Question about Vivitar ViviCam 35 Digital Camera
Computer not seeing driver - Vivitar ViviCam 35 Digital Camera
    President:
  • Vivitar Master
  • 1,734 Answers
You can get the software from http://manualfox.com
Just send them a request.
Posted on Mar 28, 2009
How can I active USB Port and Speaker port on the Keyboard Model KL-7mu after installing its driver? (All of Hot Keys work) Thank you in advance
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them
Click start control panel keyboard you can change your settings there
click start control panel administrative tools computer management device manager scroll to keyboard you could see a yellow/question exclamation mark? ! or a red X right click to install drivers
click start control panel keyboard hardware then properties you should see driver details and have options to,update driver,roll back driver,uninstall
if your computer came with a motherboard disc the drivers could be on it
hope this helps you
Oct 15, 2011 | Compaq Keyboard
Driver not intall
Right click my computer, Then click manage, & click device manager, You can see see her the yellow question mark not install (missing driver) of your computer : download & install free driver of dell vostro 1510 laptop computer pc notebook, Then download & install individually your not install driver, if your connected thru internet, if you are not connected get a computer technician or bring your notebook to the computer shop services to and tell to download your driver.
Jun 03, 2011 | Dell Vostro 1510 Laptop
My computer doesnt acknowledge my wireless mouse or keyboard
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
click start control panel administration tools computer management device manager scroll to keyboard you might see a yellow question mark ? right click to update driver
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel keyboard hardware then properties you hould see driver details and have options to,update driver,roll back driver,uninstall
diconnect the keyboard then reconnect it then reinstall the driver
make sure the lead has a secure seating if applicable or the usb device
hope this helps
you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
May 17, 2011 | Acer Televison & Video
Computer doesnt recognize the mps. supposed to go to my computer and see a driver for gpx. its not there
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Apr 14, 2011 | Computers & Internet
I can't see files from that was put on the cruzer micro 2GB from one computer to the other.
on the computer that you cant see the files
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Mar 25, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I plug my hard drive into the computer and u can see the safely remove hardware sign at the bottom right of the computer but it doesn't show up on My computer and when i open other programs while the hard...
hope this helps
Mar 16, 2011 | Toshiba Canvio 500 GB USB 2.0 Basics...
My Ativa 8GB usb flash won't let me delete anything. Then i tried to Format it and it won't allow that either! However it still plays my music... Idk... And there is an error message, when trying to...
click start control panel user accounts on the users tab,click the name of the computer administrator you can make yourself the administrator of your computer there which will give you all rights to change whatever you want on this computer
insert your pen drive click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
ports(com&lpt)right click update driver or
click start click on my computer you should see your pen drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Jan 27, 2011 | Computers & Internet
I plugged my usb stick into my computer. It recognises something is in the port but asks me to insert me stick when I double click on the usb stick folder in my computer
hope this helps
Jan 22, 2011 | Computers & Internet
Computer will not recognize the driver
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark?
hope this helps
Dec 13, 2010 | ION Audio VCR 2 PC USB VHS Video to...
Vivitar ViviCam 35 Digital Camera Logo
19 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
