once you have the output of the cable box to HDMI, select HDMI on the TV. If you still don't have it working - try bypassing the Denon and go directly into the TV from the cable box. Try it with BOTH HDMI cables. Also - try different inputs and out puts (HDMI 2, HDMI 3, etc.). Discard any HDMI cable that fails to show video and play audio.
May 04, 2015 | Audio Players & Recorders
I want to connect my cable box to my newly bought toshiba plasma
Is your cable box HD? It would be best for your tv. You can hook up a couple of ways depending on your receiver and tv in/out capabilities. You will always get best picture if you go directly from your cable box out to tv in. You should have capabilty to go HDMI out and perhaps Component out on your cable box. If you can't get hd receiver from cable company. Anyway, if you use HDMI, hook to HDMI out on receiver to HDMI in on tv. HDMI provides audio and video. You can also go componenet(red, blue, green) out from recevier to in on tv. I personally feel component gives you better picture but , doesn't carry audio. For that you need to get audio using either digital optical or, composite cables. You may have to set your HD on receiver through cable boxes menu. The last option is using composite cables(last choice, poorest picture and sound) yellow(video) and red, white(audio)
Apr 04, 2011 | Audio Players & Recorders
I subscribe to basic cable, the TV has been working fine for a year, however now some channels have no sound at all, picture is fine but no sound. Wondering if the problem is with the TV or cable...
hi, if most of your channels have audio on it and some dont have, there is no problem with your tv, it is your cable company that has problem. The best thing is to give them a call so that they could do somethin about it. Hope this helps, goodluck!
Jun 11, 2010 | Vizio SV470XVT 47 in. LCD TV
My cable TV company is COX. I am getting the
Unplug,replug the cable box for an hour later.Let the box boot up,and upgrade the softwares.Might have go to ur tv menu to rescan all ur channels again.If this don't work call ur cable company might have to change the box.
Mar 30, 2010 | Protron PLTV-32 Television
I spent the last hour on the phone with tech support for my local cable company. after the duration, we came to the conclusion that there was in fact, not a space for the red, yellow and white chords....
Without seeing anything, the yellow=video, the red and white=audio. The yellow/video "output" of the cable box goes to the yellow/video "input" of the TV. The red and white are the audio that go from audio "output" of the cable box to the audio "input"of the TV. I don't know what the Cable company was telling you???? The cables are "RCA" and give you the worst clarity for a picture. If you cable box has three output ports colored Red, Green, and Blue ("Component') and you TV has the same three as inputs, that will make your picture much better. If you can hook it up with the component jacks, you will still need the audio RCA (red and white) between the two units. I hope this helps.
Oct 27, 2009 | Olevia LT37HVS 37 in. LCD HDTV
No picture, but has audio
It could possibly be a protection circuit in your tv that protects it if something is not functioning properly. from what is described, it could be anything from overheating to even a bad power supply! I would have someone look at it. Good Luck!
Jun 11, 2009 | RCA Televison & Video
I have a Star Choice canadian Satellite and hooked up the DVI to the HDMI on my Tv I get a great HD picture but no sound i tried the Audio cable as per the instructions but still no sound will i need a...
dvi is just video. hdmi has both video and audio. dvi is still used because it is a standard for computers.
connect the audio from the audio rca jack to your TV / speakers. If you have surround sound you should use the SPDIF optical audio port - it'll be cleaner and support all channels.
Remember audio has to go to an amplifier or all-in-one box, which goes to your speakers. If your speakers are built into your tv you should be able to plug it in directly and then select the audio channel on your TV. If you plug it in and you still don't hear anything it's a problem with selecting the correct audio input on your TV / amplifier
Dec 06, 2008 | Televison & Video
Best picture and sound
connect coaxial cable connector from your cable service company to cable box-----in jack.
2-using coaxial cable connect cable box out to tv-vhf/uhf jack.
connect projection tv audio out (var-fix)jacks to avr 230 line in.
Aug 22, 2008 | Audio Players & Recorders
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
97 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
