Question about HP Pavilion dv2000t Notebook
Replace the heatfan in an hp 2100 laptop
Is it possible replace the fan in my hp 2100 laptop.  I need to know how to open the laptop to access the fan.
    Sergeant:
    Champion:
  • 318 Answers
You need a technical manual for this Laptop.
Try going here and sign up and download the Manual you need.
www.retrevo.com
Posted on Jan 30, 2009
Fan making noise
There are 2 possibilities: First, your fan, air inlet and air outlet are dirty/dusty. In this case you can use canned air to clean them up. If the dust become a dust ball, then you may have to open the laptop's base or just need a tweezer to lift the dust ball. The second possibility is the fan is dying (broken). In this case, you need to replace the fan, and it is not easy (you need to disassemble your laptop) to replace the fan.
Feb 17, 2014 | HP Compaq nc6320 Notebook
I bought a fan motor for my hp 2100, when i went to swap it i found the new fan had 1 less hot wire than the old 1. when i installed it, it does not work. could i have bought a 110 motor when i need a 220?
old motor has data needed for replacement. hp, sf ,rotation ,rpm, volts and amps.plus capacitor size required. the extra wire can be for a capacitor conection usaly brown in color and if you look at the label it will tell you how to eliminate the need for this wire.
Aug 21, 2013 | Hayward Heat - Pro 2100 Heat Pump Pool...
One of the speakers sound really bad when volume is raised. Also the area of touch pad and the jack where you connect the head phone gets hot.
About the speakers, you need to replace them with factory OEM speakers.
The touchpad and the headphone outlet will get hot if the laptop is hot inside. You might want to check the fan for dust and clean it. So the heatfan extracts the heat from inside. Avoid using your laptop on a surface without airflow, such as mattresses or pillows.
Jul 30, 2011 | Toshiba Computers & Internet
No printing
Well this issue must be related to the drivers of the printer, possibly incompatibility. Let's try to fix it with the easiest method.
First uninstall the driver after the printer is disconnected from the computer. Then run a registry cleaner (click here to download a freeware registry cleaner) to clear any unwanted registry files. You'll also need to clean the system using the feature with this application.
Now download this driver Hplaserjet 2100 windows vista32 (if your system is 32 bit) or hplaserjet 2100 windows vista64. Extract the files to a specific folder and follow the instructions as follows;
Click "Start" , select "Settings/control panel" and click the "Printers" folder.
Double-click "Add Printer".or click "File" on the menu and select "Add printer"
The "Add Printer wizard" will open. Select "My computer" then click "Next".
Select LPT1 (whether directly connected or networked) and click "Next".
Click "Have Disk".
Click "Browse".
The Locate file window will come up saying a: "is not accessible" . Click "Cancel".
Under "Look in" select the folder where the file is saved.
Highlight "HPLAOUT.INF" and click "Ok".
The Install from Disk window will reappear, click "Ok".
Select "HP LaserJet 2100 Series PCL 6" and click "Next".
Select the "Replace existing driver" option and click "Next". (This window will not come up if the uninstaller was used).
Select Not Shared and click "Next" .
Select "Yes" and then click "Finish".
Please don't skip even a step from the uninstall process. And do let me know when you are done.
Till then, Good luck.
Thanks for using FixYa.
Jun 29, 2010 | HP LaserJet 2100 Printer
I have a Compaq Presario 2100 notebook
first i work for hp laptops and desktop repaire .
second are you willing to lose your warranty for it .
how old is your laptop if think you dont have warranty on it go for it
Apr 14, 2009 | Compaq Computers & Internet
Noisy fan on a Compaq laptop Presario 2500.
Have you tried following the instruction in the Service Manual(pdf) published by HP online?
Nov 30, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
It is quite possible that you need to replace the cooling fan. You can get used parts for this machine on Ebay pretty cheap now. I have seen the fan assy go for about $8-20.00. They are a bit of a job to replace. Just take your time.
Jun 30, 2008 | Compaq Presario 2195US Notebook
Memory upgrade for presario 2100 notebook
Hope this helps . Just follow this steps.
1. Turn off your laptop and turn it on the reverse side. (under the keyboard see picture)c4c84c4.jpg
2. Remove screws and cover .
3. Remove the locks on both ends of your memory (encircled in yellow) . This is done by holding the locks on both sides using your thumbs.
4. While holding the locks gently push the locks away form the memory (sideways)
5. The memory will popout and you may now remove and replace it with a higher capacity.
Note: This is only done if there are no available slots for the new memory. If a slot is still available no need to remove old memory. Just insert the memory on the available slot
Jun 17, 2008 | Compaq Presario Notebook
Compaq presario 2100 modem problems
http://h10032.www1.hp.com/ctg/Manual/c01122313.pdf
It doesn't look like it to me...
Jan 01, 2008 | Compaq Presario 2100T Notebook
HP Pavilion dv2000t Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
