Question about 3Com OFFICECONNECT Network Adapter
Dell Driver Problem
I formatted a dell gx60. I can not find the drivers required for the following items:
1st: Ethernet Controller
2nd: Network Controller
3rd: SM Bus Controller
I downloaded the suggested files from dell. No luck. Any suggestions would be greatly appreciated.
Thanks,
J
  • jgnorton Jan 30, 2009
    with the dell. did not change os.
Did the gh60 come with the Dell or was it added later?
Did you change the OS ? if so you need to go to dell and if the card is listed as per mfg you can get the driver for an updeted OS .
Posted on Jan 30, 2009
I wanted Dell Optiplex GX60 Ethernet Controller driver
You will find the driver for your machine on this page -
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Network+Connectivity&ProductLine=Intel%c2%ae+Desktop+Adapters&ProductProduct=Intel%c2%ae+PRO%2f100+VE+Network+Connection
Mar 14, 2011 | Dell OptiPlex GX60 (SFFDELL-C2G) PC...
I need driver for the ethernet controler,you can help?
If the ethernet controller is part of the Optiplex GX60 (it came with the system when purchased), then go to the following website and enter the make/model of your desktop and select the corresponding Network driver from the list.
http://support.dell.com
If the ethernet card was purchased separately (from a 3rd-party) then you will need to provide the make/model of that card to better provide support.
Aug 10, 2010 | Dell Optiplex GX60 PC Desktop
My ethernet port do not work I think my pc missing dell gx60 ethernet controller drivers
Verify if the driver is installed properly for the ethernet card using the device manager. If the device is not shown in the devoce manager, make sure the wiring for the card is done properly and there is no loose connection. If the problem continues, try replacing the ethernet card. If that too fails, there is some problem with your computer mother board
Hoe this helps. Feel free to reply if you have any doubts.
Regards
Sherbaz
Aug 06, 2010 | Dell OptiPlex GX60 (SFFDELL-C2G) PC...
I re formatted hardrive. reinstalled O/S. cannot connect to internet. device manager shows yellow question mark over ethernet controller, multimedia audio controller, video controller. has error message:...
What kind of computer do you have? The trick here is first to get the computer on the internet by finding out what kind of network card is installed on a internet connected computer do one of the following
1> If its a dell go to http://www.dell.com/support and click on download drivers enter your service tag number Download the network driver to a flash drive and install Connect to the internet and repeat the above process to install the other drivers.
Most manufacture websites will have a download page for the drivers but you can also google the make model and operating system drivers for example google acer aspire 1000 xp network driver.
if you post your make model and operating system I can help you better.
Aug 04, 2010 | Dell Ethernet Card Network Adapter
I need the drivers for the ethernet controller and the network controller for a Dell latitude D620
For the D620, you would go to the following website. You'll need to select the operating system that you're running, and then go to the "Network" section of drivers and download the drivers there. There may be several different drivers since the D620 came with several different network adapters - It's most likely the Broadcom - Driver 57xx Gigabit Integrated Ethernet Controller.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=04&l=en&s=bsd&os=WNET&osl=en&catid=&impid=&SystemID=LATITUDE D620
Download the file and run it - it will walk you through the installation.
Mar 04, 2010 | Dell Ethernet Card Network Adapter
No Audio Device for my DELL opti GX60. and no multimedia audio controller same as yellow mark ethernet controller.
For that first uninstall driver for ethernet controoler and audio driver from add remove program.
Also uninstall both from device manager.
Right click on my computer then click on property then hardware ->device manager then uninstall both from that list.
Then download driver from below link.
Click here
Click on above link and select yourt operating system and download audio and ethernet driver then install.
Let me know if you need further assistance.
Thanks.
Oct 26, 2009 | Dell Optiplex GX60 Refurbished Intel...
Reformated my Dell Dimension 2400, now under device manager I got the big yellow question mark for Other Devices - Ethernet Controller -PCI Simple Communications Controller Dell's driver support page does...
If you have windows Vista simply Right Click on the entry in device manager and choose Update driver (Requires working internet connection)
Else use the following drivers (Works on XP and vista)
ftp://ftp.us.dell.com/network/R64645.EXE
Oct 16, 2009 | Dell Ethernet Card Network Adapter
Cannot connect to the internet
Well what we can do is that we can use any other system and download the driver from it and copy it on to a USB PEN DRIVE and then connect that USB PEN DRIVE onto your system and then install them and everything would be done...
Here's the link for the NETWORK DRIVERS..
NETWORK DRIVERS
1st OPTION
(IF YOUR SYSTEM HAS 3Com 3C905C-TXM Ethernet Adaptor then use the link below)
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R49958&SystemID=PLX_PNT_CEL_GX60&servicetag=&os=WW1&osl=en&deviceid=2730&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=5&fileid=58953
2nd OPTION
( IF YOUR SYSTEM Intel 10/100 LOM then use the link below)
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R56484&SystemID=PLX_PNT_CEL_GX60&servicetag=&os=WW1&osl=en&deviceid=2834&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=5&fileid=67420
IF U R CONFUSED IN WHICH NETWORK DRIVER DO DOWNLOAD AND INSTALL THEN JUST CONTACT DELL TECHNICAL SUPPORT AND ASK THEM WHICH NETWORK DRIVER TO INSTALL, EVEN IF YOUR SYSTEM IS OUT OF WARRANTY THEY CANT DENY YOU TO TELL YOU ABOUT YOUR SYSTEM SPECIFICATION..
THERE IS ONE MORE WAY YOU CAN ENTER THE SERVICE TAG OF YOUR DELL SYSTEM IN THE LINK BELOW AND THEN VERIFY ABOUT ALL THE HARDWARE/SOFTWARE CONFIGURATION AND WHICH DRIVER TO INSTALL ON ANY OTHER SYSTEM
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
kindly rate this solution if u think its helpful to u..
May 28, 2009 | Dell Optiplex GX60 PC Desktop
Ethernet card
If your computer is from dell all support services are complete . omniplex gx60 is not found. only the optiplex gx60. try find your service tag then input it here. http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
this is the exact way of finding driver. Optiplex gx60 is there u can select the model option.
Dec 01, 2007 | Computers & Internet
3Com OFFICECONNECT Network Adapter Logo
312 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
