Question about Toshiba M24F51 24 in. TV/VCR/DVD Combo
Toshiba m24f51 has horizontal lines at top of screen
Tv/vcr/combo has 3 inch section of horizontal lines at the top of the screen only....has them on all modes...cable or movies...never goes away...everything else seems to be working okay...any suggestions, please?
Thank you
  • 275 Answers
SOURCE: toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Posted on Sep 06, 2006
techman
  • 3130 Answers
SOURCE: Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Posted on Oct 08, 2007
skippy101
  • 143 Answers
SOURCE: Toshiba TV?VCR combo problem
you have bad caps in the vertical curcuit if you open it up you will see a smallmetal square ground sheild in there you will find two red caps look at them very carefully one will be wet it is leaking replac it
Posted on Nov 02, 2007
pishta68
  • 593 Answers
SOURCE: connecting dvd/vcr combo with tv and digital cable box.
You trying to put the DVD/VCR combo between the cable box and the TV? OK, cable out goes to vcr in, vcr out goes to tv, I think you got that. Now there should be a tv/vcr button on the vcr/dvd, you need to press that when the unit is on. Also, make sure you are on the correct input on both the vcr and the tv, usually video 1 or AUX and choose line in or L1 on the vcr/dvd. If the tv/vcr button is toggled, itll completely bypass the vcr/dvd player.
Posted on Mar 03, 2008
Mike1963
  • 8 Answers
SOURCE: WHITE LINES
Replaced C407 100uf/35V Vertical section.
Posted on Mar 04, 2008
I have a tv that has line going side to side
The line is horizontal but means no vertical deflection (set deflects picture from middle to top and bottom.
Either bad solder connections at vertical output chip or a bad part somewhere in that circuit.
Jun 16, 2012 | Toshiba 26 inch HD monitor TV, DVD and VCR...
Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
WHITE LINES
Mar 03, 2008 | Toshiba 27A33 27" TV
Horizontal line (with about an inch of picture)
check a capacitor on the horizontal section
Oct 28, 2007 | Toshiba 27AF43 27" TV
Screen white line problem.
There are two capacitors in the vertival output circuit that need replaced
Oct 19, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Toshiba M24F51 24 in. TV/VCR/DVD Combo Logo
27 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
