Question about HP P2360AA Keyboard/Mouse
I can't type numbers using my numbers pad.
My keyboard is HP. It has a NUM LOCK button that just makes two noises -- on and off, I assume. There is no light to show if NUM LOCK is one. Somehow it must have gotten turned off. I have tried every key combination I can think of, but I still can't type numbers using my key pad. I have read "fixes" that mention using a Fn key. I don't have one-- just Fn with various numbers.
  • 61 Answers
Have you tried shift and num lock
Posted on May 15, 2009
How to work key pad
Key pad? Do you mean the keyboard or what?
Mar 21, 2016 | Dell Inspiron 1525 Notebook
Num lock not working. number keypad not working. keyboard numbers are working.
Press the num lock button - usually the top left hand button on the keyboard numbers on right hand side of keyboard.
Mar 02, 2016 | Logitech Computers & Internet
I am not able to work with my keyboard function keys and num keys and function keys . but the the touch pad key is onlyworking .please send a solution to unlock the keyboard. hp pavilion g6-2102tx
Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
Control Panel\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon. Hope this helps.
Dec 10, 2012 | Computers & Internet
I can't type on my compaq nx9010. (num lock led is on)
If you have a external keyboard available this would probably get you out of a jam so long as there are no other issues with the laptop. The computer keyboard will need to be replaced since it is locked down.
Mar 30, 2012 | HP Compaq nx9010
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
Keyboard Produces Numbers Instead of Letters when Num Lock key is on. For example here is what I get when pressing the keys from Q all the way over to the \ key on that row of keys when I have the caps off...
I have the same problem. Click the Windows start button. At the bottom is a Windows Serach box. Type 'keyboard'. A virtual keyboard appears. Click the NumLock key on the Virtual Keyboard. This should override the issue you are having and your keyboard and keys should now work. Otherwise reboot!
Feb 16, 2010 | HP Pavilion DV9910US Notebook
Where is the sterling pound sign
To get character: £ then press down and release the Num Lock key (To make num lock on) located in the upper left part of the number pad on the right side of your keyboard so that the LED above is lit and release that key. Then hold down the Alt key and type 156 using that number pad. you will get pound sign Let me know if this helped Regards
Nov 26, 2009 | Acer 91.63X07.001 Keyboard
The keyboard on my laptop has numbers and keys on it
It sounds like the Num Lock is on.
Depending on the make of the laptop there is a few different ways to turn it off.
Either just hit the Num Lock key and see if it goes off, hold down Fn and hit the Num Lock key or hold down the shift key and hit the Num Lock key.
Sep 22, 2009 | Computers & Internet
No keyboard instructions
You need to press the Function button, then the num lock button. The function button may be labeled FN or F in a different color, the same color as the num lock button.
If that doesn't work, go to start, all programs, accessories, accesibility, on screen will display a regular keyboard on your screen, then click on the num lock key on that keyboard.
May 24, 2009 | Compaq TC1100 (/) PENTIUM M 753 1.2GHZ...
The num lock key controls letters on regular keyboard.
Let Number key stay off then you could use normal 1234567890 that is between QWERTYUIOP and F1-F12
May 22, 2009 | HP Pavilion DV9920US Laptop
HP P2360AA Keyboard/Mouse Logo
2,361 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
