Question about Sylvania LC320SS9 32 in. LCD TV
Sylvania model lc320ss9a code needed for direct tv rc32 remote
Tried many and none work. help
  • marktwainer Jan 30, 2009
    Trying to program the rc32 direct tv remote to Sylvania LC320SS9A tv. We tried many codes including other brand names like phillips, emerson, etc and none worked. Has anyone figured this out?
  • gbody38 Mar 18, 2009
    need to find a code that works for this tv, i have tried other codes and remotes
  • 8 Answers
SOURCE: Remote Control Codes don't work with my LCD TV
There is no code!!! -- Solution...You have to buy a universal remote with learning capabilities. I’ve ordered one that will not only learn off other remotes but can handle 10 components also. I got it from 10x it’s called the iconRemote control…if you call the company they will give you a discount (but you have to call them and ask) AWESOME!
Posted on Mar 01, 2008
SOURCE: Sylvania LC155SC8 remote TV code for Verizon Fios
buy the radio shack "6 in 1 remote. It has a "learning" mode that picked up all my needed commands from both my verizon fios remote and my new sylvania hdtv remote. works perfectly.
Posted on Apr 02, 2008
SOURCE: Need 3-digit TV remote code--Sylvania 15" LCD HDTV
many of the dish remotes have a "scan" option. This is what the installers use. You'll ned to read the manual. Its a one page explanation.
Posted on Oct 29, 2008
dsacco86
  • 1077 Answers
SOURCE: cant program direct tv remote with my new sylvania lc320slx
The remote is only programmed with only so many codes. Sadly, It doesn't hold all code for every TV made.
But you can try making the remote search every code stored inside to see if one of them will work.
Here are the instructions form the DIRECTV web site:
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Posted on May 18, 2009
  • 10 Answers
SOURCE: I need a remote code for my Sylvania TV. LC320SLX
I called Comcast and they had no clue. But I called Sylvania and their reps were FABULOUS!!! Turns out, the TV makers send the cable companies the frequencies for each TV then the cable companies send them to a 3rd party to get the codes written.
This model of TV is new and there is no code written. The rep suggested that we countinue to check back on the Comcast website regularly to see if the code is posted. She said that the sales reps tend to get the info last.
The Sylvania rep anticipates a new code written soon because this is such a prevalent problem.
Posted on Dec 20, 2009
Direct TV remote
I think you mean Hughs when you're referring to your direct Tv remote? And you want that remote to turn on/off your Sylvania Tv, right?
I'd need to know the Hughs model number on the remote to know if it's a four or five digit code requirement. But here's a site that might help. http://www.remotecodelist.com/remotes/
Scroll down to Hughs and that link should take you to the DTV site where they have a wealth of info regarding codes. Find your model number remote control and you should have a list of possible codes to try.
If all this doesn't work let me know and I'll research sme more.
Good Luck!
Bill
Nov 25, 2007 | Sylvania SH50102 LCD Remote Control
Universal remote for sylvania model lc320ss9a
Universal remote codes to check with Sanyo brand TVs are: 0020 0054 0186 0028 0030 0171 0381. Check this link. There are details about codes and setup instructions to different remote controls. Check which remote control have setup codes with your TV, and buy that one.
Jan 16, 2013 | Sylvania Televison & Video
I have a Direct TV remote that I need to program to operate my Sylvania HDTV model LC320SS9. None of the codes listed by DTV work for this TV. Do you have any suggestions for programming the remote? DB
hi! i have a couple of codes for your tv, just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483, 1046, 1465, hope this helps! goodluck!!!
Feb 25, 2010 | Sylvania LC320SS9 32 in. LCD TV
OLEVIA 42 IN LCD USIND A DIRECT TV RC32 REMOTE CANNOT FIND A CODE
If none of the codes in the DTV manual work, I would suggest calling Olevia. Often times the same television set is marketed under several different brand names and Olevia would be able to sugges codes from other manufacturers that may work for you.
Mar 19, 2009 | Televison & Video
Need code for universal remote
I need to know what model the Unversal remote is. if it take a 4 digit code, you can try these:  0054, 0030, 0171, 0020, 0096
Feb 09, 2009 | Sylvania LC320SS8 32 in. LCD Television
Directv universal remote
ok i have a sylvania tv/vcr combo, similar problem, here's how i got the directv remote (RC23 & RC32) to operate basic t.v. functions:
-First i found the code that worked for the vcr (20000 in my case).
-i programmed "AV1" to 20000, this allowed me to power the tv on/off, change the channels but not operate the volume, so...
-after plugging in the 20000 code (with the slelector switch on AV1 still):
1. Press and hold the MUTE and SELECT keys until the
green light under the TV position flashes twice, then
release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press select
that allowed me to operate the t.v. volume from the remote w/ the selector switch in any position, the only thing is i have to switch to AV1 in order to power off the T.v.
hope this helps in your case
Jan 31, 2008 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
Need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Oct 01, 2007 | One For All URC-3021 Remote Control
Sylvania LC320SS9 32 in. LCD TV Logo
731 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
