Question about Compaq Presario Notebook
Ubuntu is not starting...
I installed ubuntu inside vista.. when i choose ubuntu during boot it gets strucked up...i`ve installed ubuntu 8.10 64 bit..
my processr is amd athlon dual core 64 bit...
please help.....
    Sergeant:
    Champion:
  • 318 Answers
Uninstall Ubuntu and try Ubuntu 32bit version.
Vista sometimes does not get along with other software,or O.S
Posted on Jan 30, 2009
Want to unistall ubuntu 12.04 from hp sleekbook and install windows 8.1. pls help
Assuming you have your windows 8.1 on disks, make sure your HP is set to boot from disk and put disk in and boot your computer up. The windows install should start and you can choose to delete Ubuntu and install windows. Remove any partitions that it displays and choose to install windows on the entire disk. After that just follow the prompts and windows will install.
Mar 22, 2014 | Canonical Ltd. Ubuntu
How do i run windows 7 and ubuntu side by side in VGN-NW240F?
Download ubuntu iso from www.ubuntu.com and burn to a cd or usb. You can choose either a 32-bit or 64-bit iso from the website and before choosing, check if your windows is 32 or 64-bit in "System" under "Control panel".
When you boot from the cd/ usb you will get to the install interface where you can choose to install ubuntu along windows. Then you can choose how big you want your ubuntu partition to be and that's it - the installer does the rest of the work. You can now choose between windows or ubuntu at every start up.
Nov 03, 2011 | Sony VAIO VGNNW240F Notebook
Reformat laptop with Linux
First you need to choose a linux distro, I suggest ubuntu since it is the easiest by far.
Steps for installing ubuntu -
1. go to http://www.ubuntu.com/download/ubuntu/download and follow the directions to burn a live cd
2. restart your computer with the live cd in the cd drive
3. you can choose to try ubuntu, test it out for a bit, and then install it from inside ubuntu, or you can install it directly from the menu you get when your computer boots up. When trying ubuntu, you can also mess around with the built in partition editor ( there is an option to format the whole drive when installing so you don't have to worry about formatting before installing)
4. Just follow the instructions and install, and then enjoy :)
Jul 06, 2011 | Acer Computers & Internet
After installing ubuntu i get a blank screen saying error
I think, this problem happened because you are installing Ubuntu from the ISO image on your physical hard drive.
Here is the way around this problem. when you get to the option to unstall Ubuntu, press F4 and choose Safe graphics mode. then choose the first option on the menu:Try Ubuntu without any change to your computer.
If you still get the same problem do this:
At the prompt, press F4 and select "Safe graphics mode".
then press F6.
Modify the following boot line:
"Boot Options seed/ubuntu.seed boot=casper initrd=/casper/initrd.gz quiet splash -" Delete the part that says "quiet splash "" -" and replace it with "vga=791 noreplace-paravirt"
That will make Ubuntu boot onto the GUI. After logging into Ubuntu Interface you should be able to see an installation folder on the desktop:
Click on the Install folder. The installation wizard should come up:
Select the language and click Forward. Next Choose your location:
Choose your city, and click Forward. Don't worry if the time zone is not OK, you can change that later when you login to Ubuntu.
Next, you will need to choose your Keyboard layout, if you are in the US, mostly all your options will be the default. If you are not in the US, choose your settings accordingly. Click Forward.
Next, you will need to prepare the disk space, remember that you chose to use 10 GB of hard disk space for this virtual machine, so select the default option, Guided "" use the entire disk.
Click Forward. Next, you will have fill out, your name, your username, password, and Computer name":
After you have entered the info, click on Forward. Next, you will get a summary of the installation. Click Install to begin the installation:
The installation should start.
After 20 "" 30 minutes, the installation will finished, and will ask you if you want to reboot. At this stage Ubuntu is installed on your computer permanently.
