Question about LG LHY-518 System
I have an LG 518 System after 1 year i cannot get the sound
  • gscornett2 Mar 21, 2009
    the sound does not play
  • pkaraya Apr 17, 2009
    Replaced the system connection cable but still no sound at all.Where are the fuses located?
Cant get subwoofer to work on LG LHY 518 system
Posted on Mar 13, 2011
Have you either replaced system connection cord or any fuses
Posted on Mar 21, 2009
When I play my DVD and wacth movies, I cannot lower the base/woofter without lowering the volume to the point were I cannot here the voices. Once I raise the volume to here the voices, the action seean...
You don't indicate if the various speakers all sound normal and equal in volume with the test tones, which is where we should start.
Page 25. I would advise setting all controls to nominal (0 dB) and assessing the relative loudness without adjusting them. Then choose the one(s) in the middle, loudness-wise, and adjust the rest up or down to match it.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/LG-LHY-518-Home-Theater-Systems-manual/id/366ag212/t/2/
Jun 03, 2011 | LG LHY-518 System
I need remote codes for a lg dvd recoder combo model number LHY-518
hello after a long search through the net the only solution to retreive the code is through LG themselves you will need to send them an email with your dvd model they will email you the code
another solution would be to purchase a all in one remote this i think would be best as the codes come in the manul goodluck
Mar 28, 2011 | LG LHY-518 System
I have an LG LHY-518 home theater system. It was given to me and I need to replace the subwoofer connector cable. Anyone know where I can buy one?
I am looking for an LG LHY-518 subwoofer connector cable also... have you found where to find one yet? You can E-mail me at smt0471@yahoo.com thank you
Mar 21, 2011 | LG LHY-518 System
I have a LG LHY 518 system and the subwoofer doesnt work. Can I replace it with any LG subwoofer?, or do I need a certain kind of LG subwoofer.
I'd lurk on eBay or other auction sites and see if one becomes available.
LHS-95PAA
Take a clue from that non-standard system cable between the electronics and the sub. It powers the sub's amplifiers and carries signals. Wanna take a chance on the pin-assignments being consistent across all product lines?
Mar 13, 2011 | LG LHY-518 System
Need manual for model lhy518 p/n 3850r-m500a email: springbrook@hsccommunities.com malachi johnson apt c104
The manual for a LG LHY-518 Home Theater System can be found here:
Mar 10, 2011 | LG LHY-518 System
I purchased an Avid Screen Gazebo several years ago and misplaced the instructions. I have tried to look up the instructions on line and call the number on the tag with no success. I am trying to find...
Are these the numbers you've tried?
AvidOutdoors.com
P.O. Box 5932
Albany, NY 12205
Phone: 1-518-453-2436
Fax: 1-518-453-0053
E-mail: mail@avidoutdoors.com
Business Hours: 9:00 AM - 5:00 PM Eastern Time M-F
Jul 02, 2010 | Garden
LG HT502 wont recognize hdmi cable. it says hdmi
go into the video setup menu, and select HDMI set up and select "ON" that should do it
Jul 15, 2009 | LG LHY-518 System
LG LHY-518
I had the same problem. Also, the disc tray had issues opening if there was no disc in there. The problem was two fold... I think.
1) It was kinda dusty inside the machine and needed a good air can dusting. Get around the tray but be careful not to turn the can upside down and freeze components. I also ran a lens cleaner disc several times.
2) The tray top (only visible with the system open) was starting to warp... likely because the build up of dust was creating too much heat, also causes issues in reading discs... I created a make shift cushion that I taped to the top of the plastic tray that was depressed when the top of the machine was placed back on. This required several tests as if too much pressure was applied, the tray wouldn't open at all and I got read issues in the middle of playing a disc (possibly an alignment issue of the lens caused from the pressure). I finally got a good system where I occasionally have push the top with my finger to open the tray only if it was empty so my padding (made from gauze and gauze tape) was barely getting pressure. Again, this took about 30 minutes of trial and error to get it right. The heat and the displacement due to the warped cover could have caused read issues.
I don't know if either or both of these were the cause of the problem but I can safely say that I have no issues now and yes, prior to this, I slowly went from 100% reading discs to almost 0%.
Sorry for the winded response but this saved me from buying a new system and may save you. Good Luck!
Dec 30, 2007 | LG LHY-518 System
Express Freeze Bell Going Crazy
Wow, almost a year later but here goes;
I use combinations of buttons to disable/change settings on my LG. To disable the bell press and hold Express Frz then press and hold Filter until the display 'flashes' once, the bell should cease.
Aug 25, 2007 | LG LRSC-26922 Side by Side Refrigerator
LG LHY-518 System Logo
279 people viewed this question
Top LG Audio Players & Recorders Experts
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
