Question about Samsung 793S 17" CRT Monitor
Screeen went blank after changing resolution and hz appeared
I was trying to change resolution of monitor , while the screen went blank and the letters [ Hz ?] appeared on screen. I have pressed ctl+alt+ del, restarted computer several times but nothing happened . I have also pressed F8 several times , nothing happened. Plz help.
Refresh set to high boot safe mode change settings.
this has worked for me and XP.
Don
Posted on Jan 30, 2009
How to change the resolution
  • Native Resolution - 1280 x 1024 at 75 Hz
  • To change your screen resolution
  • Open Screen Resolution by clicking the Start button , clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
  • Click the drop-down list next to Resolution, move the slider to the resolution you want, and then click Apply.
  • Click Keep to use the new resolution, or click Revert to go back to the previous resolution.
  • if not display come pls select esc button to revert resolution.(don't press Enter)
Jun 15, 2014 | Samsung Syncmaster 730B 17" Flat Panel LCD...
I TRIED TO RESET THE RESOLUTION. THE SCREEN WENT BLANK AND THE MESSAGE ON THE SCREEN SAYS IMPUT SIGNAL OUT OF RANGE
I believe the max resolution this LCD can support is 1440 x 900 / 75 Hz. If you set your display resolution higher then that, you will receive the input signal out of range error. Your LDC turns off to protect it self from the invalid settings. If you can not change it back once your PC boots to windows, you may have to do it in save mode by pressing F8 once you power on your PC and before the windows loading screen starts.
Regards, Chris
Jun 29, 2011 | Hannspree 19" Widescreen LCD Flat Panel...
The right hand 1/3 of the screen is blank. Cannot get anything to display
sounds like you have to set the monitor resolution using your computer. right click desktop... graphics options. or Properties. look for Resolution slider. Move it around. press apply. see what happens. if it now fits but is fuzzy. change the refresh rate eg. 60 Hz or 75 Hz. On the monitor itself there is typically a button that allows you to move the image to fit the screen, quite often these settings are inadvertently played with by children ect. look for buttons/ menu's on your monitor itself. play with the settings .
Aug 24, 2010 | E-Machines eMachines Monitor E15T4
Monitor went black after changing resolution
Reboot you computer and spam F8 until you get the option to boot in safe mode then choose VGA safe mode or safe mode with network is fine also and change the resolution back
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
Monitor screen went blank after changing resolution
Try unplugging the monitor and then restart, and then go back to default settings.
Monitor power indicator blinks but doesn t show desktop.
you have to put the proper secreen resolution. you do these
1. you checked it with another pc when it shows the screen then change the display properties screen resolution as minimum lke 600X800.
2. you also change the screen refresh rate to 60 Hz to solve this problem.
ok
thanks
Nov 13, 2008 | Proview Computers & Internet
Relisys Monitor model TL528A - Plug it in, screen is blank panel light is yellow. push ON button and I get a 5 second message stating: OUT OF RANGE HS: 53.5 KHz VS: 84.8 HZ WORK RANGE ...
It normally means that you have connected the monitor to a computer whose resolution and frequency are beyond the range that this monitor are capable of.
To fix this, you can do one of two things: reconnect the old monitor and reduce the resolution to 800 by 600, which every monitor can handle and then reconnect the new monitor and change the resolution settings again. by default, Windows will restrict you to only settings that the monitor can handle. The second option would be to start your computer in safe mode (F8, just before you get the windows screen during boot). and change you monitor settings that way, rebooting afterwards.
Jul 10, 2008 | Computers & Internet
Samsung710v
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1280x1024 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab.
Mar 25, 2008 | Samsung 710V 17" LCD Monitor
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
Samsung 793S 17" CRT Monitor Logo
170 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
