Question about Canon Rebel XT / EOS 350D Digital Camera
Pictures are oly half shown\take
I'm taking pictures tonight, and all of a sudden the pics are half black o the bottom and the upper half is i view.
i did not drop it or shake it,
any ideas........................
  • cathryn121 Feb 03, 2009
    taking pictures either all black or 1/2 black and 1/2 ok stared as ever other now everyone
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 51 Answers
That not good at all sounds like you shutter has failed.
pictures look similar to this?
http://lh4.ggpht.com/_wxfFvzT47Fs/R_gboSj-IkI/AAAAAAAACb4/DQ0sg-nJfbY/IMG_2748.JPG
if so you need your camera serviced do not take anymore pictures or you risk damaging the sensor.
Posted on Jan 30, 2009
--cannot view anything to take a picture of--the view screen is black but I can see al menu items and can display settings. Flash works. I can see cannon signal clearly when camera is turned on. I am...
The A6XX series is prone to stuck shutter problems, particularly if the camera isn't used very often. Lens lubricating grease can coagulate on the shutter, immobilizing it. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 29, 2011 | Canon PowerShot A630 Digital Camera
After I take picture, the picture is captured & shown but when I try to view,(by pressing playback) it displays 'Cannot playback Image' with a big question mark. When I downloaded & tried to view...
Check to make sure that you did not accidentally change image format from jpg to crw(camera raw). Your camera lcd will only display jpg files and you need special software to view raw files on the pc.
Dec 30, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
Samsung HPR-5052X Plasma issues. Recently started
If the picture os goint to lines right from the midpoint downward then most likely you will have to replace the lower y-buffer board part number BN96-02027A. The board is mounted on the left side of the plasma panel when you take the back off. The upper y-buffer board sounds like it is failing as well and this was a very common issue on the older Samsung plasmas. The part number for it is BN96-02026A. Please take a moment and rate my answer. Thanks...
Nov 26, 2009 | Televison & Video
Long delay on oly evolt 510 before taking picture in P,A,M modes
I'm guessing you have a delay set (people will use this on a tripod). The small button on the top left (next to the flash control) will solve your problem I think.
Feb 01, 2009 | Olympus EVOLT E-510 Body Only Digital...
Screen problem??
This sounds like a cracked screen.. a leaf you say? is the leaf a graphic, perhaps an icon.. is it centered on the screen at all?
hmm....
I would take it to a certified repair center to see if they can replace the LCD panel.
Sounds like it needs to be replaced.
Oct 31, 2008 | Cameras
THE LCD SCREEN IS BLACK AND I CANT TAKE A PICTURE. BUT I CAN STILL VIEW MY PICS. THE CAMERA GOES THRU ALL THE MOTIONS LIKE IT IS TAKING A PICTURE BUT IT IS JUST COMING UP BLACK.
The LCD screen is black and I can't tace picture. But I can still view my pics. The camera goes thru all the motions like it is taking a picture but it is just coming up black.
Aug 31, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Dsc-t1 has a very "grainy" screen on viewing to take picture, when the picture has been took the image is still grainy but not as much. Ive also noticed horizontal lines on upper half of the...
Dear Davo Pottso
This has even happen to my camera, i suggest u to ignore this effect. It has been said that in sony cameras a type of Iodine glue is ussed inside which reacts and causes these sort of problems on heating of the camera. My best advice is to keep the camera cool and avoid over heating by continous shots.
Dec 07, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Pictures mysteriously deleted
Are you sure the pics aren't in a separate folder?
Nov 27, 2006 | Panasonic Lumix DMC-LZ3 Digital Camera
SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Mar 25, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Canon Rebel XT / EOS 350D Digital Camera Logo
100 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
