Question about Goodman GMS90703BXA Heater
Cycleing hi I have a goodman gmpvo75 it cycles 3to4 times before staying on do you have any ideas. thanks
  • Anonymous Jan 31, 2009
    I have the same problem but not 100% of the time. Some times it runs fine, sometimes in cycles once, sometimes twice. I was told it could be the board but want to make sure
  • 51 Answers
I would start with cleaning the flame sensor. It is a metal rod that will be located in the path of the flame. Please let me know if this helps.
Posted on Feb 17, 2009
Goodman Furnace gms91155dxa not staying on. The system ignites, but shuts off after 3 minutes. 1 blink LED system light
100% sounds like an electrical problem, something is not allowing it to go into a duty cycle.
Dec 04, 2016 | Goodman Heating & Cooling
Fan motor kicking on and off during cycle
The motor may be in need of replacement
Mar 16, 2013 | Goodman GMS90703BXA Heater
I have a goodman heat pump system and the fan turns on and off several times at the beginning of the cycle, but not every time. And sometimes it bangs really loudly but not other times when it is doing...
sounds like it could be an issues with your defrost control board this device allows the fan to shut off during the defrost cycle of operation in cooling the relay is in the closed position allowing power to the fan this relay on the board could have bad contacts a highly suggest calling a contractor that specializes in heat pumps and would also question why a part was replaced and you still have the same problem did they credit you any money back?
Jul 28, 2009 | Goodman CLQ36AR49 Air Conditioner
Flame sometimes stays lit at the flame rod after heat cycle done
Definitly a gas valve that needs to be replaced and get another roll out switch after getting hot a few times they are demaged
Mar 25, 2009 | Goodman Heating & Cooling
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Wash machine stays on wash cycle and doesnt go to rinse or spin
If the water is not getting hot, this will probably stop the programme advancing .Check heater.
Plz rate solution to prob.
Dec 10, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Blower starts ans stops
May be a short in the wiring or a bad control board.
Jul 07, 2008 | Goodman CLQ36AR49 Air Conditioner
Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
Jan 17, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Goodman GMS90703BXA Heater Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
