Question about Samsung SPN4235 42 in. Plasma HDTV
No Sound on TV??
I inherited this TV secondhand. The picture works great but I get no internal sound whatsoever. I hooked up audio input from other sources, and they don't produce sound either, so I am sure it is the internal sound. I have fiddled around with the settings but can't find anything that works. Unfortunately I don't have external speakers so I can't check to see if external sound works. Any help would be much appreciated. Thanks!
  • Anonymous Mar 15, 2014
    bought the tv second hand no external speakers looking for a way to get sound has a great picture don't want to get rid of it
Thanks for the suggestion.   I have since discovered the problem.  Apparently this model does NOT have internal sound.  You must purchase their matching external speakers or get surround sound system (which i did).  then it works great.
Posted on Oct 22, 2007
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 187 Answers
I would borrow a set of external speakers to see if I could get sound from the sound circuit at all, if not, then it sounds like the repair shop.
Posted on Oct 21, 2007
6ya staff
SOURCE:
MY PICTURE IS GREAT,BUT NO SOUND. WHAT CAN I DO TO FIX IT?
Make sure TV is not muted.Make sure the TV is not set to SAP (secondary audio protocol)Make sure TV input is correct (someone may have accidentally pressed the "aux" input button or similar causing the TV to use an input with no sound going to it)Make sure there is not a pair of headphones connected to the TV audio out jack on the side or front of your TV.Check all of the cables that are connected into the back of your TV. (it is possible the TV was moved slightly and a cable has become disconnected or loose)If you have a receiver or surround sound connected to your TV, turn it on and see if you get sound coming from the external speakers.Turn off the TV, cable box, and anything else connected to the TV. Sometimes turning everything off and then back on can fix the problem.If using an "S" video cable into an input on the back of your TV, these cables carry no sound, just video, so make sure you connect an audio cable too.Hook up an external device to the "TV audio out" input. This will be the test to see if it is a TV circuit board malfunction or the speakers are faulty in your TV.If you are connected to a satellite box, use the included remote and go into the "menu". Check to make sure sound settings are set correctly.
Read More: http://removeandreplace.com/2013/11/14/10-ways-fix-tv-picture-sound/#ixzz3lTeW6isH
Sep 11, 2015 | Televison & Video
Xbox elite connected to TV thru HDMI works fine, but connected via bcs-fs500 receiver = no audio or video Cable tv through receiver works fine Have tried cable tv through receiver inputs HDMI 1 and 2...
Hook your Xbox to tv via HDMI, then hook TV to reciever through digital optical or composite cables. If you try to get your picture through receiver first, you may get picture and sound but, sound may be delayed and picture might not be the best. Bettter to run through tv first then provide sound to receiver.
Mar 31, 2011 | Pioneer Audio Players & Recorders
Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
No Sound
try accessing your tv settings menu and look for audio settings. usually there is an adjustment that you can make for external audio speakers such as when hooking up to a sound amplifier or internal audio that accesses your internal tv speakers.
Oct 03, 2009 | Apex Digital PF2020 20" TV
I have my xbox 360 connected via hdmi to my yamaha rx-v363 receiver, and the receiver connected to my sony bravia lcd tv via hdmi as well. The xbox picture comes through to the tv fine, but the sound will...
Connect Xbox via HDMI to DTV/IN, Connect HDMI from out to Sony Bavia's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby 5.1 etc .. cheers
Sep 04, 2009 | Yamaha RX-V363 Receiver
How do you hook up a dvd player to the panasonic 10801 hd tv
the easy way is RCA cables..Plug the video out of the dvd into the video input of the t/v...then plug the audio -right & left out of the dvd into the audio input of the t/v...For a great picture use an S-video cable from the dvd to the t/v BUT thats just for the picture not the sound. you still need rca cables for sound
Dec 19, 2008 | Televison & Video
No sound with new Vizio 22" LCD TV being used as monitor
you have to hook up the 1/4 headphone jack plug to the TV, from the computer. an Y audio cable with RCA plug (male) with headphone 1/4 male plug. hook the headphone jack to the green hole of the computer(sound out) to the audio input of the TV better yet to a stereo AUX port. also make sure the mute button hasnt been pressed.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 03, 2008 | Dell Dimension 4600 PC Desktop
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Ht-ddw790
Check the setup menu on your TV. Many models require that you choose between using the internal speakers and using the speaker outputs. Sometimes the TV menu choices are "FIXED" (audio output) or "VARIABLE" (internal speakers).
Feb 05, 2008 | Sony HT-DDW790 System
Samsung SPN4235 42 in. Plasma HDTV Logo
1,486 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
