Question about Panasonic NN-T993SF Microwave Oven
The microwave does not work.
LCD display is working and shows setting only from power, timer and automatic minute bottoms but the others buttoms do not work and do not show any thing on LCD and the microwave never start working. Do you have any solution please?. Note: My microwave is PANASONIC, model: NN-T795SF, type S333 I checked the switches and they are OK.
  • patelbhavesh Jan 27, 2009
    I have Electrolux EMS2185 fitted microwave.
    The LCD seems working find showing clock, timer, child lock ect. but the start button does not turn microwave on. when i open door bulb is not working too.
I just bought the Panasonic type S333 microwave. Inside there is a flap covering a vent and its screwed down. Does this need to be removed ?
Posted on Jul 31, 2009
I'll tell you what I did: I disasembled the kid pad and checked all the kids. Some circuits were opens. I soldered a microswitch substituting the star kid and now I'm using my microwave. Thank you for your attention.
Posted on Oct 02, 2007
    Champion:
  • 225 Answers
Check control circuit and related control panel circuit
Posted on Oct 01, 2007
2 Suggested Answers
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
MicrowaveSvc
  • 9156 Answers
SOURCE: The microwave does not work.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
You may have a failed keypad or control board.
We repair these for customers nationwide with our guaranteed $39.95 service.
Posted on Aug 08, 2008
How can I to set clock on Sanyo Microwave EM-C678
1. Open door
2. Press clock/Kitchen Timer button the display will show "0:00" with the hour"0" flashing.
3. Enter the correct hour by turning the potary dial. Enter 1-12
4. Press clock/Kitchen Timer button the display will show "0:00" with the minutes "00" flashing.
5. Enter the correct minutes by turning the potary dial. Enter 00-59
6. Press clock/Kitchen Timer. The colon will remain flashing.
7. Close the door.
Sep 03, 2014 | Microwave Ovens
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Above Range GE Microwave not heating
Try disconnecting the power line from the microwave ad then reinstalling it after a few minutes.. then try heating up a small cup of water.. allow 1.5 minutes on high power. it should get very hot or boil.. if it doesn't get warm or hot then you may have a bad magnetron ( the tube that produces the microwave energy that causes things to heat up or a bad filament transformer that is required for the magnetron to work.In either case, if it fails to heat anything, I would go back to home depot and insist they send someone out to address the problem. many of their appliances come with a one year warranty but you might want to call the store and ask someone there about normal applaince coverage ( less extended warranty) and what they normally offer. An inquiry costs nothing..
Hope this helps..
Sep 17, 2008 | GE Microwave Ovens
Aug 07, 2008 | Whirlpool GH7155XHS Microwave Oven
GE xl 1800 beep
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jul 10, 2008 | GE JVM1660 Microwave Oven
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Quit working
SE probably means a sensor error.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Otherwise, it may have a problem with the control panelm such as moisture or contamination or a bad connection.
Let us know if the hard reset doen't fix it, and please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 12, 2007 | Samsung SMH7178STD Microwave Oven
Panasonic NN-T993SF Microwave Oven Logo
1,954 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
