Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Formula? how much soap do i use
My Bissell PROhear cleanshot2X needs a certain amount of soap, or so the bottle of soap says. I've been fillin the formula tank all the way to the line, should i keep doin that or water it down??
    Problem Solver:
  • 5 Answers
Only if you want to keep cleaning your carpet with detergent, but its not needed every time, turn dial on front top to water rinse (heavy,normal,light settings will determine how much soap you will be using)
Posted on Feb 19, 2009
Bissell 7920 ProHeat Upright Carpet Cleaner leaks soap
Just prespray with a pump up sprayer and use unit to extract only with hot water.
Apr 07, 2014 | Bissell 7920 ProHeat Pro-Tech Upright...
Manual
Hi Linda. This machine is an old faucet hook-up. The fresh water
comes from the faucet and the BISSELL formula was diluted and drawn from a
bottle that sat in your sink.
Here's a quick link to our current deep cleaning machines. http://www.bissell.com/deep-cleaner/?cid=ccsocial
We
offer free shipping and will currently take $10 off machines priced $59 to
$99.99 and $20 off machines over $100.
May 07, 2013 | Bissell 1631 PowerSteamer ProHeat Canister...
FHow much solution goes in first?
The tank is labeled. Take the clean/solution tank off the vacuum by lifting it straight up. Unscrew the black cap on the bottom of the tank and remove the bottle insert. Add 8 oz of the Little Green formula (this gets you up to the Formula fill line). Then add hot water to the water fill line. Replace the bottle insert and tighten the black cap. Then replace the clean/solution tank by lining the indentations up with the vertical guides on the left side of the unit and sliding it straight down. Please note that the bottles of the formula come in 32 oz or 64 oz bottles. So you can expect one of the smaller bottles to last 4 fill cycles.
I hope this helps.
Oct 07, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
We cannot get the water and soap to dispense in out Bissell steamcleaner
Check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have the Bissell heat pro 2x 8920 and the water doesn't come out. The soap just mixes with water tank and the carpet stays dry
Jun 14, 2010 | Bissell 8920 ProHeat 2XTM Upright Vacuum
I have an older model Bissell rug shampoo machine, model # 1631. I have several bottles of Bissell 5 One carpet formula to use in this machine, however I have lost the measuring bottle that tells me the...
I have a older mod. Bissell carpet machine plus mod. 1630-5 and need a floor nozzle part num.013-6194 and grip tube w/button part num.014-4181 and trigger part num.010-9406 and tube
Mar 22, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell proheat
First is the smart mix valve turning like it should? If it is then replace the soap dispensor. Also is the gasket on the valve at the bottom of the bottle?
May 28, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
How much soap and how much water do I put in the Bissell pro heat?
You are supposed to buy the Bissell soap. On the bottle depending which cleaner you need. The directions are on the bottle. Please do not use house hold cleaners because you can cause serious damage to the vacuum.
Go here, this pg. shows the 7901-1 click the user guide pdf & print the instruction if you choose:
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=7901-1+ProHeat+
Good cleaning!
Please vote..........
Jan 16, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
97 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