Click on Restart now. Now Ubuntu should be installed and ready to be used on your virtual PC
Jun 20, 2011 | HP Pavilion a1700n PC Desktop
I have installed ubuntu in drive C(66gb) with windows xp,giving 13 gb space to ubuntu and rest to xp .now i have deleted the disk partition for ubuntu of 13 gb .when i start computer it shows grub error-17...
when this happened to me on my Vista machine last year, I freaked out until I accidentally fixed it using by booting with my original Vista boot disc, and choosing 'Repair OS'. Try finding a/your original Windows XP install disc and seeing if it will repair and replace your own Windows boot sector. It would be best to find the one that came with your system, or another like it, but if all else fails, just try a hologrammed Windows XP install CD, but instead of 'install', choose 'repair'.
Feb 15, 2011 | Compaq Presario M2000 Notebook
How can I uninstall Ubuntu from Dual Boot. I have a dual boot of Windows Vista Ultimate with Ubuntu 9.04 The specs of my computer is 2gb ram, 500 gb HDD and dual core processor 2.66ghz (E5300). I installed...
How to remove Ubuntu from a Vista dual-boot config
On my new PC I wanted (still want) to have toa go with Linux. I chose to experiment with Ubuntu. I downloaded thedesktop CD, burned it, freed up some disk space (inside Vista) andloaded up Ubuntu from the CD. After some experimenting I figured outhow to install Ubuntu in the empty disk space and it all worked fine(GRUB took over my booting (recognized Vista automatically!) and Ubuntuloaded up fine).
Then I tried to install my GPU drivers andeverything went wrong.. For some reason Ubuntu wouldn't boot anymore(failed to load X-Server or something). I was completely lost andwanted to remove Ubuntu.
This is where things start to get really messy!
Ifyou simply remove the Ubuntu partition, GRUB (Linux boot loader) willstill be on your PC (in control). It will trip out, as the Ubuntupartition will be removed.. Bad thing!
So you need to restore your Master Boot Record (MBR) for Vista (so that Vista will handle the booting, not GRUB).
Googleonly pointed me to sites that explained how to REMOVE VISTA, whichisn't what I wanted. Many sites talked about the 'fixmbr' command, butthis is really only available in Windows XP.
So how do you restore your MBR for Windows Vista?
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec.exe /FixMbr, and then press ENTER.
That'sit. Now when you reboot your PC, Vista will load automatically... Youcan now safely boot using your Ubuntu desktop CD, to use the built inGnome Partition Manager to remove your Ubuntu partition!
Apr 06, 2010 | Microsoft Computers & Internet
I was trying to load ubuntu onto a spare hard drive i had lying around. i used my everex stepnote 1500 note book to load the system on to the spare hard drive. now when i turn on my note book without the...
You should install Ubuntu from inside Windows with the wubi program. When you boot you will have Windows as the default boot option and Ubuntu as a second option. Choose the Ubuntu installation to reside on the external drive. You will connect the drive if you use Ubuntu.
If you do not do that, reinstall ubuntu on the external drive and choose to write the boot sector for GRUB or LILO on the external drive, not on the MBR of the primary drive.
Hope it helps.
Sep 12, 2009 | Everex StepNote NC1500 Notebook
Ubuntu linux compatibility with vista
1.Repartition HD to fit Ubuntu
2. Install Ubuntu
3. Upon starting computer, select operating system (Vista or Ubuntu)
You could also use Wubi which is a program on the ubuntu 8.10 cd that allows you to install Ubuntu right from Vista and it will run just like it's an app per say. Just to warn you though, it will not run as fast and if you are installing this on a laptop it won't be able to hibernate. Also it doesn't require you to create a separate partition to install Ubuntu. This could potentially be a bad thing, depends on how you look at it.
Hope this helps!
Jan 29, 2009 | Compaq Presario Notebook
Ubuntu grub error 17
You have to delete the ubuntu partition completely and recreate a new partition for the vista install. You can do this during the vista setup.
Jan 19, 2009 | Canonical Ltd. Ubuntu
Ubuntu Install Problem
i gav encountered this prob while i was helping my frnds install UBUNTU......then i found out they had low RAM.....but if ur patient n wait for a lil longer it does work on som comps.....its better u upgrade ur RAM....
Aug 12, 2008 | Canonical Ltd. Ubuntu
Compaq Presario Notebook Logo
158 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
