Question about Panasonic PT-53WX42 53" Rear Projection Television
Panasonic PT-53WX42F Power light is blinking 3 times
TV just went off and will not turn on , power light blinks 3 times
  • 296 Answers
Your tv is shutting down and going in to a protection mode to protect itself from damage. The light blinking 3 times represents high voltage shutdown, usually occurring in the convergence IC's and support componets of the tv. It is known as a common problem. Sorry its not a consumer fix for its a major fault in the circuitry. But if you have knowlage it can be repaired. If you take it for repair it will usually run about $300 to $400.
If you try to work on this kind of tv precede with caution because they are high voltage.
Posted on Jan 30, 2009
    Brigadier General:
  • 8,619 Answers
If it is blinking three times if so its a convergence problem -your set uses stk392-110 i usually replace with stk392-150 or stk392-180 these are more stable. if you have no soldering experience or electronic experience. but if you want the challenge go for it. remember that there can be several thousand volts in this set even when unplugged.
  • 716 Answers
If You Unplug The Unit And Plug It Back In Will The Unit Work For A Second?
  • 10,594 Answers
Its convergence failure problem and causing 3 time blinks.
TV requires replacement of STK392-110 to fix it.
    Sergeant:
  • 250 Answers
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672
    Sergeant:
  • 378 Answers
Its the power supply boaRD problem.the board has to be checked with a meter.
Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-56WX33/red light blinks 3 times ovr-n-ovr
It's one of two things, a bad chipset, or bad lamp. 200-250 repair. Hope this helps
Jul 07, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
Can you post how many blinks the power indicator is blinking as that is an error code such as 3 blinks means Convergence circuits.
Mar 02, 2009 | Panasonic PT-51HX41 51" Rear Projection...
No sound, no picture, power light blinks
i have a model #pt-53wx42f when you first turn the t.v. on it gets shakey and distorted then it shuts down and the power button light starts flashing
Sep 06, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic TV not working
The Led should be blinking a certain number of blinks before pausing. IF so what is the number of blinks?
Mar 11, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Power problem
I have the exact same symptom model# PT-53WX42F. Bought new in 2002. Turns on for about 5 seconds perfect picture, then turns off. Power light blinks 3 times then repeats. Any guesstimates for repairs?
e-mail me at "nikao2-at-sbcglobal.net" thank you...!!
Oct 23, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
218 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
