Question about Kenmore 9381x Top Load Stacked Washer / Dryer
Notsure if this is my washer
I have a washer / dryer that will not work in less both are on ....neather will out with out the other on
  • 183 Answers
It appears that you have a main timer/programmer fault, it would possibly be cheaper for you to get an engineer to inspect rather then fit an incorrect part. Regards Engineer
Posted on Jul 29, 2007
    Novelist:
  • 159 Answers
Sounds like a electrical problem. you should check the terminal block and cord to make sure there is nothing wrong with it. Burned wires etc. and also that the cord is properly attached. I would also check the voltage across the end terminals (red and black wire) and make sure there is 240v across them. then red to netral and black to netral should be 120v.
SOURCE:
What is HE detergents
Special low sud detergent designed for high efeciency HE machines.
Feb 08, 2013 | Maytag NFW7200TW Front Load Washer
Windscreen and headlight washers not working
It sounds as though their is a short, loose connections, or the water punps for these are out.
Inquire with a technician for diagnostic options.
carsandcomps
Mar 13, 2012 | 2002 Honda Accord
Taking a long to time to dry doesn.t get very hot
Igreat answer above now here is a great video shows how it works and what to check
Jan 04, 2011 | Dryers
I have an e63 error code on my dryer. It is only 1 year old and I have already had to repair my washer when it was less than 1 year old. Please help
try cleaning out the lint in you vents. Its your dryer getting too hot. u will need to replace the heater tube it this doesn't work
Nov 01, 2010 | Electrolux EIED55H Dryer
We bought samsunf fully automatic but we dont have adequate water supply so how to use it by adding water manually
check to make sure the filter at the connection where the hose goes into the washer is clear of debris. this can cause low water pressure if it's clogged. it's real simple to fix. just disconnect the hose from the washer and remove screen from inside the hole and clean it off and replace. Notsure if you can run the machine mannually by adding water.
Aug 11, 2010 | Samsung Washing Machines
Will not agitate or spin. Makes a sound almost
make sure that the belt is still on the drive on the bottom of the washer.
Oct 15, 2009 | Washing Machines
Can I replace the dryer on my frigidaire stacked washer and dryer model # mlc275cw5?
I don't think you can replace the whole dryer section as a piece. If it just stopped working correctly you can replace internal parts to fix it. If it suffered some catastrophic damage (many parts destroyed) it will probably be less expensive to replace the whole laundry center.
Oct 11, 2009 | Dryers
Would p1887 cause my 04 Chevrolet Cavalier to "hard shift" going into 1st gear, then a less hard shift going into 2nd gear? If so, what type of business would fix this?
IT wll cause hard shifting. The problem is your torque converter. Any transmission shop could fix this for you. Notsur if goodyear or firestone could do this for you.
Sep 30, 2009 | 1996 Chevrolet Cavalier
Control locked on ghw920 can u help me unlock
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Kenmore 9381x Top Load Stacked Washer / Dryer Logo
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
