Question about Technics SL-MC7 110-Disc CD Changer
CD CHANGER BROKE
THE CD EJECTOR GOT JAMMED. NO CDS CAN BE READ.
  • phonecall Jan 13, 2008
    I have a SL-MC7 C.D. player. When ever I place a C.D. in the single slot, the C.D. player will plays the disc. When ever I place C.D. in slot one to one hundred and ten, the machine would not pull the C.D. into the transport or the piece that plays the C.D. The front display on the machine keep showing no disc. I can heare the machine tring to locate the disc.This process will last for 20 seconds and then the machine will show no disc on the front display. Can someone help me with this problem?
  • fournotrump Feb 13, 2008
    I also have an SL-MC7. I (stupidly, I know) moved the unit while CD's were still inside. It says 'checking disks' and then just sits there.
    The door won't open up more than 1/2". I can see that lots of disks are out of place. I would like to 'override' and be able to open the door to gently put the CD's back in place, or open it up. Ideas? Thanks.
Have the same problem only mine does it on all slots. It appears the finger which removes the disk from the tray does not slide foward to "pick" the disk. Don't know why, tried to pull it and it will not move foward I was hoping this sight might have some sort of exploded view of the linkages but doesn't.
Posted on Feb 16, 2008
SOURCE:
My RF 6 Disc Changer just stopped playing any CDs. Just reads E. What do I do??
is it jammed? remove the CDs, blow in some compresed air to knock out dust and try it again. if the CDs are stuck then its a whole other issue.
Sep 02, 2015 | Car Audio & Video
I have a 2001 chrysler town and country. cds got stuck in the 4 cd changer. I took the player out, removed the cds but now cds wont go in all the way and the display reads err. radio works fine, tape...
Sounds like the ejector has become jammed, probably from repeatd failed attempts to eject the stuck cd's.
There isn't much you can do about it, repair on that unit will probably cost more than a better aftermarket replacement
I’m happy to assist further over the phone at https://www.6ya.com/expert/gregg_78ecbb34e27be215
Jun 11, 2014 | Cars & Trucks
2004 GTO will not eject CDs, says CD mech error.
I just had this happen the other day. It completely jammed up. I ended up having to remove the radio and disassemble the upper changer section to get the disks out. The problem with mine was that one of the disk trays broke and jammed the mechanism. I ended up gutting the changer and and reassembling the radio and installing it in the car to use the AM/FM function. I'm currently in the search for a new radio to swipe the CD changer off of since even radios that you do not have the security code for will work as the coding is in the radio section and not the CD changer. The changer attaches to the top of the radio with 2 T8 and 4 T10 screws and connects with a ribbon cable between the two modules. You'll see the ribbon cable when the top CD changer mechanism. Be careful removing CDs this way as if the player's rotating assembly is not retracted, it is very easy to scratch the disk. Unfortunately I lost a Velvet Revolver disk this way. Good luck! If you are on one of the the big boards I go by TR GTO on both if you need to contact me and I'll walk you through it.
Jun 23, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
It doesnt open and cant read the cds inside.
Remove the cover lid and look inside for anything jamming disk tray, problem may be very simple once you look at this. change out some of the cds.
Apr 09, 2010 | JVC XL-F254BK 5-Disc CD Changer
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
Jammed cd player - 2002 Honda Accord
I have a 2002 honda accord with the 6 disc cd changer. I beleve the cd changer has jamed and have lost power to the CD player. When I press the CD button it wont recognise the player. Any suggestions
Oct 23, 2009 | 2002 Honda Accord
CD Changer not reading CDs
2000 bmw 528i,my cd changer also reads no cds,this seem to be a common problem with all bmw cd changer.Anyway i removed the cd changer from my car,took the outside black cover apart only to see that a white big wheel came of its place,(its the wheel that holds the cd in place from the top (bottom wheel is black attached directly to the motor,as the cd is sandwitched between the black,and white wheels) .if that wheel is out of place the cd will not turn inside the changer for the eye to read it,so your radio screen will read NO CD OR NO DISC.Very easy fix,just place the wheel in its place,and everything worked fine,it took me 20 minutes to fix.
p.s :
1- you do need to make sure you have an original cd in for testing it.
2- you do not need to recode your cd changer at the dealer if you have an old bmw,dealer will need to recode cd changers for 2006 and up.
Good luck.
Jun 15, 2009 | 2001 BMW 3 Series
Bose Wave Music Sys & 3 CD Changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will probably have to be disassembled to get the CD out or have it serviced.
Dec 23, 2007 | Bose Wave music system Multi-CD Changer...
CDs will not load
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Nov 08, 2007 | Alpine CHM-S630 6-Disc CD Changer
Technics SL-MC7 110-Disc CD Changer Logo
182 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
