Question about MSI K7T266 Pro2 (MS 6380-060) Motherboard
Hav K7T266 Pro2 motherboard, can not get it to go past turning on
I have tried three different processors with this board, the last being a known good AMD 900 mhz processor. The 4 red lights still stay lit on the board as if the processor is no good. Could something on the board being jumpered or not jumpered cause this. My understanding from the book is it is automatically set a 100 mhz bus speed, but can be changed to 133 mhz in the bios. Please help if you can. Thank you.
  • lorna7456 Jan 30, 2009
    Stephen, I cleared the cmos and now it boots to point of real time clock error. On the motherboard I found sw1 which also says 1-2 for 100mhz or 2-3 for 133mhz, however it has no pins.... The manual says The default hadware configuration for cPU clock freq. is set at 100 mhz. Therefore, to use a 133 mhz cpu and have it run at 133 mhz you need to adjust the cpu clock up to 133 mhz by changing the cpu clock in the bios setup utility.....If I can't get to the bios I can't change it...any ideas???
    Sorry, I didn't see well enough that the monitor did bring up the prompt, For now everything is going well.....Thank you very much,,duh me, not clearing the bios...
    Problem Solver:
  • 5 Answers
to change bus to 133 MHz, you need to unlock the speed by setting a corresponding jumper on the board to assign busspeed by bios. After doing so, you need to clear CMOS and reboot. Next you'll have to set speed and multiplier in bios. Ideally: 900MHz = 100 x 9. Alternatively: 133 x 6.5 If that doesn't help...check if your RAM-modules are any good anymore. When RAM is not functioning, CPU-error code may be presented, since CPU cannot read/write to RAM, therefore not function. Let me know how this turns out.
Kind regards,
Posted on Jan 30, 2009
  • Stephan Hubers
    Stephan Hubers Jan 30, 2009
    Sounds to me like your onboard crystal has died. Therefore there won't be any clock-speed set at all. I once had a K7-board with the same problem. Can't fix that. Will need a new board. If thinking about that new board...I have a Gigabyte K8NS lying here (used with a Sempron 3000+ socket 754 cpu). If you're interested in the board, let me know.
    sorry your board has died... :-(
    kind regards,
Audio, sound card
there you can see 5 white slots you can insert your sound card can youse 4.1 creative sound card only............
Nov 13, 2010 | MSI K7T266 PRO2-A Socket A XP Motherboard...
Audio draiwers no
open goole home page download Driver magician instal after update serch all drives click audio drive opition driver version support relase date
google page open serch driver name version freedownload after instal problem slove its true ............try
Add a comment
Oct 23, 2010 | MSI K7T266 PRO2-A Socket A XP Motherboard...
New ram won't work. Boot up beeping.
There are a few reasons why this might be happening. you have to make sure that you bought the right type of ram. there are a few different ones out there. did the chip fit right in or did you have to work on it for awhile? if it did fit right in then chances are you have the right type. there are different speeds as well. also some systems you have to install ram chips in pairs. 512 and 512 or 1gb and 1 GB. 2 different sizes wont usually work either
May 03, 2010 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
K7t266 pro2 ver:2 the mother board can't be powered on. Could some one tell me how to check it ok please
When your motherboard/CPU board CMOS battery dry or have charge then you can not run to power *********** board.Or CMOS is disable.Please check
1 Power supply
2 CMOS Battery
Mar 15, 2010 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
I hav an abit va-20 motherboard that does not want to display anything. i tried changing the cpu but nothing happens. i even removed the ram just to check if it beeps but still nothing happens. i took...
Are you saying you have tried your processor in two known good motherboards and neither board will work with your processor?
Either your processor is bad or it does not work in those motherboards.
Jun 30, 2009 | Abit VA-20 Motherboard
Msi motherboard
use the booklet that came with the MOBO...i used it and it was pretty user friendly...the acronyms on the MOBO will confuse you
Sep 14, 2007 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
Trying to fix old computer
Disconnect the drive and see if your video card works. If not, something else is broken. Could be the video card, the motherboard, processor or power supply. It is possible for a power supply to fail in such a way that it destroys everything connected to it. If that works, you have made some mistake hooking up the hard drive or it is badly damaged. Hard drives have jumpers that must be set correctly to indicate whether it is a master (1st drive on the ribbon cable) or slave (2nd drive on the ribbon cable). The ribbon cable must be correctly oriented with the red strip going to pin 1 (pin 1 should be marked in very, very small print on the drive's connector).
Sep 10, 2007 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
MSI K7T266 Pro2 (MS 6380-060) Motherboard Logo
195 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
