Question about Air Tools & Compressors
Ingesoll Rand 4000
I have an Ingesoll Rand 4000 Model # ra5e6va. What type of oil does that compressor use?
Bruce
  • 405 Answers
Http://air.ingersollrand.com/manuals/Default.aspx
Go here, If this helps you please vote me fixya..
thanks
Posted on Jan 31, 2009
WILL T21 SELECT OIL WORK IN A MODEL 2475
The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
Jun 25, 2014 | Ingersoll Rand - Rand Type - 30...
Type oil compressor
non detergent 30w
if you mean what kind of oil for the pump
if not, what do you mean ???
Dec 11, 2013 | Ingersoll Rand - Rand Type - 30...
Oil in lines from t 30 rand
Dear,
First check the Scavenging line is OK, It should create a well vaccume, If this is OK then you required to replace the Oil separator.
regards
Ashfaq
Jun 30, 2010 | Ingersoll Rand - Rand Type - 30...
Model 2545 compressor getting toomuch carbon deposit in side the cylinder
You can try switching to a full synthetic compressor oil to alleviate the problem.
Carbon is caused by the over heating of oil. Your problem is most likely an undersized compressor, or worn valves and piston rings.
Regardless of the problem synthetic compressor oil will help.
Hope that helps,
under_psi
May 16, 2010 | Ingersoll Rand - Rand Type - 30...
What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
May 10, 2010 | Ingersoll Rand - Rand Type - 30...
WHAT TYPE OF OIL CAN I USE IN MY TYPE 30 COMPRESSOR
I am sure Ingersoll Rand would like you to use there all season select synthetic oil, or you can use a good quality R+O 100 oil, also known as SAE30 non detergent. do not use cheap oil for gas engines,,, buy a good name brand from a regular oil distributor, and specify yo are using it for an air compressor. and most manufactures will recommend you change it every 3 months.
Jan 08, 2010 | Ingersoll Rand - Rand Type - 30...
I have a ingersoll rand air compressor rand 4000 60 gl vertical 230v model #ra5e6va serial #dc90177-0025 i am wanting to know what cylinder head torqe is for the compressor.the head gasket leaks oil and...
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Oct 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Air Tools & Compressors Logo
2,023 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
