Question about Sony Bravia KDL-37M4000 37 in. LCD HDTV
Power supply tv
Are power supplies for lcd s inter-changable
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    No,
    Each power supply has its own custom design, output voltage so can not be used in other model.
    Problem Solver:
  • 8 Answers
Only between exact same models. Even then some models have several different versions depending on type of LCD panel used. If you have another power supply from the same model and all the plugs are the same you should be fine.
Posted on Jan 30, 2009
My tv is on but the standby button keeps flashing and I cannot do anything with the remote either I've unplugged it and left if for 30 mins
What make and model of TV is this? If its a LCD tv thats more then a few years old chances are its the very common problem of failing capacitors in the power supply. That will usually cause the issue your describing. I have rebuilt dozens of tv power supplies now, the term commonly referred to now is re-capping the power supply. The capacitors become leaky and the voltages go out of tolerance and the tv will no longer turn on. If you can find someone to take it apart and check the power supply board inside that would be your best bet, otherwise its time for a new tv otherwise. There is no simple fix other then repair unfortunately.
May 04, 2017 | Televison & Video
Samsung LCD... Power supply, t-con or inverter?
Samsung LCD TV Repair - TV Won't Turn On - How to ...
? 8:22
https://www.youtube.com/watch?v=n54IurMvr6o
Apr 4, 2014 - Uploaded by ShopJimmy.com
So in this video today we are going to be looking at a Samsung LCD and how to diagnose if you have a bad main or a bad power supply.
Samsung LCD TV Fixing Power Supply Problem - YouTube
? 10:52
https://www.youtube.com/watch?v=F6qgCg8lsxc
Dec 23, 2011 - Uploaded by Studio G Vision
Samsung LCD TV Fixing Power Supply Problem. Studio G Vision .... How switch mode power supplies (SMPS) work - Duration: 19:22.
Samsung LCD TV Power Supply Repair, Capacitor Replace ...
? 25:23
https://www.youtube.com/watch?v=lL0id3-YZsQ
Feb 9, 2013 - Uploaded by HandySavesMoney
... LN46A630 LCD TV. This procedure will apply to several otherSamsung TVs. ... Samsung LCD TV Power Supply Repair, Capacitor Replace, LN46A630. HandySavesMoney .... Country: Worldwide; Restricted Mode: Off.
Jan 27, 2016 | Samsung Televison & Video
60 inch LG Plasma, did have to push the power button 5 to 7 times to get the TV to power up. Now it will not come on at all
The tv before,the tv power supply board already have problems and was slowly dying,that why it require u to pushes 5 to 7 times for the tv power supply board to be able to sustance and hold power for the tv.Now the tv power supply board it is alot weaker or already dead.That why the tv dose not power on anymore.The tv power supply board that the board where the tv power a/c cord plug into it.Try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 06, 2011 | LG 60PC1D 60 in. Plasma Television
Spot of bad weather here, just had a power surge in the house and now our tv (sharp lc-42SB48UT) won't power on. There is no blue or red light on the front and changing outlets/surge protectors doesn't...
90% to 95% ur tv have a dead power supply board only.5% ur tv could have both dead boards the tv power supply board and the main tv Tuner signal board too.The tv power supply board.That the board,where the power a/c cord plug into it.The tv main Tuner signal board,that the board where all the exstented devices and the tv incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first.The tv problems should be fixed.If not than the main tv Tuner signal board is dead too.Must be replaced also.
Apr 24, 2011 | Sharp LC42SB48UT 42 in. LCD TV
I lost power in my house. I cannot get the TV to power up. Is there a reset button? what do I have to do to get power on the TV? All the other components linked to the TV are working.
Now,there is no power to the tv at all?Yes.Tries tv unplug,replug it back like about and hour later.That the resetting tv back to the factory setting.The tv now should be working again.If tv still have the same result,tv power supply board have problems,that the board,where the power a/c cord plug into it.Check the tv power supply board fuse,because u lost main power to the house.If u lucky,the tv power supply board only have a dead fuse,fuse is near where the power a/c plug,plug into tv to get it power.Fuse can buy it anywhere like Radio Shack like $1.50.After u repalced the fuse,if tv still getting the same result,than sorry ur whole power supply board have problems and it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Feb 23, 2011 | Samsung LN52A850 52 in. LCD HDTV
Tv little green light is blinking but tv won't power on
Ur tv power supply board it dead.The power supply board,that the board the a/c power coard go into it,that ur tv power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replament.
May 26, 2010 | Dell W3000 30 in. HD-Ready LCD Television
Sanyo lcd tv blinking
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 02, 2010 | Sanyo 42 in. LCD TV
Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Apr 02, 2009 | Vizio L32 32 in. LCD HDTV
Sharp Aquos LC-30HV4U
replace the supply board
or repair it *** there's problem with supply
Jun 13, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Sony Bravia KDL-37M4000 37 in. LCD HDTV Logo
66 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
