Question about Sony Playstation 3 (PS3) Console
Ps3 help how do i hook my ps3 up to my wireless router
    Problem Solver:
  • 21 Answers
This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Set the method for connecting the system to the Internet. Internet connection settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet wirelessly.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
Confirm that an Ethernet cable is not connected to the PS3™ system.
Select ps3 help - in_networkset.gif (Network Settings) under (Settings) in the home menu.
Select [Internet Connection Settings].
Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
Select [Easy].
Select [Wireless].
connectwireless001.jpg 7.
Select [Scan].
A list of access points within the range of the PS3™ system is displayed.
Depending on the model of PS3™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
connectwireless002.jpg 8.
Select the access point that you want to use.
An "SSID" is an identification name assigned to an access point. If you do not know which SSID you should use or if an SSID is not displayed, contact the person who set up or maintains the access point for assistance.
connectwireless003.jpg 9.
Check the SSID for the access point.
Select the security settings that you want to use.
The types of security settings vary depending on the access point. Contact the person who set up or maintains the access point for information on which setting to select.
connectwireless004.jpg 11.
Enter the encryption key.
The encryption key is displayed as a series of [*]. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
Depending on the network environment, additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
Save your settings.
Test the connection.
If you select [Test Connection], the system will attempt to connect to the Internet.
Confirm the connection test results.
If a successful connection has been made, information on the network will be displayed.
  • If the connection fails, follow the on-screen instructions to check your settings. Also refer to the information from your Internet service provider and the instructions supplied with the network device in use.
  • If you test the connection immediately after selecting [Automatic] > [AOSS™] in step 7, the router settings may not be completed and the connection may fail. Wait approximately 1 or 2 minutes before testing the connection.
Posted on Jan 31, 2009
5 Suggested Answers
  • 182 Answers
SOURCE: online hook up
hi ive got my ps3 hooked up with a wireless conection so feel free to ask any questions. you need a wireless hub to send out the wireless broadband signal. is your pc set up with a wireless connection to broadband?
Posted on Jan 07, 2008
  • 61 Answers
SOURCE: PS3 and router
You need to make sure that both your router and your ps3 IP settings are set to DHCP or Automatic
Posted on Jan 09, 2008
  • 50 Answers
SOURCE: ps3 probems with usb router
Plug the router into the modem provided by your internet service. Then hook up the router to your comupter with a wire. Then go to settings connections on the PS3. then hit find networks. It should find your. Follow the on screen intructions.
Posted on Feb 24, 2008
  • 7 Answers
SOURCE: my ps3 cant find my wireless network anymore
get your router name and go through manual setup, your brother may have accedentally made your wireless network hidden, to change that go to or .0.1 and log in and chang the settings to default
Posted on Sep 27, 2009
Testimonial: "i called belkin and they had me reset the router to original settings. the address admin942 gave was very helpful. thank you!"
Cant hook up my ps3 to my netgear wgr614 n150
need to get ps3 component cable that can hook directly to the router,if it is a wireless router goto ps3 setup menu,then turn on network discovery on ps3,then will ask for password from router fill password in,it will hook up.
Dec 21, 2012 | NetGear WGR614 Wireless Router
My ps3 cant find my wireless network anymore
Sep 27, 2009 | Sony Playstation 3 (PS3) Console
Can't connect my PS3 to a Linksys Wireless-G BB router
What type of encryption are you using for your router. I am hooking up my son's PS3 to the wireless. I'm also a computer, network, and server technician. I may be able to help.
Jul 29, 2009 | Linksys Wireless-G WRT54G Router
Are you using a router? s133pyh34d is assuming you're even using a router. You can not hook up a PS3 directly to a modem like you can a computer. Wired or wireless, you need a router
May 01, 2009 | Sony Playstation 3 (PS3) Console
Trying to get online with ps3
Your PS3 should hook up fine to a wireless router if you input the correct SSID(network name) and WEP key. No ports have to be set to open for your PS3
Jan 15, 2009 | Linksys Wireless-G WRT54G Router
Sierra Wireless AirCard 595U And PS3
I understand that you want to connect the PS3 using the Wireless card and NETGEAR card. Please note that the setup you have will not work for internet access. You can not configure the Air card to work with NETGEAR router. you need to have wih a broadband connection available for this router to connect to internet.
Once you have the router configured with Internet access then you may either connect the PS3 wired or wireless to the router, like you connect a desktop or laptop to the router.
Jan 12, 2009 | NetGear WGR614 Wireless Router
Hooking up wireless router to ps3 to get internet thru TV
i believe what you mean is your connection to your ps3 not on your tv
actually i think ps3 has a built in wireless adapter unlike xbox360
things to remember:
-make sure that you use compatible routers
-distance of wireless router from ps3 may affect the signal of internet
-actually, some devices like microwave or chordless phone may also interfere with youre connection
-if you are using a direct modem connection, you may need to call your isp to check if the firmware of your modem is up to date
-there is more to life than games so try to do some sports if you are not able to connect ^_^
hope it helps
Dec 29, 2008 | Actiontec GT704WG Wireless Router...
You can't. For wireless connection on the PS3 you need to have a wireless router hooked up to your modem. Once you have your wireless network hooked up with your PC. You can give your PS3 access and the PS3 will scan for any available wireless networks. Google will help you more if you need more detail on how to set up your PS3 wirelessly.
Sep 10, 2008 | Sony Playstation 3 (PS3) Console
I need help with my ps3
did you hook the ethernet cable from the modem to mthe back of your ps3(wire internet)
do you have a wireless router(wireless internet)
are you trying to hook it up wire or wireless
Feb 19, 2008 | Sony Playstation 3 (PS3) Console
Cant find access point
do you have anything else on your wireless router using the wireless?....Does a laptop with a wireless card hook to your wireless setup and surf the net?...
Dec 29, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
96 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
