Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Need Operating and Care manual
For gently used Saeco Caffeteria vending machine
  • 1 more comment
  • steveburgess Mar 16, 2009
    How can I get a copy of PDF of the manual?
  • berncar Apr 01, 2009
    can someone tell me the burr grinder adjustment numbers what they mean....and if i turn them to a higher number does it grind more or less ?
    email me at berncar@gmail.com
  • Anonymous Apr 11, 2009
    can you send me the manual?
I have a PDF of the manual if you still need it.
Posted on Feb 15, 2009
Saeco coffee vending SG200 cup dispenser keeps on getting jammed. I would fix it, then will get back to being jammed after a few used of cups. Cams color is black. Thank you!
If the cups are jamming straight after you clear a jam it means one of to things. 1: Non vending or poor quality vending cups are being used. The SG200 is very sensitive to the rim of the vending cup. Make sure the rims are circular are even and have no bits of card board hanging out of the rim.
2: Cup cams are out of alignment. Take all of the cups out of the machine and also take the cup carrousel (cup tubes) off. Look down at the 5 black cup cams and check if they all look in the same position. There is instructions on how to realign the cams on pages 52-53 in the manual that came with the machine. If you need a copy of the manual I'll need a email address the send it to you.
Mar 11, 2012 | Coffee Makers & Espresso Machines
Saeco coffee vending machine 7P is reading OUT OF SERVICE 06, it is not blocked have checked everything.
7p wouldn't be displaying 06. My guess is you have a Saeco SG200. 06 means the cup dispensers jammed. Remove all cups and switch the machine on. if the cup dispenser make a clicking sound the the cames in the cup dispenser is jammed and needs to be freeed. if it works theres no clicking noise, switch machine off, and reload the cups in the tube that arn't directly over the cam hole. if this is an ongoing issue, tell me what colour are the cams (theres 5 and there black or white) and describe the cup that your using.
Mar 16, 2011 | Kitchen Ranges
Configure the saeco coffee vending machine type AD 7P PLUS
Hope this is what you're after
http://pdf.archiexpo.com/pdf/saeco/7p-plus-11410-3425.html
Apr 05, 2009 | Saeco Royal Professional Espresso Machine
Out of service 16 message on a Saeco 8P espresso vending machine
Data Problem. hold reset button on inside of door while switching machine on. keep holding button down until it asks for a password(0000) or says system management.
Mar 20, 2009 | Coffee Makers & Espresso Machines
Need repair of boiler on saeco coffee vending machine
Coffee Machine Services. 2114 14th St NW (403) 282 4445
Authorized Saeco repair. Great work. Am bringing my machine there today & have used them before.
Mar 15, 2009 | Coffee Makers & Espresso Machines
I have a Saeco Incanto RS Espresso Machine. The prime light is on, but the machine won't prime. Very little water of steam comes out of the wand.
You need to manually prime it using the priming bulb that came with it. Instructions are in the manual. Remove water tank. Fill priming bulb. Hold priming bulb on water inlet. They don't inter-connect, so just hold it on there as best you can. Turn the machine on, turn steam knob on, and gently, slowly squeeze the bulb to force water into the machine. It works best when the machine is cold, because you want to get liquid water in there, and not have it displaced by steam.
Jun 30, 2008 | Saeco Incanto Classic Espresso Machine
Bypass doser malfunctions
Happens when the preground coffee is not ground fine enough, you may have to put the pre ground coffee in a manual coffee grinder to make it finer. The machine is not really designed to brew regular coffee grounds.
Jan 20, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
272 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
