Question about Philips Universal PH301S Remote Control
Help! I just changed batteries and then...Then I tried to turn on the T.V. it didn't work...We didn't know there was a code for this remote. It's a Philipps Universal! AAAAHHH I need to watch...Please help!
  • 34 Answers
Try here
hope this helps
Posted on Feb 01, 2009
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Mar 24, 2013 | Samsung TV Remote Control
My lg tv suddenly stopped working with the remote? Didn't change anything. Just woke up and the remote would not work. Changed batteries but no luck. Tv works but remote no longer works with it
Visit this site. Type in the site name "Electro-help" in yahoo search box. Pull up older posts there. You will get all details. Codes, setup proceedings etc:-
Jun 09, 2012 | LG 32LG30 32 in. LCD HDTV
Remote quit working for litex ceiling fan
after changing the batteries make sure you didn't change the remote code. If you didn't there should be a reset button inside the battery compartment, it may just look like a small hole. Just use a toothpick and insert it into the hole and lightly depress the reset switch.Replace the battery cover and try using the remote again.
Apr 13, 2012 | Casablanca Fan Dryers
I have a 32" insignia LCD TV. My remote stop
You can reset your remote control by removing the batteries, pressing all of its buttons, and installing new batteries. Also, ensure that your TV's sensor is clean and unobstructed. If the problem persists, try using a universal remote control as a troubleshooting step. This will help identify whether the original remote or the TV is at fault.
Oct 20, 2011 | Insignia IS-LCDTV32 32 in. Television
Didn't recharge, now it says insert batteries when batteries are in place. even tried new batteries
search for models of all types:http://www.espares.co.uk/search/remote-controls/p/1090
It is possible that the remote codes were changed or reset. Remove battery and keep aside for some time , then reinsert and try with the code specified.
Please check on the link below for details on logitech remotes.
http://www.logitech.com/en-in/440/3898?selectedcrid=440&selectedcid=3898&WT.z_sp=Product&osid=&bit=
Sep 14, 2011 | Logitech HARMONY 659 Remote Control
MY TV REMOTE IS NOT WORKING ?
Check the battery of your remote.Try to replace new battery.If didn't work.Try to open and clean the contact of the bottun of the battery.If didn't work, its need to replace the crystal of the battery.Try this sugestion.Thanks
Aug 26, 2011 | Sony KDL32EX700 32 in TV
My batteries died so I recharged them but now the remote will just flash on the tv button. It will turn the volume up or down sometimes. It will change the channel every once in a while but its not...
Hi drembert35,
Try dis-assemble the remote control, and clean it from inside, using Akia Spray or something, but be carefull to not use cleaning fluid which would erase the button connection with the board, so just use spray, and if you don't have one, use the water, and dry it fine before connectng the battaries to it.
and see if the buttons work fine, after doing this, and if not, do this,and don't get surprised,
use a cigarette package paper, the silver paper, and cut a circle from it, in the size of button, and put the conductor side of the paper on the board, on the buttons which don't work with you, and fix it good, then assemble the remote again.
that's if not the 1st soultion of cleaning didn't work.
and Let me know.
Jun 11, 2011 | Philips RC4331/01 Remote Control
The remote for the fan quit working. New batteries didn't solve the problem. The are no strings to pull on/off, just a light switch which does turn on the light.
Just in case, I'll ask, Did you also change the remote receiver batteries, located behind the fan's cowling? If not, that should do the trick. Don't feel bad if you didn',most folks do remember they're there.
Jun 09, 2011 | Hunter Heating & Cooling
Not all the buttons are working on the remote
You may have to change your code. http://www.urc.philips.com/ This link will take you to the Philips Support site where you can download manuals and code sheets for your remote.
Mar 15, 2009 | Philips PM435S Remote Control
Televison & Video Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
