Question about Sony VAIO VGN-AR630E Notebook
Power Switch is not working.Not able to switch on laptop
Power switch is not working.
i tried to swith on the laptop but not able to do that
Power windows work from driver switch. New switch. No power to individual power window switches. Could it be a fuse ?
could be a fuse but more than likely it's the window lock switch being defective or needing cleaned, find a swith assembly at a bone yard.
Sep 14, 2015 | Vehicle Parts & Accessories
2001 Buick Regal. Power door lock swith will not lock doors.
Remove the door panel and unplug the connector to the door actuator. Probe the contacts with a voltmeter set on DC volts. Then operate the lock/unlock switch. You should see the voltage toggle from +12 volts to -12 volts. If you do, then the wiring, switch and connector are good and you have a bad actuator. Be prepared to start replacing all of them because they all operate the same number of cycles.
Jul 28, 2017 | 2003 Buick Regal
2002 thunderbird window won't go up or down replace swith still wont work fuse are ok does the switch get power
The master switch connector does have circuits that have power on them. The Master switch is not directly connected to the window motors. The switch sends a signal to the Front Electronic Module and the module controls operation of the motor on the driver side. The passenger door window motor is controlled by a different module
Nov 28, 2012 | 2002 Ford Thunderbird
How do I switch to normal power when the battery is running out please. It is a Medion Laptop. The battery warning light flashes and then the laptop warns 'switch to power' but I can't find out how to. It...
This might be an indication of a problem related to either the power adapter, the power cord, or the power receptacle in the laptop.
Please refer to the following article for detailed diagnosis & a fix:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Dec 21, 2010 | Computers & Internet
2003 nissan altima took window down and would not go back up.30min.latter it worked.today forgot about it and it did it again.is the switch bad?how can i get the window up for now without the switch?
This may be the switch ,but most times its a motor, try to hold the swith in the up postion and bang on inside of door toward the midlle and bottom while holding switch, ig that doesnt work try to push swith for window to go up useing a little force and wiggle.the best way to find the problem would be to test motor for power and ground while operating the switch.
Jun 15, 2010 | 2003 Nissan Altima
Compaq Presario 700 Series Laptop wont turn on
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Nov 23, 2008 | Compaq Presario 700 470024-192 Notebook
No power
Most times when this occurrs, there is a problem with the power supply inside the unit. It is possible that the motherboard is not telling the power supply to turn on. Any time the computer is plugged in, the power supply provides 5V as a standby voltage. Pressing the power button sends a signal for the remainder of the power supply to start up. If the 5V supply is not present, no action will occur. Try replacing the power supply.
Dan
Mar 18, 2008 | HP Pavilion A520n (DW233A#ABA) PC Desktop
Wireless switch
The switch is located on the front of the notebook, an oblong plastic clear button which flashes orange when working, normally next to a bluetooth button, although this may not be installed.
Aug 29, 2007 | Acer Aspire 3000 Notebook
Sony VAIO VGN-AR630E Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
